b250a-btc v20 no voltage cpu https://vlab.su/viewtopic.php?f=44&t=111450 |
bokin021 [ 25 янв 2021, 15:40 ] | |
Заголовок сообщения: | b250a-btc v20 no voltage cpu |
Hi i hav problem with cpu voltage without cpu voltage is 0.900 v with cpu 0 ..I flash bios from site and i notice signal on pwm controller rt3606bc en 3.3 but VR eady is only 0.9 v i think should be 3.3 v ..What more i can test?Thanks |
Sokol78 [ 25 янв 2021, 23:18 ] | |
Заголовок сообщения: | Re: b250a-btc v20 no voltage cpu |
I think PGOOD (pin 2) should not be 3,3V, it is pulled up to something like VCCSA=1.05V through divider, so 0.9 V is normal in this case. Check the voltage at pin 44, 30, 52. Are you sure your CPU works well and compatible? How about the socket? Look at it through a microscope! |
alex68q [ 25 янв 2021, 23:48 ] | |
Похожая схема MS-7A74 есть в : viewtopic.php?f=239&t=346&p=496267&hilit=%2AMS+7A74%2A#p496267 , VRM_PGD_R подтянут через 1ком к VCCSA . |
bokin021 [ 26 янв 2021, 10:32 ] | |
Cpu is ok support board also socket is ok no pins are damage or bad position..When cpu is removed voltage are 0.8v wirh cpu is 0V ..I did not understand what voltage should be on vready.. |
aleksros [ 26 янв 2021, 11:09 ] | |
bokin021 flash bios check for broken smd elements change hub |
bokin021 [ 26 янв 2021, 16:46 ] | |
On hab coming 1.1v does not get worm..No brocken smd at all i have check well..Maybe can be damage pwr contropler for cpu..I will resarch more.. |
bokin021 [ 27 янв 2021, 13:08 ] | |
44 3.190 v 30 1.1 v 52 12 v |
Sokol78 [ 27 янв 2021, 13:37 ] | |
bokin021 писал(а): 44 3.190 v 30 1.1 v 52 12 v Is that without CPU or with CPU? |
bokin021 [ 27 янв 2021, 13:54 ] | |
with cpu |
Sokol78 [ 27 янв 2021, 14:10 ] | |
Pin 30 is VCC, it should be 5V! Otherwise PWM controller will not start working! Try to find out where it came from! Have you got the scheme you were told about above? |
bokin021 [ 28 янв 2021, 15:14 ] | |
i have change 2.2 ohm resistor 5 v it is but no cpu voltage |
Sokol78 [ 29 янв 2021, 15:32 ] | |
May be on your motherboard somewhere is two pin jumper for starting without CPU? And you can start the motherboard without CPU only when this two pin closed? So, in order to start the motherboard with CPU you need to disconnect them! |
bokin021 [ 29 янв 2021, 16:05 ] | |
no this jumper but when i remove cpu voltage is 0.9v |
