Текущее время: 01 май 2025, 02:36
 Заголовок сообщения: Dell XPS 17 9700 (Stradale CMLH MB 18835-1) Dell logo shows for one second and screen goes blank but backligh
СообщениеДобавлено: 10 июн 2024, 03:56
Hello everyone, the client said the laptop was performing updates and after, that happened. The laptop behavior is as follows:
1. When the laptop is powered on or auto powered from a power reset, the dell logo shows for a second and the screen goes blank but the backlight stays on. This happens whether memory is installed or removed. It stays like this for a considerable time and then it repeats.
2. All the voltages rise, and fans spin for that one second that the logo comes on and goes off and then all voltages drop, with the exception of 3V/5V ALW and PCH voltages 1.05v, 1.8v, and 3.3v, and heat from the PCH is considerably low.
3.There is oscillation on the 24Khz for the PCH but not on the 24Mhz. There is also oscillation on the EC controller EC5107 crystal.
4. The battery charges and current draw from charger when laptop is powered without battery installed is hovering between 512mA an 517mA.
5. ME Analyzer showed errors in the bios backup, and I repaired and reflashed and also tried different files online but still no change in behavior.
I'm at a loss now as to whether it has developed a hardware fault or it's still a firmware issue. Any help in the right direction will be appreciated.
 Заголовок сообщения: Re: Dell XPS 17 9700 (Stradale CMLH MB 18835-1) Dell logo shows for one second and screen goes blank but back
СообщениеДобавлено: 21 авг 2024, 13:12
Я бы для начала посмотрео что там с биосом происзодит и стартовал бы с чистого дампа.
СообщениеДобавлено: 30 авг 2024, 01:51
Send your dump here, you have to modify old dump cause dell does not like firmware from other machine
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL XPS 17 9700 (Stradale CMLH MB C31KJ$JA) Не загружается ОС с флешки или SSD
в форуме Dell
dzigarok
07 окт 2022, 19:25
dzigarok Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. XPS 17 9700 (Stradale CMLH MB C31KJ$JA) распаковка биос
в форуме Dell
_Рустам_
13
4025
31 янв 2021, 20:29
_Рустам_ Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo g580 (intel) blank screen after logo
prestigionr
04 июн 2015, 09:03
В этой теме нет новых непрочитанных сообщений. dell precision 5750 (Stradale CMLH MB C31KJ) Включается и зависает на логотипе DELL
в форуме Dell
Walkman
29
3237
18 янв 2024, 03:50
khvkdv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Is this second hand 3090 Gigabyte Eagle OC good for purchase? It passed Furmark and Unigine but not MATS/MODS.
Shayan
31 дек 2023, 21:07
FrostDad Перейти к последнему сообщению
