Текущее время: 21 ноя 2024, 19:41
 Заголовок сообщения: RX 6900 XT AORUS MASTER NO VIDEO  [РЕШЕНО]
СообщениеДобавлено: 06 апр 2023, 15:06
Hello everyone!
The graphics card did not give video, I measure voltages and everything is ok, I see a slight ripple on the PCB on the PCI side. Due to the weight of these graphics, the memory chips tend to detach from the pcb, so I do a memory test, it gives me an error in memory E0 and E1, I replace memory D0, D1 and E0, E1 to make sure. I connect the graph and it gives video, I pass the furmark test, everything is ok. I put the graphics card to sleep with a youtube video in the background and it freezes and blue screen with artifacts, restarts and works again. I turn off the pc I turn on again and it no longer gives video.
I pass the memory test again and according to the test all the memories are ok. I don't know what else to look at. Any ideas?
thanks.
 Заголовок сообщения: Re: RX 6900 XT AORUS MASTER NO VIDEO
СообщениеДобавлено: 06 апр 2023, 21:07
surn32 писал(а):
Hello everyone!
thanks.
Hello. First of all which memory software u used to test memories? memtune? how did you move the memtune files to the R69XT folder?
Did you reball the memories or replace the memories with new?
СообщениеДобавлено: 07 апр 2023, 14:12
ll_r1d0_ll писал(а):
Hola. En primer lugar, ¿qué software de memoria usaste para probar las memorias? memtune? ¿Cómo moviste los archivos de Memtune a la carpeta R69XT?
¿Renovaste los recuerdos o reemplazaste los recuerdos con nuevos?
Yes, with memtune, the gigabyte tool, the file is hidden now I don't remember which folder it was in but to find it, I mounted an image with ubuntu desktop, inserted the hard drive with the gigabyte tool and started searching, then started again the gigabyte tool and I went into the R69XT folder and put the command "cp (here file path) . " example " cp /mnt/atidiag/memtune ." and it is copied to the folder in which you are.
The memories are from a R68XT of the same brand that work correctly.
---------- Добавлено спустя 1 час 15 минут 51 секунду: ----------
SOLVED: The previous technician who tried to repair it changed the bios and had a different one.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte Z390 Aorus Master нет питания видеоядрa
в форуме Gigabyte
RandomR
2990
25 фев 2022, 13:52
RandomR Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. IR35201 нужен дамп под Gigabyte Z390 Aorus Master или любую МП схожую
gehka3
13 янв 2024, 11:01
nmv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gigabyte aorus master x570 выключается
в форуме Gigabyte
burda11b
1579
30 ноя 2022, 02:36
alex68q Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. AORUS GeForce RTX 3070 MASTER 8G помогите опознать номинал сбитого элемента.
dubstep11
26 май 2023, 12:06
gehka3 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte XT 6800 XT Aorus Master VBIOS
bd250
12 окт 2023, 22:37
bd250 Перейти к последнему сообщению
Сейчас этот форум просматривают: madking, razoramd, вовико2 и гости: 58
