FSP240-50SBV https://vlab.su/viewtopic.php?f=46&t=127412 |
dvarius [ 18 июл 2022, 22:46 ] | |
Заголовок сообщения: | FSP240-50SBV |
Hi, maybe someone had this problem. Standby burned: Tny277pn, and resistor R26 (i can't figure out value). But if I add R26 0R, and tny277 I gel standby voltage. If i try to start psu (green+black) it just spins cooler a little and that just it... Output low voltage's. If I try in mainboard it burns standby again. Thank you for any help. |
grrepa12 [ 12 сен 2022, 14:51 ] | |
Заголовок сообщения: | Re: FSP240-50SBV |
Sounds like there is still a shorted rail on the PSU. These are also known for bad capacitors. I don't think it is worth repair. |
