Текущее время: 21 ноя 2026, 03:41
 Заголовок сообщения: MSI RX 470 ARMOR OC 8gb - all voltages and no detect chip system
СообщениеДобавлено: 18 ноя 2021, 15:57
I have a RX 470 that I bought to repair, because it had a broken chip which is what controls the fan, being a bipolar transistor.
she has her memories burned and was not fed.
After replacing the (mmdt3904-7) bipolar transistor, and the same control chips that were shorted: GS... and APW...
this is already being fed in all places.
The same when I connect to the PC does not detect the chip and the fans only run when it is already hot.
Chip warms up and the memories too.
How do I get the chip to boot?
Any idea Any idea
or the chip is burned?
 Заголовок сообщения: Re: MSI RX 470 ARMOR OC 8gb - all voltages and no detect chip system
СообщениеДобавлено: 19 ноя 2021, 12:39
You need to follow the diagnostic procedure. PCIe signals integrity, resistances of voltage rails and many other factors. What PCB version is it?
СообщениеДобавлено: 21 ноя 2021, 02:32
GPU PCB model is V341_20.
I would like to understand more about this, if you can help me, I would appreciate it.
СообщениеДобавлено: 21 ноя 2021, 06:20
Search for Schematic MSI MS-V341, u can get guide from there.
Follow this recomended
СообщениеДобавлено: 16 дек 2021, 18:12
Hello people
These days I've been in analysis. Checked for defective chips.
on vrm had 3 defective chips and had an output condenser on pcb botton ripped out.
I put the capacitor back in and put in 3 new chips and 2 used coils from another gpu that burned on the other side, but they're good.
With this I got the circuit much better, but now I have 1 problem and I don't understand why this is.
In image 1 I made the drawing of the oscilloscope measuring the wave, being a square wave. It appears on all coils except the one marked in image 2. Even so, it passes 0.850V on that coil, but without such a wave.
can you give me a hand?
Image 1: https://ibb.co/sR6FTtQ
Image 2: https://ibb.co/W6mXkqh
СообщениеДобавлено: 18 дек 2021, 19:38
If you don't have pulses there you have to investigate this particular phase.
В этой теме нет новых непрочитанных сообщений. ASRock Vega56 - no Video but all voltages and BIOS OK
Assassin
04 июл 2020, 16:53
men2k1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI Radeon R7 370 GAMING 4G, all voltages, not turn on video display.
PT-AH
30 янв 2022, 01:19
pEEp Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 970 MSI GAMING X MS-V316 REV1.3 / ALL VOLTAGES PRESENT, BUT NO VIDEO
azzed
27 окт 2022, 10:46
huehu3gg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RTX 3080ti no picture all Voltages up
Dance0fArrows
21 сен 2023, 14:24
Dance0fArrows Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTx 980 all voltages are normal, PWM signal too, but black screen
netcrusher
14 фев 2020, 18:50
Naik Перейти к последнему сообщению
Сейчас этот форум просматривают: Yandex [BOT] и гости: 75
