winfast PC761GXM2MA-RS2 no vídeo https://vlab.su/viewtopic.php?f=44&t=15155 |
eletmoraes [ 25 авг 2013, 21:01 ] | |
Заголовок сообщения: | winfast PC761GXM2MA-RS2 no vídeo |
code information (- 00) on board diagnosis. Processor OK . Tested mosfet transistors in the processor back and found no shorted. Normal stress in the memories. Tested voltage vcore , measured 1.08v should not take 1.3 to 1.4v? The processor used is an AMD 64X2 Chip North Bridge normal heating Chip South unheated If the correct voltage Vcore is 1.3V can be that the electrolytic capacitors that feed the Vcore MOSFETs are changed. |
Haik [ 20 сен 2013, 13:28 ] | |
Заголовок сообщения: | Re: winfast PC761GXM2MA-RS2 no vídeo |
What South bridge used in this mb? I can't find this motherboard in google. |
