Прошивка новых PWM IR3567b https://vlab.su/viewtopic.php?f=48&t=102697 |
Страница 8 из 10 |
timyr13 [ 14 сен 2022, 16:50 ] | |
Заголовок сообщения: | Re: Прошивка новых PWM IR3567b |
Подскажите пожалуйста размер прошивки для с8051? Может можно контроллер с меньшим количеством памяти использовать? |
dewa [ 15 сен 2022, 07:49 ] | |
Hi all, sorry i can't speak Russian, can somebody help me how to flash ir35217, wanted to buy the usb005 but can't ship to my country so i need to build the clone, what equipment do i need to build the clone from hardware, firmware and software, its very helpful if there's a guideline, thanks |
gehka3 [ 15 сен 2022, 20:29 ] | |
timyr13 252 кб Прекрасно на 340м работает клон, отладочная платка как раз пригодилась, по С2 прошивается практически любым проггером с этим протоколом |
huehu3gg [ 13 окт 2022, 14:14 ] | |
hi, interesting post! i cant download yet from here, can someone share me the files ? the softwares and the clones?? or can someone recompile everything in a driver o something like that?? sorry if im asking too much! cheers |
gehka3 [ 13 окт 2022, 16:23 ] | |
huehu3gg Done |
mich82 [ 18 окт 2022, 03:10 ] | |
Please, I am new member in forum and can not download All the files needed for Clone of usb005. Can someone Kindly share All the files necessary to make the Clone with me via PM |
mich82 [ 18 окт 2022, 10:24 ] | |
gehka3 Please, PM the usb005 clone Software and Firmware to clone C8051F340 Development board as I can not download from the forum yet. Thank you. |
Quattro [ 18 окт 2022, 21:11 ] | |
Could you please send me a copy of the firmware and information needed to make USB005, because I don't have the right to download, thank you very much, from China, using translation software, the sentences may not be standard |
slavak_111 [ 09 ноя 2022, 20:37 ] | |
Извиняюсь за оффтоп. Есть ли способ прошить шимку MPS MP2979A ? Поставил с платы донора, но там разное кол-во фаз VCORE. И откуда брать нужную прошивку? Так понимаю надо сливать с такой же платы? |
bargo [ 16 дек 2022, 17:11 ] | |
refflex писал(а): Attachment: IR3567b.7z [17.12 KiB] Downloaded 67 times Thanks a lot for this information, I was able to see a better documentation for this and also I could understand a bit on what needs to be done, but maybe i'm still missing something as each time I program the MTP values and then try to write to 0x15 (which fails to write) store_all_command, after restart, the MTP values are back to original state, do I need to try password first at 0xF6 and 0xF7 and maybe this IR_LOCK bit as well at 0xE6? thanks a lot for sharing this anyway |
bargo [ 17 дек 2022, 02:53 ] | |
I was missing round about 16 steps to get the mfr registers in place, and I don't know how much it differs for each chip, but at least in my case I am after the 35217 for an rx6900XT memory controller |
deimans88 [ 17 дек 2022, 11:57 ] | |
Кто-нибудь поделится поломанным infenion? |
bargo [ 17 дек 2022, 17:16 ] | |
bargo писал(а): I was missing round about 16 steps to get the mfr registers in place, and I don't know how much it differs for each chip, but at least in my case I am after the 35217 for an rx6900XT memory controller The only missing information at this point is: USER WRITE COMMAND STRUCTURE and MANUFACTURER WRITE COMMAND STRUCTURE for ir35217, if anyone has an idea what those value are, it would be helpful |
ruzalit [ 19 дек 2022, 15:36 ] | |
deimans88 писал(а): Кто-нибудь поделится поломанным infenion? В этой теме выложили viewtopic.php?f=48&t=102697&start=150 |
bargo [ 21 дек 2022, 12:44 ] | |
bargo писал(а): USER WRITE COMMAND STRUCTURE (0x40) + programming pointer (from 0xb6)and MANUFACTURER WRITE COMMAND STRUCTURE (0x58) + programming pointer answered |
ElexxIR [ 16 янв 2023, 16:42 ] | |
Кто-нибудь собрал успешно на отладочной плате с C8051F340? Есть там какие-то нюансы? У меня прошилась успешно в PowIR отображается нормально, а шимки в упор не видит Подключаюсь P00 - SDA, P01 - SCL и земля, подопытная плата запитана, шимки живые, пробовал разные несколько 3567b и 35217 PowIR пишет "I2C connection is not ready for this device" Отладочная плата пришла бракованная или я что-то упускаю? |
jocker [ 16 янв 2023, 17:19 ] | |
ElexxIR писал(а): Есть там какие-то нюансы? кроме того , что f340 f342 в разных корпусах и соответственно p0.0 p0.1 у разных чипов - разные номера выводов - нюансов вроде нет. |
ElexxIR [ 16 янв 2023, 18:15 ] | |
jocker писал(а): кроме того , что f340 f342 в разных корпусах и соответственно p0.0 p0.1 у разных чипов - разные номера выводов - нюансов вроде нет. Благодарю, на отладочной плате пины подписаны, сравнил на всякий случай с даташитом Видимо попалась плата с глючным контроллером |
jocker [ 16 янв 2023, 19:02 ] | |
там не всё так просто и прозрачно на самом деле. мало экспериментировал пока, и в основном с парой десктопных плат. условно говоря - пока контроллера нет в списке доступных - фиг его увидишь нормально. второй момент - мне не удалось нормально поработать с запущенным контроллером на плате гигобайт , ибо шим проца на выключенной мпл обесточен, на включенной соответственно он работает и достучаться до него не удалось. ну, опытные поправят если захотят. |
bargo [ 18 янв 2023, 21:09 ] | |
@Alcos @refflex @tolik-psk @Azazehl @Janosik Thank you for sharing and making this possible to work with, it was a bit of a challenge to get the right bits in place without all of this. Much appreciated and have a good start into the year :) Also to everyone else. All my best, A screenshot of my working version based on the usb005_59_14_full.zip version, working 100% This is a screenshot from an RX6900 which I actually replaced its chip, and now I need to reprogram it Posted after 21 minute 19 seconds: ElexxIR писал(а): Кто-нибудь собрал успешно на отладочной плате с C8051F340? Есть там какие-то нюансы? У меня прошилась успешно в PowIR отображается нормально, а шимки в упор не видит Подключаюсь P00 - SDA, P01 - SCL и земля, подопытная плата запитана, шимки живые, пробовал разные несколько 3567b и 35217 PowIR пишет "I2C connection is not ready for this device" Отладочная плата пришла бракованная или я что-то упускаю? I did build it on the C8051F340 chip, did you try the options menu and the force I2C/Smbus OK? I still get the i2c connection is not ready in some cases, but I need to try with a different controller to judge whats wrong, it could be bad soldering/mounting from me. I hope this helps. Posted after 2 hours 19 minutes 54 seconds: ElexxIR писал(а): Кто-нибудь собрал успешно на отладочной плате с C8051F340? Есть там какие-то нюансы? У меня прошилась успешно в PowIR отображается нормально, а шимки в упор не видит Подключаюсь P00 - SDA, P01 - SCL и земля, подопытная плата запитана, шимки живые, пробовал разные несколько 3567b и 35217 PowIR пишет "I2C connection is not ready for this device" Отладочная плата пришла бракованная или я что-то упускаю? I have the same problem actually, I tried with a working board and with the same I2C connection is not ready for this device error, forcing the i2c/smbus does not actually change anything, but I do feel something is still missing here.. |
bargo [ 20 янв 2023, 00:32 ] | |
bargo писал(а): I have the same problem actually, I tried with a working board and with the same I2C connection is not ready for this device error, forcing the i2c/smbus does not actually change anything, but I do feel something is still missing here.. Solved, I used the 59.14 FBFF.rar version and then I could add the addresses manually but alo the I2c bus scan tool works and detects the chip fine.. I hope this helps |
lowbass [ 27 янв 2023, 05:29 ] | |
refflex писал(а): В ответ поделюсь прошивкой донгла для шимок mps EVKT-USBI2C-02, в нем C8051F381. Дошли руки, собрал на C8051F380, зашил эту прошивку - работает. Также сверил её с дампом из другого источника, от Mafiya67 - одинаковые. Спасибо огромное обоим за FW и фотки донгла, но главное - за участие! nicky_f писал(а): Прошивка битая в хлам - Вы просто не умеете её готовить. |
BoRuSiV [ 16 фев 2023, 13:31 ] | |
Итак, полезная инфа по клону USB005, или мой путь его создания: Купил отладочную плату c С8051F340 и программатор U-EC6. Подключил программатор комплектным 10pin кабелем к отладочной плате, и через Flash Programming Utility пролил 59.14 FBFF.rar. Все файлы есть в этой теме. Программатор, кстати, не хотел прошивать плату, пока Flash Programming Utility при очередном перезапуске не предложила его обновить. После обновления отладочная плата определилась и прошилась. После чего отладочная плата стала определяться по USB и в PowIR Center, и обновляться "официальным" способом. Касаемо распиновки, никаких дополнительных резисторов допаивать не надо. P00 - SDA, P01 - SCL, и конечно GND подсоединяется напрямую к прошиваемой карте. В моём случае (IR35217) Pin 24 - SDA, Pin 25 - SCL. Теперь к нюансам: При ручном выборе прошиваемой микросхемы виделись только пункты Loop1 и Loop2, при попытке считать дамп появлялась ошибка "Check device 3.3V and i2c". Проблема решилась автодетектом, вместо ручного выбора нужно нажать левую кнопку "Auto populate devices" в верхней панели. После чего сама микросхема определилась с синим статусом "i2c Good", и всё прекрасно начало читаться, прошиваться и мониториться. Внешний вид отладочной платы и программатора в прикреплённом фото. |
lowbass [ 23 фев 2023, 18:41 ] | |
Если вдруг тему читает человек из Симферополя с программатором/дебаггером C2 для Silabs, или кто-то знает такого человека - это просьба для него: Надо слить прошивку с донгла Renesas ISLUSBEVAL1Z для Intersil. Донгл находится в Симферополе. Владелец согласен слить прошивку. Дело пяти минут. Но у владельца нет прогера, и ему это не надо. Зато это возможно пригодится нашему сообществу. Пока не встречал, где бы нам этот донгл пригодился, но учитывая тенденции - думаю, лучше иметь её под рукой, на всякий случай. Если есть возможность и желание - пишите в личку. |
STALKER_71 [ 13 мар 2023, 16:28 ] | |
lowbass lowbass писал(а): - Вы просто не умеете её готовить. Подскажите как правильно её готовить. Тоже пробовал прошить и пока ничего не вышло. |
lowbass [ 13 мар 2023, 21:25 ] | |
STALKER_71 писал(а): Подскажите как правильно её готовить. Подсказываю: конвертировать в Intel Hex |
STALKER_71 [ 13 мар 2023, 22:15 ] | |
lowbass писал(а): конвертировать в Intel Hex Я так и понял, вот только не выходит сконвертировать нормально. Каким методом вы конвертировали? При конвертации дампа из темы в intel hex я получаю файл размером 15кб который не работает. При этом прошив платку в usb005, потом считав с мк данные и переконвертировав их в intel hex я получаю полностью рабочую прошивку размером 146кб, которая прекрасно зашивается и работает. Либо с дампом из темы что то не так, либо его нужно как то по особому конвертировать. |
lowbass [ 14 мар 2023, 05:19 ] | |
STALKER_71 писал(а): я получаю файл размером 15кб который не работает Или файл, который работает, но Вы не понимаете, как) STALKER_71 писал(а): Либо с дампом из темы что то не так, либо его нужно как то по особому конвертировать. Никакого особого способа конвертации, который дал бы на выходе какой-то особый файл, не существует. |
STALKER_71 [ 14 мар 2023, 12:25 ] | |
Я вот не пойму, вам так сложно дать полноценный ответ? К чему этот флуд? Почему то прошивки для usb005 прекрасно конвертируются и зашиваются и работают. А этот дамп нет. Не хотите отвечать в теме, ответьте в личку. Я вам задавал этот вопрос там, но вы проигнорили и продолжаете в теме воду лить. |
koslw [ 14 мар 2023, 15:12 ] | |
STALKER_71 писал(а): Я вот не пойму, вам так сложно дать полноценный ответ? А зачем конвертировать? Flash Programming Utility и так зашивает |
Страница 8 из 10 | Часовой пояс: UTC + 4 часа |
