Текущее время: 22 ноя 2024, 00:01
 Заголовок сообщения: Dell Inspiron 15 Gaming (LA-E992P) not charging
СообщениеДобавлено: 13 авг 2019, 00:44
Hi Russian friends,
I got 2 machines with same problem, one is Dell Inspiron 7567, other is Inspiron 7577.
Think it's some manufacturing issue because I had more of these with same issue I couldn't fix, so I sold it for parts.
Thing is that laptop is detecting charger normally and saying it's charging, but actually it isn't.
I got present charging voltages on battery connectors + control voltage from EC. I tried flashing BIOS, changing charging IC and changing EC. Nothing helped. Batteries are all good, so are chargers.
Those machines got some smart charging chips, they was shipped with 130W chargers instead of 150W or 180W. They are designed not to charge at all while laptop is under full load, it was obviously problem to ship machines with 180W PSUs, very disappointing from Dell. I guess that's the reason why they are failing.
Anyway, if anybody had similar issue and managed to solve it please advise.
Thank you in advance
Greetings from Croatia!¨:)
 Заголовок сообщения: Re: Dell Inspiron 15 Gaming (Intel Core i7) not charging
СообщениеДобавлено: 22 авг 2019, 11:48
Dell Inspiron 7567 originaly complectes with 130w adapter
https://www.dell.com/en-ca/shop/accesso ... polaris-pd
Inspiron 15 7000 Series (7566)
Inspiron 15 7000 Series (7567)
but
BalkanBoy писал(а):
Inspiron 7577
with 180w adapter, for lot money on ALI https://www.aliexpress.com/item/32851000748.html
there were cases need battery replace,
after new battery replace all OK.
СообщениеДобавлено: 23 авг 2019, 21:52
I solved the issue, one MOSFET was shorted, it was B04N03 near the battery connector. I was checking voltages earlier and didn't noticed that, everything looked good. Later I noticed that MOSFET was actually shorted which is really strange as machine was working normally besides not charging battery.
Anyways, I hope it would be helpful for somebody else reading this :)
В этой теме нет новых непрочитанных сообщений. E5-571 (LA-B161P) not charging not switch with battery
erdi34
06 окт 2018, 20:25
t.tashbaev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo legion y540 (nm-c371) Not charging not switch on..
pcexpert8
29 дек 2022, 20:12
Yariy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Inspiron 15-7577 P72F001 (LA-E992P Rev 2.0) No Initialization, possible dead GPU
в форуме Dell
mohammedsf
25 янв 2023, 08:07
mohammedsf Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. INSPIRON 15-7577 la-E992P dis не получается залить чистый регион
в форуме Dell
makmain
11 дек 2019, 19:49
makmain Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Inspiron 15-7577 (LA-E992P) Включается только после сброса CMOS
в форуме Dell
lelykgsm
04 янв 2021, 21:13
lelykgsm Перейти к последнему сообщению
Сейчас этот форум просматривают: pinkerator и гости: 41
