https://vlab.su/
M90 (la-2881p) charging
https://vlab.su/viewtopic.php?f=41&t=34774
Страница 1 из 1
ayad [ 30 июл 2015, 16:06 ]
Заголовок сообщения:  M90 (la-2881p) charging
hi all , when i push bottom switch , i got this warning in brief :
you should use ac adapter 130W , hit F1 to shut down
i have used adapter with 130 w but nothing change
i have tested PR2 PQ2 PD1 PU12 PU11 ext.... all are ok
so could i change bios dump to prevent that message ?
ars44 [ 02 авг 2015, 14:56 ]
Заголовок сообщения:  Re: M90 (la-2881p) charging
Try BIOS settings reset to default.
ayad [ 02 авг 2015, 15:52 ]
i have used spi programmer but nothing change
Sergej [ 02 авг 2015, 19:07 ]
:sh_ok:
Try a BIOS for Dell Inspiron 9400 - the same MB, but it work with 90W power supply und hasn`t this "press F1";
servmv [ 16 авг 2015, 18:40 ]
Look oscilloscope on a thin wire should go charging data. Look pulses in the laptop can be a problem in the connector. This is a typical problem.
ayad [ 24 мар 2017, 13:30 ]
Sergej писал(а):
:sh_ok:
I have used bios of Dell XPS M1710 and it is succeeded thanks for your advise .......
http://www.phpbb.com/
