Текущее время: 02 июн 2024, 14:56
amkwca
Заголовок сообщения: Re: Short at pci e 12 volt line Добавлено: 19 дек 2021, 23:58 |
Зарегистрирован: 17 дек 2021, 09:54 Наличности на руках: 44.00
Сообщения: 24 Откуда: canada
Do u think it could be mosfets or vram? I have all volts are fine. I think a little bit less than normal. vcore exits as 0.7 and crystal heats up takes few seconds longer than normal to heat up. also I have vram 0.7v. I'm missing only the 12v of pci-e. do u think it maybe a bad capacitor only? or this drop in vcore and vram volts from 0.9 to 0.7 reflects something? I'll do pictures for both side. Thanks you for your reply Posted after 1 hour 1 minute 50 seconds:https://drive.google.com/file/d/1ZbLHuj ... p=drivesdkhttps://drive.google.com/file/d/1Z_hKkV ... p=drivesdk Posted after 1 hour 22 minutes 17 seconds:checked capacitor under microscope, doesn't show any one damage. don't have a thermal cam. somebody can advice
amkwca
Заголовок сообщения: Re: Short at pci e 12 volt line Добавлено: 22 дек 2021, 00:39 |
I checked the fuse is good now. I've the 12v pci e now which I didn't have before, no short on line, I justed replaced one mosfet and I didn't replace the driver yet. I'm having the volts, 12v main, 5 volts, 12 pci e and 3.3v. I'm missing the 1.8v and the rest following pex, vcore, vram and v ram controller. what surprised me I was missing only the 12v pci-e and I had the rest but they had a little bit drop like 0.7v on vcore. when I changed the mosfet, I'm getting no 1.8v which is so wired. by the way, I followed the GS7103 I've vcc and vin and I'm missing en and 1.8 vout. so my problem is missing 1.8v_en now. npn transitors giving the signal they are good. I'm trying to follow that signal back. I'll send photos when I go home
Pandemonium6
Заголовок сообщения: Re: Short at pci e 12 volt line Добавлено: 23 дек 2021, 08:14 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
Such situation should not have happened. You lost 1.8V after replacing mosfet. amkwca писал(а): I've an update, I found short mosfet as you adviced. Which mosfet did you replace? Can you post an image with a new mosfet?
