Текущее время: 26 июн 2024, 15:16
Внимание! Скачивание вложения в этом разделе стоит 10 Баллов.
Attention! Cost for attachment in this forum is 10 Points.
 Заголовок сообщения: connect the matrix N156B6-L3D in place of N156B6-L08.
СообщениеДобавлено: 23 сен 2013, 22:15
Looking scheme to N156B6-L3D
Looking for a way to connect the matrix N156B6-L3D in place of N156B6-L08.
My laptop do not support 3D and 2-channel LVDS.
Do you have any ideas use 3D matrix in place of the normal?
 Заголовок сообщения: Re: connect the matrix N156B6-L3D in place of N156B6-L08.
СообщениеДобавлено: 24 сен 2013, 00:56
here is schame for this panel
hope it can help
all can be fixed
СообщениеДобавлено: 24 сен 2013, 01:27
Thank You Dimension
I do not have 15 messages :-(
Do you have any ideas use 3D matrix ( N156B6-L3D ) in place of the normal (N156B6-L08) ?
СообщениеДобавлено: 24 сен 2013, 10:23
so sorry i dont know how to do that
never try to do that yet
all can be fixed
СообщениеДобавлено: 24 сен 2013, 19:11
I understand. Unfortunately, I have no choice I have to find method.
Now I change the colors in sequence.
The first time was all white
СообщениеДобавлено: 24 сен 2013, 19:36
Заблокирован
Possible interchangeable items matrices 15.6 Notebook
N156B3-L0BVer.1.0
N156B6-L03
N156B6-L04
N156B3-L0B
N156B3-L04
N156B3-L01
N156B3-L02
N156B6-L04Rev.C1
N156B6-L05
N156B6-L08Rev.C1
N156B6-L0A
N156B6-L0B
N156B6-L08
N156B6-L07
N156B6-L06
N156B6-L06Rev.C1
LTN156AT10
LTN156AT09
LTN156AT01
LTN156AT02
LTN156AT02-A01
LT141X2-156
LP156WH3(TL)(L2)
LP156WH3(TL)(B1)
LP156WH3(TL)(L1)
LTN156AT03
LTN156AT05
LTN156AT07-A01
LTN156AT08
LTN156AT07
LTN156AT06-A01
LTN156AT05-H01
LTN156AT06
N156B6-L0BVer.1.0
N156B6-L0BVer.2.0
N156O6-L01
N156O6-L02
N156O6-L0D
N156B6-L3D
N156B6-L0I
N156B6-L0BVer.3.0
N156B6-L0D
N156O6-L0DRev.C1
LP156WH3(TL)(A3)
LP156WH3(TL)(A2)
BT156GW02
BT156GW02V.0
CLAA156WA01
BT156GW01V.A
BT156GW01V.4
BT156GW01
BT156GW01V.1
CLAA156WA01A
CLAA156WA11
LP156WD1(TL)(A2)
LP156WD1(TL)(B2)
LP156WD1(TL)(B3)
LP156WD1(TL)(A1)
CLAA156WB11A
CLAA156WA11A
CLAA156WB11
B156XW04V.0
B156XW03V.2
B156XW01
B156XW01V.0
B156XW01V.1
B156RW01V.1
B156RW01V.0
B156HW01V.5
B156RW01
B156XW01V.2
B156XW02
B156XW03V.0
B156XW03V.1
B156XW02V.3
B156XW02V.2
«Кто владеет информацией - тот владеет миром»
СообщениеДобавлено: 24 сен 2013, 20:16
I understand.
The first time was all white.
Now I change EDID N156B6-L08 is the matrix N156B6-L3D the colors in sequence ( white, blue, red and so on ).
Why? How have to do to work normally?
СообщениеДобавлено: 24 сен 2013, 20:41
Заблокирован
check train to T-con and the presence of LVDS signals
---------- Добавлено спустя 17 минут 53 секунды: ----------
- factory test mode
no signal from the video chip
---------- Добавлено спустя 2 минуты 54 секунды: ----------
you have a monitor or laptop? :du_ma_et:
СообщениеДобавлено: 24 сен 2013, 21:17
I have a Acer laptop.
Laptop Motherboard JM31 is version 2.0
The presence LVDS signals checked using an oscilloscope.
They are all.
Do not have waveforms to compare with the standard.
How check train to T-Con ?
PS. Excuse me but I have the possibility of the presence of writing once an hour
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. N156B6-L3D rev:C1 ищу прошивку
в форуме Ремонт ноутбуков | Laptop Repair
apollo
19 сен 2015, 22:29
apollo Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sanyo TV FW55C46F with white vetical lines same place and image exists
amkwca
01 май 2022, 23:11
amkwca Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Куплю матрицу на ноутбук 15.6 N156b6 или LTN156at17 и т.д.
в форуме Куплю | Buy
Звук
18 мар 2015, 02:22
DrScreW Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Матрица N156B6-L0B Rev. C3
LEX38RUS
28 окт 2015, 14:36
LEX38RUS Перейти к последнему сообщению
