Toughpower Grand RGB 1200W Platinum SHORT-CIRCUIT https://vlab.su/viewtopic.php?f=46&t=137893 |
PT-AH [ 24 окт 2023, 20:26 ] | |
Заголовок сообщения: | Toughpower Grand RGB 1200W Platinum SHORT-CIRCUIT |
I found a damaged circuit, which broke the following components: UBIQ QM3054D B06N03 APW7159C However, now it says that it is not in a short circuit, but as soon as it turns on, it immediately turns off as protection. Can anyone help me check the circuit? PS_ON only tests with 2.64V. |
Radio2865 [ 25 окт 2023, 09:20 ] | |
Заголовок сообщения: | Re: Toughpower Grand RGB 1200W Platinum SHORT-CIRCUIT |
first you need to properly design the topic according to the topic design rules, you need to describe the composition of the power supply |
