Текущее время: 22 ноя 2024, 08:06
 Заголовок сообщения: EVGA GTX1060 - no tension of memories
СообщениеДобавлено: 25 июл 2020, 20:29
Hello! could someone help me identify this Ci? I have this card, all voltages go up except the memory, in this ci I only have 5v and 1 of the pins, I didn't find the data sheet to evaluate the pinout.
 Заголовок сообщения: Re: EVGA GTX1060 - no tension of memories
СообщениеДобавлено: 25 июл 2020, 21:26
https://www.ebay.com/itm/253001740454
---------- Добавлено спустя 1 минуту 41 секунду: ----------
https://www.alldatasheet.com/datasheet- ... 8DSCR.html
СообщениеДобавлено: 26 июл 2020, 19:45
Thanks madking, it helped a lot, I noticed that the card shows intermittent behavior, if you leave it a few minutes off the motherboard and then plug it in again it will turn on normally and works until it is turned off (passes all stress tests ), but when it doesn’t turn on all the voltages go up less than the memory, and only the 5v appears on pin 7, seem to enable and without PGOOD (which by the datasheeet is connected directly to the 5 volts) has anyone been through this and has any tips for give me? I was unable to identify where the enable comes from with the multimeter continuity test.
СообщениеДобавлено: 26 июл 2020, 20:10
I do not really understand, PGOOD is present or not, when there is 5V
СообщениеДобавлено: 26 июл 2020, 21:38
sorry if I wasn't clear, there are 2 situations:
1- the card turns on normally and works until the pc is turned off, in case I turn it off and try to rewire the card, no more video and the memory voltage does not appear.
2-the card does not open video, has no memory voltage, and in the pinouts of the TPS51218 there is only 5v on pin 7.
when I remove the card from the motherboard, after a few minutes and reconnect the voltages rise and the video card
В этой теме нет новых непрочитанных сообщений. RX VEGA 56 STRIX = no power to the HMB2's memories
PT-AH
27 май 2022, 18:52
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 11.3 Volts at the coil exit corresponding to the VRAM memories //GTX 1650 4GB GDDR5 GV-N1650OC-4GD ,
azzed
15 сен 2022, 01:50
В этой теме нет новых непрочитанных сообщений. RTX 3060 Zotac : 1v8 voltage on memories.
azzed
28 сен 2022, 13:09
uncledim Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte GTX 3060Ti Vision Memories swap problem
ll_r1d0_ll
20 авг 2023, 23:33
ll_r1d0_ll Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. EVGA GTX1060 3Gb SC сбитый транзюк
Black_Alone
20
6139
27 окт 2018, 17:45
Black_Alone Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 89
