MSI RX580 8GB missing PX_EN https://vlab.su/viewtopic.php?f=48&t=119789 |
andreagtr [ 15 окт 2021, 19:31 ] | |
Заголовок сообщения: | MSI RX580 8GB missing PX_EN |
Hi to all and thanks for your attention I have this 580 (maybe i can have one working), with all the voltages and resistance in order, but im missing PX_EN and DRAM_RSTA, the gpu goes warm, but i cant reconignize it on windows or other OS. The seller say goes black some days ago and nothing else, some months ago changed thermal compund (paste and pads). If anyone can help me i appreciate PS i dont know if its permitted by rules but i can pay if we can fix it. many thanks |
pEEp [ 15 окт 2021, 22:12 ] | |
Заголовок сообщения: | Re: MSI RX580 8GB missing PX_EN |
andreagtr писал(а): but im missing ... DRAM_RSTA Look for white capacitors: |
andreagtr [ 15 окт 2021, 22:21 ] | |
Thanks to your time! What cap do you mean? Ive tested all the cap near the pcie connector and j read 0.230v for each one... |
pEEp [ 16 окт 2021, 00:23 ] | |
andreagtr писал(а): What cap do you mean? pEEp писал(а): Look for white capacitors: Under the red line (on photo). |
andreagtr [ 16 окт 2021, 09:57 ] | |
I cant see the pic attached... i havent the permission, too young on this forum... im so sorry Posted after 1 hour 6 seconds: Ive tryed to test the 2 cap near the q1077, both had one side at ground the big one had other side connected to pin7 of u200 the other one i cant check with multimeter in diode mode and I cant follow where it goes... |
vernanflexX [ 18 ноя 2021, 04:30 ] | |
Did you get any solution I have exactly that problem on two video cards. |
Pandemonium6 [ 18 ноя 2021, 12:50 ] | |
andreagtr писал(а): PX_EN It is very important signal. How close to the GPU did you search for it? It goes through a series of resistors and 0 ohm resistors. It is connected to many places. A shorted transistor somewhere can pull it down along with DRAM_RSTA. For example this dual NPN could pull these signals down or up permanently. Posted after 5 minutes 48 seconds: andreagtr писал(а): I cant see the pic attached.. But you could support this forum with $99 ![]() Posted after 2 minutes 40 seconds: vernanflexX писал(а): Did you get any solution I have exactly that problem on two video cards. Did you measure the whole net? What is a voltage drop and resistance of each signal in a different points? What is the exact model of this MSI card? |
PT-AH [ 18 ноя 2021, 16:01 ] | |
I have a 580 nitro rx here with the same problem. :/ |
Leha74 [ 18 ноя 2021, 17:43 ] | |
на Сапфирах PX_EN появится когда карта будет стоять в материнке. |
