dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work https://vlab.su/viewtopic.php?f=41&t=16099 |
ayad [ 08 окт 2013, 08:35 ] | |
Заголовок сообщения: | dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work |
Hi all , I have dell vostro 1015 it dose not work , the +3.3V_ALW is ok , but +5V_SUS is absence , please any one could tell me why . What different between ALW , SUS signals , and what S3 , S5 meaning ............. |
mashder [ 08 окт 2013, 10:50 ] | |
Заголовок сообщения: | Re: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work |
ayad писал(а): Hi all , I have dell vostro 1015 it dose not work , the +3.3V_ALW is ok , but +5V_SUS is absence , please any one could tell me why . What different between ALW , SUS signals , and what S3 , S5 meaning ............. "doesn't work" is not enough in order to understand what is goin on. Please give more details what is going on when you push the power batton, current consuption before and after pushing the power button, fan behavior, etc... |
ayad [ 08 окт 2013, 11:52 ] | |
any led dose not glow , fan dose not move ..... |
mashder [ 08 окт 2013, 12:24 ] | |
ayad писал(а): any led dose not glow , fan dose not move ..... You didn't tell regarding power consumption. Any way, if you have 3.3 v you would probably reflash the bios. |
ayad [ 08 окт 2013, 16:55 ] | |
I did but nothing change |
mashder [ 08 окт 2013, 17:49 ] | |
ayad писал(а): I did but nothing change Did you check with scope whether or not there is communication between BIOS chip and multicontroller? What multicontroller is there? |
ayad [ 09 окт 2013, 10:06 ] | |
it is ITE8502 |
ayad [ 12 окт 2013, 12:26 ] | |
Заголовок сообщения: | Re: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work [РЕШЕНО] |
I have solved that problem , I have replace XTAL near KBC , thanks to all.......... |
mashder [ 12 окт 2013, 19:29 ] | |
ayad писал(а): I have solved that problem , I have replace XTAL near KBC , thanks to all.......... Well done! ![]() |
