need some help for ati cards with memory errors for making script https://vlab.su/viewtopic.php?f=48&t=100822 |
Страница 43 из 56 |
ilie321 [ 26 янв 2022, 22:14 ] | |
Заголовок сообщения: | Re: need some help for ati cards with memory errors for making script |
sshana писал(а): Hello, sorry if this have been asked before, Is it possible to test an AMD card (Rx 580 to be exact) in secondary mode? there's no image on this card Using iGPU (Intel) or another card as primary? If possible, what is needed? Thanks! If you read topic you will find that is very possible. Easiest is to have nvidia to see image. |
sshana [ 27 янв 2022, 06:56 ] | |
ilie321 писал(а): If you read topic you will find that is very possible. Easiest is to have nvidia to see image. Yeah, that did the trick, thank you. Fixed the 580, now having a weird problem with another cards What could it be, GPU? |
Pandemonium6 [ 27 янв 2022, 07:17 ] | |
Try to read my topic: viewtopic.php?f=48&t=121800 |
lovaK [ 27 янв 2022, 17:51 ] | |
TcoreSilicontarget: Failed to load ME microcode using toollib on Tonga/Ellesmere RF Было у меня на RX460. Думал, что проблема в GPU. Снимал его, отреболил, поставил обратно - ничего не изменилось. Оказалось, что на карте сдохла вся память и флешка vBIOS. После замены все заработало. |
StayeR [ 28 янв 2022, 08:05 ] | |
sshana писал(а): now having a weird problem with another cards Hello! There were such errors when replacing all the memory, and there were no soldered contacts. There was such a bug in TServer. Rescued script DMGG which showed on which channels the problem. After re-soldering - everything worked. Check it. And look at the state of the crystal on the chip for cracks and chips in the corners. I met the same error on chips with a damaged crystal. |
motohomiak [ 29 янв 2022, 23:08 ] | |
Приветствую, подскажите какой командой задать частоту гпу, чтоб не стоковая была, а например 1300? |
Pandemonium6 [ 29 янв 2022, 23:18 ] | |
viewtopic.php?f=48&t=100822&start=1050 |
cxav [ 30 янв 2022, 12:47 ] | |
Hi, can someone share the mhdt.tar.gz here ? Thanks you https://www.chinafix.com/thread-1299855-1-1.html Привет, может кто-нибудь поделиться mhdt.tar.gz здесь? Спасибо |
motohomiak [ 30 янв 2022, 17:39 ] | |
Pandemonium6 писал(а): viewtopic.php?f=48&t=100822&start=1050 Спасибо, мил человек! |
Pandemonium6 [ 30 янв 2022, 23:37 ] | |
So you could click "Thank you" button |
Sinchuk [ 03 фев 2022, 14:29 ] | |
Crimfell писал(а): то просто восстановите образ usb1804v3.pmf при помощи diskgenius. По крайней мере у меня все работает и без boot-repair-disk-64bit. Я на флешку все воcстановил, но с нее не грузится комп, постоянная перезагрузка... что я не так делаю ? |
submitred [ 06 фев 2022, 15:34 ] | |
Ребят, подскажите как сделать полный тест всей памяти? Переделал с 4гб на 8гб. Карта пару дней отработала в майнинге нормально. Сейчас после 10мин работы отваливается. Проверил стандартный тест ./tserver -boardtest=memfa, ошибок нет. Частоту увеличивал до 2100, всё в норме. |
Gas_man [ 07 фев 2022, 09:03 ] | |
submitred писал(а): Ребят, подскажите Сделай свой скрипт и пропиши там тесты -test=ak600.001 и т.п. Вот я такой текст скрипта использую: rm -f memfa.log ./agt -pplist=short read -p "Select the test Mode = " mod echo "Mode select =" $mod sleep 5 ./agt -ppmode=$mod ./agt -fancontrol=2 ./tserver -d=gpu.* -test=ak600.001 sleep 1 ./tserver -d=gpu.* -test=ak403.001 sleep 1 ./tserver -d=gpu.* -test=ak403.003 sleep 1 ./tserver -d=gpu.* -test=ak401.001 sleep 1 ./tserver -d=gpu.* -test=ak010.001 sleep 1 ./tserver -d=gpu.* -test=ak311.007 sleep 1 ./agt -clkstatus sleep 3 nano memfa.log назвал его test.sh закинул в папку с rx470 и запускаю ./test.sh У меня было 2 такие карты. ошибки по каналам полезли уже на тесте ak403.001 |
cxav [ 08 фев 2022, 02:34 ] | |
Hi, is there any tserver for AMD RX6x00 cards ? Привет, есть ли tserver для карт AMD RX6x00? |
DmitriyDDD [ 12 фев 2022, 17:55 ] | |
Sinchuk писал(а): Я на флешку все воcстановил, но с нее не грузится комп, постоянная перезагрузка... что я не так делаю ? не каждая версия diskgenius корректно создает флешку из образа. нужно после залития или флешку восстанавливать с помощью boot-repair-disk-64bit или "правильную" версию diskgenius У меня версия 5.4.2.1239 она правильно создает флешку |
MisterAlex [ 12 фев 2022, 20:37 ] | |
Gas_man писал(а): MisterAlex писал(а): Подскажите пожалуйста ./tserver -d [отображает список карт] ./tserver -d = 1 [порядок может быть другим] ./tserver -d = 0 [порядок может быть другим] Не хочет ничего показывать . Я так понимаю последовательность такая , заходим в интересующую папку с модом и вводим ./tserver -d . Правильно понимаю ? |
Gas_man [ 13 фев 2022, 11:52 ] | |
MisterAlex писал(а): Не хочет ничего показывать . Я так понимаю последовательность такая , заходим в интересующую папку с модом и вводим ./tserver -d . Правильно понимаю ? Зачем? Если у вас в тесте одна карта - она автоматом определяется, если у нее нет каких-то других проблем, кроме памяти. ./tserver -d - нужно тогда, когда у вас материнка без поддержки встроенной графики и вы используете в качестве первичной карту АМД, тогда есть смысл использование команды выбора карты |
olegshepeta [ 16 фев 2022, 18:35 ] | |
Подскажите люди с опытом Есть MSI rx 480 4 Gb (ошибка 43 при запуске на встройке, невозможность установить драйвер, картинку не показывает). При тестировании tserver из папки 480 выдает пятерки в A канале https://drive.google.com/file/d/1mbXM64 ... sp=sharing https://drive.google.com/file/d/1mW5wZf ... sp=sharing Если тестировать папкой 590, то уже сыпет ошибками по всех каналах, причем пятерки в А канале остаются, в остальных каналах появляются четверки https://drive.google.com/file/d/1mevtqP ... sp=sharing, https://drive.google.com/file/d/1mf0Bda ... sp=sharing, https://drive.google.com/file/d/1mfFH7J ... sp=sharing, https://drive.google.com/file/d/1mg7lQU ... sp=sharing Значит ли это, что логично поменять память на А канале и перепроверить повторно P.S. Как вставлять сразу изображения на форум без ссылок на другие ресурсы? Команда "Добавить изображение" у меня не работает, перекидывает на страницу с ошибкой 404 |
Gas_man [ 16 фев 2022, 20:23 ] | |
olegshepeta писал(а): пятерки в A канале Меняй канал А (оба чипа) благо у тебя чипы не дефицитные. А там видно будет. А фото вставить через "ДОБАВИТЬ ФАЙЛ" |
serega2014Mog [ 16 фев 2022, 21:13 ] | |
если показывакет канал a, то это единственный канал который можно с точностью сказать это а0 или а1 просто дать команду ./agt -mccfg если производитель памяти будет виден то просто меняйте а1 а если тишет что неизвестен то меняйте а0 |
Vovan800 [ 17 фев 2022, 06:25 ] | |
Братья, пните в нужном направлении! :) Окуенная голубая сапфира нитро+ RX 580 на 8Гигов - память всегда 300, дрова не ставятся, частота GPU регулируется, частота памяти нет, в линуксе - дрова встают, майнит только Gminer-ом, 20Mh c ошибками. Тсервер проходит только на 300 с ошибками по всем каналам и только первую часть, потом на втором тесте зависон, махнул всю память на самсу (была хуникс), биос шил, а ничего не изменилось, при этом картинку норм выводит и все напряжения в норме, dmgg.py тест проходит... Все 43 стр. темы перечитал: при ошибках во всех каналах пинают смотреть питание памяти, но здесь всё замечательно, осцилом ровная линия 1,56V! GPU грел, качал на шарах с флюсом.. |
olegshepeta [ 17 фев 2022, 18:38 ] | |
serega2014Mog писал(а): если показывакет канал a, то это единственный канал который можно с точностью сказать это а0 или а1 просто дать команду ./agt -mccfg если производитель памяти будет виден то просто меняйте а1 а если тишет что неизвестен то меняйте а0 Очень благодарен. Проверил только что другую карточку msi aero rx 560 4 gb - судя по Ваших рекомендациях можно сузить замену до одной микросхемы а1 |
serega2014Mog [ 17 фев 2022, 18:44 ] | |
да у вас видно что hynix. значит а0 работает и чип ее видит орпределяет и читает меняйте а1 |
stud [ 22 фев 2022, 11:41 ] | |
Всем здравствуйте! Я здесь видел вопросы но ни не видел ответы по поводу ошибки в Tserver Когда проверяешь память и пишет ошибку, но при этом память целая. В чем проблема, это GPU отваливается? Вложение: 4b7f5e7b-c7e5-4906-8b0f-82a996d293db.jpg
kubik [ 22 фев 2022, 13:10 ] | |
Zkus udělat rebal videočipu a velmi často je jedna pamět vadná,tj všechny odpájet,zkontrolovat ohmetrem napájení pamětí a většinou jeden ze 4 pinů má nekonečný odpor u jedné i více pamětí,stává se tedy že paměti se tváří při testu že jsou ok ale karta i tak nehashuje |
stud [ 22 фев 2022, 16:02 ] | |
kubik писал(а): Zkus udělat rebal videočipu a velmi často je jedna pamět vadná,tj všechny odpájet,zkontrolovat ohmetrem napájení pamětí a většinou jeden ze 4 pinů má nekonečný odpor u jedné i více pamětí,stává se tedy že paměti se tváří při testu že jsou ok ale karta i tak nehashuje Вы имеете ввиду, если показало что все хорошо но при этом эта ошибка, то ошибка в памяти имеется? Я конечно попробую. Иначе у меня выбора нет. Поставлю другую память и посмотрю изменится или нет. Но сам чип к сожалению я не смогу перекатать или заменить. Нет инфракрасной паяльной станции. |
Gas_man [ 22 фев 2022, 20:09 ] | |
stud писал(а): Вы имеете ввиду, если показало что все хорошо но при этом эта ошибка, то ошибка в памяти имеется? Я конечно попробую. Иначе у меня выбора нет. Поставлю другую память и посмотрю изменится или нет. Но сам чип к сожалению я не смогу перекатать или заменить. Нет инфракрасной паяльной станции. Забей на эти ошибки "VDDC" Карта работает ? Изо Дает? Тесты проходит? |
kubik [ 23 фев 2022, 02:06 ] | |
Opravoval jsem asi 40 ks RX470 a hodně karet i po výměně špatných pamětí bud neprošly testem anebo byly ok-PASS ale po vložení do rigu nehashovaly,po odpájení a změření pamětí ohmetrem jsem našel vždy nějaké vadné paměti,ty dobré ještě přezkouším zapájením do dobré desky.Ale vždy začínám Bios čipem.Nejlepe se opravují karty,když si seženeš komplet všechny dobré paměti např. z ALIexpresu,ale i ty někdy posílají vadné. |
stud [ 23 фев 2022, 13:00 ] | |
Gas_man писал(а): Забей на эти ошибки "VDDC" Карта работает ? Изо Дает? Тесты проходит? Забивать на то что она не работает? Если знаете проблему, то говорите, а просто кидаться словами все могут. Карта не работает, если бы она работала я бы не писал ни чего! ---------- Добавлено спустя 52 секунды: ---------- kubik писал(а): Opravoval jsem asi 40 ks RX470 a hodně karet i po výměně špatných pamětí bud neprošly testem anebo byly ok-PASS ale po vložení do rigu nehashovaly,po odpájení a změření pamětí ohmetrem jsem našel vždy nějaké vadné paměti,ty dobré ještě přezkouším zapájením do dobré desky.Ale vždy začínám Bios čipem.Nejlepe se opravují karty,když si seženeš komplet všechny dobré paměti např. z ALIexpresu,ale i ty někdy posílají vadné. Спасибо! Я обязательно попробую |
Gas_man [ 23 фев 2022, 13:09 ] | |
stud писал(а): а просто кидаться словами все могут. Никто словами не кидается. Я же вопросы задал: Карта работает ? Изо Дает? Тесты проходит? "PASS" " это на стандартных частотах - 300 Mhz? или повышали частоту? - ./agt -mem=2000 Всю всю ли память видит правильно? - ./agt -mccfg Мало информации. LOG файл выложи. |
Страница 43 из 56 | Часовой пояс: UTC + 4 часа |
