Текущее время: 08 июн 2024, 04:18
Pandemonium6
Заголовок сообщения: Sapphire Nitro+ rx580 strange problem Добавлено: 01 ноя 2021, 12:43 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
Всем привет,
There is Sapphire Nitro+ rx580 for repair. I have already brought it back to life. There was a shorted (KZ) ceramic capacitor, nothing special, PEX power was missing. But this card reports 83% of memory controller utilization. When memory clock is set to its default 2000MHz there is 83% but when I increase it even by 1MHz the memory controller utilization drops to 60-70%, when I decrease MHz there is no change to the certain point and it starts increasing to 91%. This card works normally, Furmark passes, this card can mine but slowly up to 22.5Mh and the hash rate reported by pool is lower. All VRMs work and have proper scope shapes, everything looks good but this card does nor want to eat power and des not want to work faster. GPU frequency and power limit work and only the memory clock does not react properly when adjusted in afterburner. I reflashed bios several times and this is not the bios issue.
PWM controller NCP81022
What could happen to this card?
