LA-E331P
Код 43 на видео карте quadro m1200. Питание на GPU, VRAM присутствует. Хочу протестировать видеопамять.
Загружаюсь с тестового HDD
cd 400.247_1660
./mods gputest.js -skip_rm_state_init -short -notest
MODS arguments :
MODS start: Tue Apr 9 10:38:10 2024
Command Line : gputest.js -skip_rm_state_init -short -notest
CPU
Foundry : GenuineIntel
Name : Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
Family : 6
Model : 14
Stepping : 3
Version
MODS : 400.247
OperatingSystem: Linux (x86_64)
Kernel : 4.17.4-gentoo
KernelDriver : 3.87
SBIOS Version : 1.38.0
SBIOS Date : 04/09/2024
HostName : tinylinux
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x13b6
Raw ECID : 0x026010c00000000402c009d1
Raw ECID (GHS) : 0x1740402c008000000030084c0
ECID : T10B02-03_x01_y19
Device Id : GM107
Revision : a2
NV Base : 0xec000000
FB Base : 0xc0000000
IRQ : 16
Successfully cleared GPU's interrupt state.
WARNING: GPU 0 [01:00.0] PCIE speed capability (8000Gbps) higher than down stream port link speed (2500Gbps)
Chipset
VID : FFFF (Unknown)
Chipset DID : FFFF (Unknown)
Rm call failed. default Disabled.
Chipset ASPM : Disabled
Chipset LTR : Enabled
resumehandler.js: 1
gputest.js : 29
short.spc : 5
boards.js : 3
Error Code = 000000000000 (ok)
[1;39;42m[0m[1;39;42m [0m
[1;39;42m ####### #### ###### ###### [0m
[1;39;42m ######## ###### ######## ######## [0m
[1;39;42m ## ## ## ## ## # ## # [0m
[1;39;42m ## ## ## ## ### ### [0m
[1;39;42m ######## ######## #### #### [0m
[1;39;42m ####### ######## ### ### [0m
[1;39;42m ## ## ## # ## # ## [0m
[1;39;42m ## ## ## ######## ######## [0m
[1;39;42m ## ## ## ###### ###### [0m
[1;39;42m [0m
[1;39;42m[0m
MODS end : Tue Apr 9 10:38:12 2024 [2.317 seconds (00:00:02.317 h:m:s)]
./mats -n 1 -e 20 > test.txt
Running mats on card with index 1.
NOTICE: For secondary gpus make sure you have run ./mods gputest.js -skip_rm_state_init first.
Error: Can't find Pci device with class code 0x30000, index 1
Could not find a video controller. If you are running mats on 3d controller please try ./mats -3d_card
Почему ошибка Error: Can't find Pci device with class code 0x30000, index 1 ?
Подскажите, как протестить видеопамять.
