Текущее время: 21 ноя 2026, 03:38
 Заголовок сообщения: Power Color RX 570 8GB help with identifying resistor value.
СообщениеДобавлено: 30 сен 2020, 12:12
Someone desoldered all 4C10N mosfets and CHL 8510 drivers and also changed the resistors. . What should be the value of the resistor in the picture? I don't have 4C10N, can I use the 4C09N ??
 Заголовок сообщения: Re: Power Color RX 570 8GB help with identifying resistor value.
СообщениеДобавлено: 30 сен 2020, 12:46
10к
yes
СообщениеДобавлено: 01 окт 2020, 16:28
I soldered 5 phases and started the card. Something is wrong VRM Efficiency 100% .Изображение
СообщениеДобавлено: 01 окт 2020, 23:27
VRM Efficiency looks fine.
It is efficiecncy of DC-DC converter, not "the percent of max tdp", that is shown for nvidia.
However >100W power draw for idle card seems really incorrect.
100W without spinning fans would quickly put the gpu much hoter than 50°...
It looks either like incorrect measurement, or like some ICs of of DC-DC converter are eating 100W and are extermely hot for idle mode.
СообщениеДобавлено: 02 окт 2020, 19:51
I found two damaged resistors, probably measuring ones. I could not read their values. I soldered with a value of 000 like the others next to it. Unfortunately, it did not help the card still in idle have 100W.Any ideas what to do next ??
СообщениеДобавлено: 02 окт 2020, 20:12
I don't think that these are measuring. They may be related to some power phase, and zero resistors often are not damaged by themselves, but a burned due too high current. So, I suggest re-checking that all about phases related to those zero resitors are fine
СообщениеДобавлено: 06 окт 2020, 21:00
I replaced the Ir 3567B but it is still the same, the power supply system is slightly warm. There are strange jumps in the current consumption in the 100W-150W gpuz. The card can hang during these jumps. Once I saw even 1.5V on the gpu. I have no idea what lying to the measurements ??
СообщениеДобавлено: 07 окт 2020, 14:33
It turned out that the card was mechanically damaged. A broken pad under one of the coils, someone tried to stick it. After removing the coil, the card has normal consumption. Thanks for your help.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 15-DY (DA0P5HMB8J0) Help needed with resistor value..
mohammedsf
08 янв 2026, 18:36
mohammedsf Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus X556UJ (Notebook) Resistor value?
CesurISLER
07 дек 2017, 15:40
CesurISLER Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. F15KR_DSC (F15KR_DSC) Resistor value
CesurISLER
13 дек 2019, 22:42
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Predator (g9-593) no ACDET/resistor value?
myth77
17
4661
18 июл 2022, 10:15
mmarc Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS GL752VW 2.1 (GL752VW 2.1) Value of resistor
razoramd
25 ноя 2020, 14:52
razoramd Перейти к последнему сообщению
Сейчас этот форум просматривают: tyghvm и гости: 82
cron
