ayobisinen писал(а):
Gpu-z screenshot.
There is also a vga straps, which you could have accidently moved.
Hello I have changed only straps according to attached in picture. I have tried both 8GB Configuration. Card is detected as secondary only with 0000 Configuration and test passes perfectly even furmark and heaven benchmark. Can you please show me what combination is for VGA Please? I have attached picture of it. Please let me know if there is any mistake. That would be great.
EmirhanDonanimOfis писал(а):
Posted: Yesterday, 13:29
You need test the card with mats use this commands connect the card secondary after mats commands ./mods gputest.jse -skip_rm_state_init -oqa after ./mats -n 1 -e 5 after share results report.txt
before double check the all strap resistor perfectly soldered
I have checked multiple times the test PASSES.
