Текущее время: 22 ноя 2024, 09:29
 Заголовок сообщения: Gigabyte GTX 3060Ti Vision Memories swap problem  [РЕШЕНО]
СообщениеДобавлено: 15 авг 2023, 17:46
Hello everyone. I got Gigabyte 3060ti vision from the customer which was giving garbage since it had HYNIX memory. I replace all the memories to Samsung and changed the straps according to samsung. Now the GPU detects and works perfectly in Secondary Gpu. But not giving any display from HDMI or DP Ports. What could be the issue ? The card was sealed and display was coming from all Display ports before changing memory. All the bios come with samsung support . I did not flash any bios yet but I dont think it could be the problem because all the bios come with Samaung memory support and same Display ports configuration . Any guide or idea ? Please let me know thank you
 Заголовок сообщения: Re: Gigabyte GTX 3060Ti Vision Memories swap problem
СообщениеДобавлено: 15 авг 2023, 22:08
Gpu-z screenshot.
There is also a vga straps, which you could have accidently moved.
СообщениеДобавлено: 16 авг 2023, 12:29
You need test the card with mats use this commands connect the card secondary after mats commands ./mods gputest.jse -skip_rm_state_init -oqa after ./mats -n 1 -e 5 after share results report.txt
before double check the all strap resistor perfectly soldered
СообщениеДобавлено: 17 авг 2023, 20:26
ayobisinen писал(а):
Gpu-z screenshot.
Hello I have changed only straps according to attached in picture. I have tried both 8GB Configuration. Card is detected as secondary only with 0000 Configuration and test passes perfectly even furmark and heaven benchmark. Can you please show me what combination is for VGA Please? I have attached picture of it. Please let me know if there is any mistake. That would be great.
EmirhanDonanimOfis писал(а):
Posted: Yesterday, 13:29
I have checked multiple times the test PASSES.
Вложение:
Вложение:
Вложение:
Вложение:
СообщениеДобавлено: 17 авг 2023, 22:11
One strap resistor is missing.
СообщениеДобавлено: 20 авг 2023, 23:33
Hi. I fixed it. The resistor was of STRAP 3 was also moved to 0 . Later I switched it back to its original position and picture came. Now its working fine :D Thanks for the advice. I could not do anything without you VGA STRAP Statement. Thanks again.
В этой теме нет новых непрочитанных сообщений. 11.3 Volts at the coil exit corresponding to the VRAM memories //GTX 1650 4GB GDDR5 GV-N1650OC-4GD ,
azzed
15 сен 2022, 01:50
В этой теме нет новых непрочитанных сообщений. MSI GTX 970 - memory swap to another company
Micchaleq
1981
30 сен 2021, 14:04
den800 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. EVGA GTX1060 - no tension of memories
TheMArcos
26 июл 2020, 21:38
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RX VEGA 56 STRIX = no power to the HMB2's memories
PT-AH
27 май 2022, 18:52
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3060 Zotac : 1v8 voltage on memories.
azzed
28 сен 2022, 13:09
uncledim Перейти к последнему сообщению
Сейчас этот форум просматривают: ruzalit, Size и гости: 105
