Текущее время: 21 май 2024, 16:50
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 08 ноя 2013, 13:15 |
Зарегистрирован: 01 июн 2013, 20:03 Наличности на руках: 18.07
chulat писал(а): Laptop repairs done before? Power is on videoadapter? I checked all broad with true photo about missing part, but it is OK, we have 0.95 volt on nvidia chipset power supply inducer. but no Nvidia adapter recognized.
_________________ Don't give up without the fight.
chulat
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 08 ноя 2013, 16:04 |
Сообщения: 955 Откуда: Дербент
Device Manager is also nothing in the tab Display Adapters? Make is photo, please.
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 08 ноя 2013, 17:50 |
chulat писал(а): Device Manager is also nothing in the tab Display Adapters? Make is photo, please. There is photo. I guess something about ME region. Bios with clear ME is available?
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 08 ноя 2013, 20:15 |
chulat писал(а): Dell N5110 has 3 video adapters: 1. AMD Radeon HD 6470M 2. Intel HD Graphics 3000 3. NVIDIA GeForce GT 525M
Disassemble the laptop and look at the name of the video chip. It is HM67(PCH) and Nvidia Video chipset.
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 08 ноя 2013, 20:38 |
chulat писал(а): 1. Part-Code video chip on the motherboard what? 2. Maybe your laptop there are no discrete graphics?? Dell N5110 is sold in three different versions c video: а. AMD Radeon HD 6470M b. Intel HD Graphics 3000 c. NVIDIA GeForce GT 525M I said before: This MB have Nvidia Chipset.
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 08 ноя 2013, 21:09 |
Sergej писал(а): P.zonouz, maybe - you have BIOS from UMA or discrete ATI ?? You have true BIOS?
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 09 ноя 2013, 11:36 |
chulat писал(а): Which is 4 pins of PU9201? yes. 4th pin is 3.3 so PowerGood is TRUE.
Doc
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 09 ноя 2013, 19:11 |
Зарегистрирован: 22 апр 2012, 19:23 Наличности на руках: 2,124.96
Сообщения: 2778 Откуда: Togliatti
P.zonouz писал(а): Sergej писал(а): P.zonouz, maybe - you have BIOS from UMA or discrete ATI ?? You have true BIOS? from official site exe /writeromfile
P.zonouz
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 09 ноя 2013, 19:14 |
Doc писал(а): P.zonouz писал(а): Sergej писал(а): P.zonouz, maybe - you have BIOS from UMA or discrete ATI ?? You have true BIOS? from official site exe /writeromfile I tested it. nothing changed!
RsM
Заголовок сообщения: Re: DELL N5110 (DQ15) Cannot find Nvidia graphic Добавлено: 10 ноя 2013, 17:04 |
Модератор |
Сообщения: 8282 Откуда: Сыктывкар
P.zonouz писал(а): RSM what do you think? The same that DOC -quartz -GPU -power -CPU -PCI-E
