Текущее время: 22 июн 2024, 00:03
Страница 1 из 1 [ Сообщений: 2 ] |
dani82
Заголовок сообщения: Zotac GTX 970 4GB "please power down and connect..." ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 08 янв 2022, 21:58 |
Зарегистрирован: 05 авг 2021, 23:40 Наличности на руках: 60.18 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 29 Откуда: Indonesia
Hello, Zotac GTX 970 4GB DualFan Standart, the problem card start up with "please power down and connect..." No short at any coil, n power all look fine. No problem with powersupply and cable. Sometimes card can boot normal, tes benchmark normal too, but mostly stuck with "please power down and connect..." Try to flash bios with other, at many time, change bios ic, but same result Try to change ina3221, and no result. Still please power down and connect...
i am out of any more ideas, Please advice me where to look the problem, which component responsible to this problem Thank you for your help
![](images/spacer.gif) |
