https://vlab.su/
Dell E6540 (la-9411p, la-9413p) Charger unknown
https://vlab.su/viewtopic.php?f=41&t=77489
Страница 1 из 1
scobay [ 24 июн 2018, 19:08 ]
Заголовок сообщения:  Dell E6540 (la-9411p, la-9413p) Charger unknown
Hi I have 2 Dell Latitude E6540,
1 had short circuit which I fixed but both say charger unknown in bios and on post. Charger is original and confirmed good on a 3rd same model which also had a short which I repaired, this sees the charger as 90w.
1 is La-9411p and the other is La-9413p.
I have checked the PS_ID signal on Scope and both are present to KBC (mec5075).
Is there a common issue with this model ?.
Thanks
Lendrover [ 26 июн 2018, 16:00 ]
Заголовок сообщения:  Re: Dell E6540 (la-9411p, la-9413p) Charger unknown
Hey.
Try to reset the BIOS using JTAG_RST.
Multicontroller KBC mec5075 has its own firmware. Maybe you need to flash it.
scobay [ 27 июн 2018, 03:49 ]
Hi yes I cannot find dump of Mec for the la-9413p.
http://www.phpbb.com/
