Текущее время: 21 ноя 2024, 21:12
 Заголовок сообщения: MSI GTX 970 - memory swap to another company
СообщениеДобавлено: 06 июл 2019, 09:58
Hi all,
I have a question about GTX 970 from MSI company and maybe another 970 series card. I have an old PCB without memory and now I would like to place them there. The problem is that I don't know which company was there. I have Hynix memory now.
I heard that when the memory are swapped there are additional resistors have to be placed or swap some of them (something like that).
That is why I would like to ask you is it true?
Do I have to change something?
Maybe I can use Elpida, Samsung or Hynix interchangeably? That mean it doesn't matter about company of memory, GPU or BIOS detects it automatically.
The memory which I saw on the MSI 970 is:
ELPIDA: W4032BABG-70-F
SAMSUNG: K4G41325FC-HC28
The SKhynix which I have is: H5GC4H24AJA T2C
 Заголовок сообщения: Re: MSI GTX 970 - memory swap to another company
СообщениеДобавлено: 06 июл 2019, 11:24
write the serial number of your videocard, I will tell you what kind of memory it was installed from the factory.
СообщениеДобавлено: 08 июл 2019, 11:53
Hi,
The serial number is: 602 V316 09SB1410039222
СообщениеДобавлено: 08 июл 2019, 12:22
HYNIX/H5GQ4H24MFR-R2C
this memory from factory
СообщениеДобавлено: 08 июл 2019, 14:14
Простите за не скромный вопрос а как вы узнали какая память стоит с завода?)
СообщениеДобавлено: 08 июл 2019, 14:57
Thank you very much. I will order this model.
On the other hands. Is this memory can be replaced for Samsung or ELPIDA?
As in the first post is there special resistor which define which memory is used?
СообщениеДобавлено: 08 июл 2019, 15:40
msi сказал ))
СообщениеДобавлено: 08 июл 2019, 20:40
да резистор есть, по 5 ножке флешки биос, 20к самсунг, 15к хуникс, 10к элпида!
СообщениеДобавлено: 09 июл 2019, 00:50
спасибо / Thank you
СообщениеДобавлено: 30 сен 2021, 14:04
Да резистор есть, по 5 ножке флешки биос, 20к самсунг, 15к хуникс, 10к элпида!
Не могу найти этот резистор,поменял банки с хуникс на элпиду,но не разберусь чтоб отображалось правильно.
Не подскажите номер резистора по схеме?
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 05:42
black7705 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte GTX 3060Ti Vision Memories swap problem
ll_r1d0_ll
20 авг 2023, 23:33
ll_r1d0_ll Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. EVGA GTX 970 Identyfication position of memory banks
Micchaleq
17 авг 2020, 13:48
Micchaleq Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 23:26
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Apple Macbook Pro A1278 (K90i, 820-2936) another motherboard with water damage issue
в форуме Apple
andromedax
22 окт 2015, 20:12
andromedax Перейти к последнему сообщению
Сейчас этот форум просматривают: madking и гости: 68
