need some help for ati cards with memory errors for making script https://vlab.su/viewtopic.php?f=48&t=100822 |
Страница 16 из 56 |
anton127 [ 02 дек 2020, 06:28 ] | |
Заголовок сообщения: | Re: need some help for ati cards with memory errors for making script |
У меня почему-то dmgg перестал работать. Проверял и в арчлинукс и в убунту. После запуска команды комп зависает и перезагружается. |
pEEp [ 02 дек 2020, 10:24 ] | |
anton127 У меня такое было (или похожее) - попробуйте пересоздать флешку. Мне помогло. |
nipp [ 02 дек 2020, 12:18 ] | |
Запустил тестовый стенд на встроенном видео, теперь сыплет ошибками по всем банкам. |
ilie321 [ 02 дек 2020, 15:15 ] | |
If driver it is loaded ok (good card) you can't test with dmgg. Also embedded card can't be tested. In first test with 7/or8 was an old version of dmgg you need to run the last one you have used in your last post for rx5xx rx4xx and post results. |
uncledim [ 02 дек 2020, 15:30 ] | |
ilie321 писал(а): If driver it is loaded ok (good card) you can't test with dmgg but after running "memfa" it becomes possible to test with dmgg. "lspci" output differs before and after memfa test - attribute "disabled" disappears and vram window seems become accessible. |
pEEp [ 02 дек 2020, 17:14 ] | |
ilie321 For statistics: Sapphire R9 390 Nitro 8GB (vertical memory artifacts). New dmgg identified 6 and 8 banks (8 bank had more errors) - after reballing of 8 bank VC has been started w/o artifacts. Q: the new dmgg can now identify a specific bank for 300 series? |
ilie321 [ 02 дек 2020, 21:20 ] | |
For 390 is detected by chip directly |
kripto.emre [ 02 дек 2020, 23:50 ] | |
tserver test How will we prepare somehow it didn't work |
darker123 [ 03 дек 2020, 03:15 ] | |
Вложение: Capture.PNG I want to report my results with the latest dmgg script.I have received a card Power Color RX 580 8GB. When card is installed as primary display it displayed no video. If booted to windows as secondary adapter, it showed error 43 on the card... I have ran it thru dmgg under Linux latest script, see results attached. It reported memory chip 3 & 4 with errors. What i next is heated these 2 modules on soldering station and floated them on balls. After that I ran script again with 0 errors. Since I didn't remove the modules I can't tell unfortunately which module was originally defective 3 or 4. In any case thank you for the script the latest improvements are great!@ |
ilie321 [ 03 дек 2020, 23:13 ] | |
I thanks to @galkinvv for his great idea . I just edited his work |
kripto.emre [ 04 дек 2020, 00:35 ] | |
Can you share the program and how to use it |
ilie321 [ 04 дек 2020, 14:10 ] | |
What program? |
westcoast [ 04 дек 2020, 21:39 ] | |
darker123 писал(а): I have ran it thru dmgg under Linux latest script, see results attached. It reported memory chip 3 & 4 with errors. What i next is heated these 2 modules on soldering station and floated them on balls. After that I ran script again with 0 errors. do you think the heating fixed the defect inside actual chip, or there was bad BGA contact/short between balls? |
kripto.emre [ 04 дек 2020, 22:29 ] | |
ilie321 tserver |
ilie321 [ 05 дек 2020, 09:37 ] | |
Check posts in the back i have links for 16gb usb or hdd |
anton127 [ 05 дек 2020, 13:19 ] | |
Завелся DMGG на убунту, без зависаний. Там, где MEMFA показывает ошибки по 1 каналу, DMGG показывает всё хорошо. После нескольких перезагрузок - ошибки по всем каналам в DMGG. |
uncledim [ 05 дек 2020, 17:48 ] | |
anton127 писал(а): Там, где MEMFA показывает ошибки по 1 каналу, DMGG показывает всё хорошо. а первый этап memfa что показывает? они по виду вроде одинаковые с dmgg |
obli [ 05 дек 2020, 21:49 ] | |
Подскажите сегодня решил потестировать жутко артефактную карту, картинка ток в биосе , посе загрузки любой ос черный экран (дос не пробовал) после загрузки со встроенной карточке , с usb1804v2.pmf ,выдает Possible gpu address <unassigned> lspci -v выдало Вложение: 20201205_124640.jpg я так понимаю что gpu капут ? Или вся память ? |
anton127 [ 06 дек 2020, 05:50 ] | |
uncledim Да, там 2 теста проходит. На первом ошибок нет, на втором по одной банке. Банка перекатана - карта работает. ---------- Добавлено спустя 2 минуты: ---------- obli писал(а): Или вся память ? А что там с питанием памяти?? |
ilie321 [ 06 дек 2020, 10:47 ] | |
Take care when compare dmgg with tserver results. Tserver is not BACD order it is ABCD as in Chinese pdf explained. For example A1 from tserver means chip 2 |
uncledim [ 06 дек 2020, 11:07 ] | |
ilie321 писал(а): Tserver is not BACD order ??? https://c.radikal.ru/c27/2010/84/f3f345cb1853.jpg its exactly BACD btw, why limit testing size to 256M in latest dmgg? On some systems its possible to test all of VRAM |
uncledim [ 06 дек 2020, 16:28 ] | |
Новомодная технология от AMD - Smart Access Memory - на немолодой интеловской системе с немолодой же rx550)) мать asus на H97, в биосе включено above 4G decoding проц без встройки, отсюда 509 ошибок при тестировании |
ilie321 [ 06 дек 2020, 18:08 ] | |
uncledim писал(а): According to the chinese pdf it is abcd: Вложение: Screenshot_20201205-175906_Opera.jpg And i tested that with gas_man. Tserver give A1 and dmgg chip2. If it is abcd A1 =chip2. He just reball chip2 and card it is working now I have limit to 256MB because when driver fails only 256mb are loaded and if you put more it is stuck in loop and need hard reset . If the card it is good than yes you can test all memory but for that you have windows tools much better. But if is needed i can remove this or anyone can search in script and replace 256 with 10000 for example |
uncledim [ 06 дек 2020, 18:30 ] | |
ilie321 писал(а): According to the chinese pdf it is abcd: I see. IMHO rather an error in pdf's picture, than in tserver tserver outputs lines in chip's physical (edited:) logical order, but named them by channels: ChB0, ChB1, ChA0, ChA1, ChC0, ChC1, ChD0, ChD1 |
aleksros [ 06 дек 2020, 19:16 ] | |
There is no mistake. The physical location of the memory banks is as ilie321 wrote, i.e. ABCD, but the tserver displays them in a different BACD order. This must be taken into account when changing memory banks. |
uncledim [ 06 дек 2020, 21:12 ] | |
aleksros писал(а): There is no mistake. ошибка у меня), в терминах заплутал tserver выводит в логическом, не физическом порядке. т.е. в порядке возрастания адресов (он же порядок отображения на дисплее) тогда всё сходится, никаких противоречий ща поправлю пред. пост |
darker123 [ 07 дек 2020, 19:11 ] | |
westcoast писал(а): do you think the heating fixed the defect inside actual chip, or there was bad BGA contact/short between balls? I do not believe direct heating fixed the defect inside the chip, I believe it was a bad BGA contact under the chip. The card was cheap and didn't have any thermal pads or heatsink on top of it. ---------- Добавлено спустя 1 час 37 минут 2 секунды: ---------- Кто нибудь видел такую проблему чтобы артефакты на экране были на пол канала на каждом канале??? карта XFX RX 580 GTS 8gb |
galkinvv [ 07 дек 2020, 23:10 ] | |
darker123 писал(а): Кто нибудь видел такую проблему чтобы артефакты на экране были на пол канала на каждом канале??? Какое разрешение передаётся с видяхи на моник у монитора в момент когда сделано фото? На AMD до активации ускорения драйвера - каждая микросхема памяти обслуживает 64 вертикальных линии, соответственно каждый канал - 128 вертикальных линий. После активации - разбиение уже идёт не по линиям, а по квадратам. Каждая микросххема памяти начинает осблуживать свой набор квадратиков 8x8. |
darker123 [ 08 дек 2020, 02:54 ] | |
galkinvv писал(а): Какое разрешение передаётся с видяхи на моник у монитора в момент когда сделано фото? Pазрешение с видяхи на моник 1080P.. Что Это MoжeT быть? Memory или GPU? |
uncledim [ 08 дек 2020, 09:20 ] | |
darker123 писал(а): 1080P. а выглядит как 2560х1440 с отвалом в канале А что говорит dmgg? (только возьмите свежий, с конца 13й страницы темы) |
Страница 16 из 56 | Часовой пояс: UTC + 4 часа |
