Текущее время: 07 июн 2024, 17:37
Pandemonium6
Заголовок сообщения: Re: нету напряжений после дрмосов на сапфир рх 570 Добавлено: 08 сен 2021, 20:38 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
oplk писал(а): what could be the matter? Hi, In my opinion it looks like your GPU. Crystal top part of the GPU lost contact on some pins with the bottom part of the flip chip. I observe it very often.
Pandemonium6
Заголовок сообщения: Re: нету напряжений после дрмосов на сапфир рх 570 Добавлено: 09 сен 2021, 13:19 |
Most cards with such symptoms like not detected from time to time, black screens, restarts look like GPU. When you remove the heat sink so removing the tension on the crystal, this card may stop being discovered and may stop boot on 2b. Of course miracle can happen like knocked off 220n capacitors, broken traces, bios related things, power but some symptoms are brutal. But I had miracles also. For instance warm capacitor on the GPU itself, not hot but warm that is why the thermal cam and a ZnSn lens is mandatory.
