Dell Alienware M15x (DELH-41-AB3900-A00G) BIOS NEEDED https://vlab.su/viewtopic.php?f=41&t=84033 |
mateus_25 [ 10 дек 2018, 20:09 ] | |
Заголовок сообщения: | Dell Alienware M15x (DELH-41-AB3900-A00G) BIOS NEEDED |
Hi I`m looking for BIOS Dell Alienware M15x, main DELH-41-AB3900-A00G U15 - SST25VF040B - 4Mbit U7 - SST25VF016B - 16Mbit Regards matt |
kalya [ 10 дек 2018, 22:56 ] | |
Заголовок сообщения: | Re: Dell Alienware M15x (DELH-41-AB3900-A00G) BIOS NEEDED |
It's good to ADD your backUP |
mateus_25 [ 11 дек 2018, 11:12 ] | |
Original bios dump attached |
viktor-novikov51 [ 11 дек 2018, 12:00 ] | |
https://downloads.dell.com/bios/R293649.exe it has everything you need. Open with archiver |
mateus_25 [ 11 дек 2018, 15:08 ] | |
I checked the dump from the given link and the computer does not work on them. The EC has a size of 128KB, and the original is 512KB. My EC dump is almost empty so I think that's where the problem is. I tried to complete 128KB "FF" up to 512KB but it does not work. On the original dump main and EC after starting the laptop the Num, Scroll and Caps lights flash, the picture does not show up on the screen. Power consumption about 1.5A for 5 seconds, then drops to 1.2A On dumpod viktor-novikov51 these controls are not flashing and the picture does not show up. Power consumption the same as before. thanks for your help |
kalya [ 11 дек 2018, 18:32 ] | |
mateus_25 писал(а): Power consumption about 1.5A for 5 seconds, then drops to 1.2A 1.5A is so much to run. you have a short in the power circuit |
mateus_25 [ 11 дек 2018, 19:55 ] | |
kalya писал(а): mateus_25 писал(а): Power consumption about 1.5A for 5 seconds, then drops to 1.2A 1.5A is so much to run. you have a short in the power circuit 1,5A is after start the laptop. In S5 state consumption is 24mA. |
