Hello.
There is a video card XFX 580 8gb.
After installation and inclusion on the screen of the monitor of a strip. Which change depending on the screen resolution.
After loading Windows, there are five vertical bars. The interesting thing is that if you take a screenshot, then there are no stripes on the screenshot. The driver cannot be installed, because when loading Windows, a "Blue Screen" occurs and a reboot follows.
Has anyone else experienced something similar, what could it be?
And is it possible to fix it. Memory K4G80325FB-HC25. Eight pieces. 7 pieces of samsung 743 and one 640.
Here are pictures and videos of anomalies on the screen.
https://wdfiles.ru/folder/10227/XFX_580_8gig Thanks in advance.
Its simply Memory Error. You can run Tserver to find which bank is faulty. As long as the part number is "K4G80325FB-HC25", it will work.
