MSI GTX 1070 Gaming X 8G "connect the pcie power cable for this graphics card" https://vlab.su/viewtopic.php?f=48&t=111770 |
TomaszR [ 02 фев 2021, 12:37 ] | |
Заголовок сообщения: | MSI GTX 1070 Gaming X 8G "connect the pcie power cable for this graphics card" |
Hello, I have a problem with an MSI GTX 1070 Gaming X 8G specifically it's the error "connect the pcie power cable for this graphics card". Of course, the PSU has been checked as well as the power cables are properly plugged into the card.(on the other same card everything works fine), so the problem must be on the graphics card. The graphics card has been dropped and has a slightly bent laminate at one of the power sockets, but the main 12V goes to the graphics card from both sockets. No components have been broken off, they are all on the board - I have compared this with second identical card. Has anyone encountered this problem or have an idea how to fix it? i would appreciate any help |
aleksros [ 02 фев 2021, 13:51 ] | |
Заголовок сообщения: | Re: MSI GTX 1070 Gaming X 8G "connect the pcie power cable for this graphics card" |
check the integrity of the wires at the locations marked in green. check your email |
TomaszR [ 02 фев 2021, 16:15 ] | |
Exactly! There was a break in the wires, after reconstitution wires the card start to working properly. Thank you very much Aleksros for your quick and accurate diagnosis! |
takavara [ 04 мар 2024, 04:11 ] | |
verifique a integridade dos fios |
nhyd [ 16 мар 2024, 18:46 ] | |
Определите правильность напряжения в близлежащем триоде по GPIO12. |
dron102 [ 23 апр 2024, 14:14 ] | |
Аналогичная проблема на такой же видюхе,проверил эту обвязку,там все нормально,копать дальше к шим управления питальником? |
