Текущее время: 23 май 2024, 07:41
dennis85
Заголовок сообщения: Re: help in identifying this vga Добавлено: 22 апр 2020, 06:35 |
Зарегистрирован: 20 сен 2012, 23:43 Наличности на руках: 806.60
Сообщения: 418 Откуда: Ukraine
TheMArcos писал(а): did I end up damaging the gpu? For determinate it, need looks on the maximum VRM voltage / core temperature. If they were not critically increased, the probability of a GPU malfunctioning as a result of manipulating with BIOS, I think, is unlikely. Maybe it just coincided. Try warming the chip to 150-160 degrees(without power!) and see if its behavior changes.
_________________ Главный враг истины не отсутствие знания, а иллюзия знания.
TheMArcos
Заголовок сообщения: Re: help in identifying this vga Добавлено: 23 апр 2020, 00:50 |
Зарегистрирован: 18 мар 2020, 04:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
dennis85 писал(а): or determinate it, need looks on the maximum VRM voltage / core temperature. so, the vcore is 0.976v and I believe it hasn’t heated up, because when she gave the video it was with the heatsink, I would try to heat the chip according to your suggestion, and without results. unfortunately.
