Текущее время: 20 ноя 2026, 18:32
 Заголовок сообщения: GTX 970 Palit Broken SMD capacitors
СообщениеДобавлено: 12 мар 2021, 06:22
Hello i have gtx 970 Palit with broken capacitors, could you please tell me values of that capacitors?
Thank you
 Заголовок сообщения: Re: GTX 970 Palit Broken SMD capacitors
СообщениеДобавлено: 21 мар 2021, 01:24
Hello again, i got 2 more gtx 970 with the same pcbs and i measured every capacitor that was off and soldered it, and still i have no picture and on gpu is only 110mV, strange thing because on second gtx 970 is the same thing, on gpu only 120mV, what could be wrong with that cards? Tomorrow i will add all other voltages and resistances.
СообщениеДобавлено: 21 мар 2021, 14:56
Every voltage 3.3, 5, 12, are present
 Заголовок сообщения: Re: GTX 970 no powers after plug both 6pin pcie
СообщениеДобавлено: 21 мар 2021, 22:03
Hello again guys i have 3x gtx 970 cards with the same issue, on palit reference cooling if one of 6 pin is only connected (no matter which) it boots and show warning to connect pcie connector, after plug in gpu is not recognized and power to mem and gpu is not present. Could it be ina3221 or what?
On other 2 cards the same problem:
Palit jetstream - it shows screen only when i plug left pcie connector, if i will plug only right plug it is not recognized.
On gainward phantom is the same but opposite direction.
What the hell could it be?
---------- Добавлено спустя 29 минут 25 секунд: ----------
Ok, as on this photo i measured resistances and all 3 cards have short in some point so on one card i give 2v here and demos heated us so i think is broken, tomorrow i will replace him and give u feedback.
СообщениеДобавлено: 22 мар 2021, 22:52
Ok, changed on one card one of mosfets to sid780 and one of fuse and card turned on, but i got a lot of artifacts and in mats only one ram have no errors, changed bios - no difference, voltage on memory is 1.4v - isn't is too low?
СообщениеДобавлено: 24 мар 2021, 07:58
Hello again, first card i have still artifacts and all memory errors in mats, on second after replace mosfets card working fine and third card have broken traces under mosfet and shorted gpu so it's dead.. what could be with that card with artifacts?
СообщениеДобавлено: 01 апр 2021, 23:13
I have a FBVDDQ of 1.61V at my GTX 970 JetStream. Try to check the 12V source feeding the 2 memory channels, as well as their phase signals with an oscilloscope. The signal must look stable, whithout "jumps" in the timings. What is the resistance between the FBVDDQ and GND? I have 25 Ohm with Samsung memory and even though it looks quite low, it works OK. Is any of the RAM modules heating up more than others? Does the color of the compound at the GPU crystal look even or are there darker areas?
This card has a known issue of building up a short circuit between the vias of the feedback traces under the chokes, check if this is the case for your "dead" card.
Your current sensing shunt SRS1 at the first photo doesn't look good. Check it by replacing (e.g. use your dead board as a donor).
В этой теме нет новых непрочитанных сообщений. Aorus x570 Gigabyte broken SMD capacitors
в форуме Gigabyte
xxkachellxx
25 дек 2021, 19:50
В этой теме нет новых непрочитанных сообщений. dell vostro 15-7570 (Broken) Bios is broken
в форуме Поиск BIOS
deathdealer9982
08 дек 2023, 08:38
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Replacement SMD capacitors for ASUS ROG Strix 2080
MSIGamer72
1898
09 мар 2021, 23:35
MSIGamer72 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gigabyte GA-G31M-ES2C Doubts about heating in two electrolytic capacitors near memory
в форуме Gigabyte
eletmoraes
13 апр 2017, 17:24
practicezerg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI 1070 v330 ver. 3.0 Capacitors capacity on the back
в форуме Беседка
IljaKraft
14 дек 2021, 18:31
IljaKraft Перейти к последнему сообщению
Сейчас этот форум просматривают: andiag, donkihot, Google [Bot], madking, Sl78 и гости: 89
