EVGA GTX 1080 fw issue https://vlab.su/viewtopic.php?f=48&t=119021 |
bokin021 [ 16 сен 2021, 23:17 ] | |
Заголовок сообщения: | EVGA GTX 1080 fw issue |
When I turn graphic card after 30 sec,monitor turn on but no pictures..I change GPU,but same..I also test with mats no memory error,when I turn on vga u see card in device menager ,but after driver blue screen and restart..I flash new bios no help..Maybe some one have same problem?What mats is for this model of graphic card?Thanks.. |
YunicheK [ 16 сен 2021, 23:29 ] | |
Заголовок сообщения: | Re: EVGA GTX 1080 fw issue |
От 367.56 и выше. |
bokin021 [ 21 сен 2021, 16:53 ] | |
some hellp? |
Artem4058 [ 22 сен 2021, 19:44 ] | |
you need to use 367.56 and after mats test. |
Quasar047 [ 22 сен 2021, 19:50 ] | |
bokin021 писал(а): some hellp? Try to test the card using mods. You have to put your card in the second slot of MB then put another card in the first slot or use internal graphic to get the image. Take the ISO from these theme viewtopic.php?f=48&t=110020 You can use mods like ./mods gputest.js -oqa -old_gold -dramclk_percent 100 -fan_speed 80 -run_on_error -test 3 This let you test the card by mats through mods with maximum of memory clocks |
bokin021 [ 26 сен 2021, 15:46 ] | |
i have problem with mods heattest is not defined ..I wish test do with vga and grphic card installes in slot ..Please hellp |
Quasar047 [ 28 сен 2021, 10:49 ] | |
bokin021 писал(а): i have problem with mods heattest is not defined ..I wish test do with vga and grphic card installes in slot ..Please hellp I don't undrstand exactly what did you do? Did you flash the ISO from theme? |
