Текущее время: 25 июн 2024, 10:02
Micchaleq
Заголовок сообщения: Asus RTX 2080 Ti Turbo - 100% fan and no signal. ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 05 май 2021, 22:46 |
Зарегистрирован: 21 июл 2018, 10:32 Наличности на руках: 57.41 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 39 Откуда: England
Hi all,
I have a question about the problem as in the subject of the post. I have checked all coild by multimeter and toy osciloscope. It look like everything is ok. There is 1,8V 1V, 0,8 GPU and 1,4 VRAM present. The resistance is about: 0,1-0,2Ohm on GPU, 16Ohm on VRAM, 2,8 kOhm on 1,8V; 8 Ohm on 1V 3x 12V kOhm
If you preffer you can answer in your native language.
![](images/spacer.gif) |
