Sappire RX 470 8GB 0C temps https://vlab.su/viewtopic.php?f=48&t=116900 |
frankmnld [ 02 июл 2021, 10:42 ] | |
Заголовок сообщения: | Sappire RX 470 8GB 0C temps |
Good Day I have a Sapphire RX 470 8GB mining 1x dvi port which works fine only shows 0.0C temperature in gpuZ and fan runs at 100%,. looks like thermal sensor is broken, I thought thermal sensor maybe located inside gpu chip itself so i welded a new chip on it but the same problem, does anyone knows anything how to solve this problem, A boardview or schematic..? beside 0C problem the card runs perfectly fine and temps are around 55C under full load when measuring with external thermocouple. I hope someone will help me out. Cheers |
k0t1k [ 02 июл 2021, 14:21 ] | |
Заголовок сообщения: | Re: Sappire RX 470 8GB 0C temps |
check the fan control signal transistor. |
westcoast [ 03 июл 2021, 11:48 ] | |
Look out for sc70/sot363 components on the board |
Poyraz__ [ 26 сен 2021, 02:41 ] | |
Hi i have rx470 4gb, its working but fans not spinning even if hot getting 75degree not spinning. İ tried bios and afterburner not worked. Did you solve problem? Which part is controlling that fans? |
Poyraz__ [ 26 сен 2021, 14:11 ] | |
Poyraz__ писал(а): Merhaba, rx470 4gb'im var, çalışıyor ama fanlar sıcakken 75 derece dönmüyor olsa bile dönmüyor. Bios denedim ve afterburner çalışmadı. sorunu çözdün mü Bu fanları hangi kısım kontrol ediyor? İ solved the problem i changed q1604 maked as "S1AH" and q203 marked as "S1AH" ![]() |
