Текущее время: 21 ноя 2026, 04:29
 Страница 1 из 1 [ Сообщений: 23 ]
 Заголовок сообщения: mods error when testing gpu
СообщениеДобавлено: 12 дек 2021, 06:15
hi everyone
im triying to run mats and mods in an asus laptop mats version is 367.38.1
the model is gl553vd with a gtx 1050 mobile
when i run mods i got the following log
MODS start: Sat Dec 4 21:24:33 2021
Warning : test specifications should be used to control p-states
Command Line : gputest.js -test 3 -test 18 -test 19 -test 52 -test 111 -test 112 -test 143 -mfg -null_display -poll_interrupts -pstate 0.max -no_thermal_slowdown -matsinfo
CPU
Foundry : GenuineIntel
Name : Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
Family : 6
Model : 14
Stepping : 10
Version
MODS : 367.38
OperatingSystem: Linux (x86_64)
Kernel : 4.1.2-gentoo
KernelDriver : 3.63
HostName : tinylinux
Smbios version [0x300] is not supported
File 'gp107_f.xml' not found
gpu 0 dev.sub 0.0
PCI Location : 0x00, 0x01, 0x00, 0x00
DID : 0x1c8d
Raw ECID : 0x062312c000000070718881c4
ECID : SS768W-11_x49_y49
Device Id : GP107
Revision : a1
NV Base : 0xa3000000
FB Base : 0x90000000
IRQ : -1
Error 000000000229 : Gpu.Initialize hardware was not initialized
Error 000000000229 : Global.PrintGpuInitError hardware was not initialized
Error 000000000229 : Global.InitializeGpuTests hardware was not initialized
RmDestroyGpu failed
Error Code = 000000000229 (hardware was not initialized)
MODS end : Sat Dec 4 21:24:35 2021 [1.199 seconds (00:00:01.199 h:m:s)]
i got the error ¨hardware was not initialized¨ but windows recognizes the gpu and i can play some games on it that means my gpu is not faulty
how can i get pass this error or what this error means
thanks in advance
 Заголовок сообщения: Re: mods error when testing gpu
СообщениеДобавлено: 12 дек 2021, 09:36
https://disk.yandex.ru/d/pBUIc8NdTaYEdg
delete all the files from the flash drive and drop these, then send the report
after checking, the PC will turn itself off
mats 400.184
СообщениеДобавлено: 15 дек 2021, 20:29
niko_lyan
ok
ill test and post the next log
СообщениеДобавлено: 18 дек 2021, 04:37
niko_lyan
hi
i tried your mods version and i am getting the following errors
mods says
MODS start: Wed Dec 15 11:57:44 2021
gputest.jse:7058: ReferenceError: HeatStressTest is not defined
MODS end : Wed Dec 15 11:57:45 2021 [1.538 seconds (00:00:01.538 h:m:s)]
and mats says
error description gpu was not compatible
now what can i try
thanks for your response
СообщениеДобавлено: 22 дек 2021, 23:29
some suggestions?
СообщениеДобавлено: 23 дек 2021, 00:28
You must find MODS+MATS with support your card. Download more MODS and check this file (gp107_f.xml) is present in his folder. Then repost MODS log there.
СообщениеДобавлено: 23 дек 2021, 05:44
CatSW
Ok I’ll find a new version of mats with that file and then will post log output
СообщениеДобавлено: 24 дек 2021, 03:50
CatSW
hi
i find a new mods version wich is 455 and then now i got this log
MODS arguments :
MODS start: Thu Dec 23 11:24:52 2021
Command Line : gputest.js -skip_rm_state_init
CPU
Arch : x86_64
Cores : 8
Version
MODS : 455.127
System
Kernel : 4.4.0-142-generic
KernelDriver : 4.01
SBIOS Version : V1.28
SBIOS Date : 08/05/2019
HostName : bau-Nitro-AN515-52
Available RAM : 4729/7824 MB (Free/Size)
Sys-uuid :
HDD-Serno : WKPJBXSP
ERROR: File 'gp107_f.xml' not found
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
GPU DID : 0x1c8d
PDI : 0x00002d9a94cf8b43
Raw ECID (GHS) : 0x470707188800000000b188c40
ECID : SAMSUNG-SS768W-11_x49_y49
Device Id : GP107
Revision : a1
Sub Revision : 2
IRQ : 16
Successfully cleared GPU's interrupt state.
WARNING: GPU 0 [01:00.0] PCIE speed capability (8000Mbps) higher than down stream port link speed (2500Mbps)
Chipset
VID : FFFF (Unknown)
Chipset DID : FFFF (Unknown)
Chipset ASPM : L0s/L1
Chipset LTR : Enabled
Error 000000000021 : CheckClocks (test 10) script failed to execute [0.000 seconds]
Error 000000000021 : Global.RequireGoldenValues script failed to execute [0.054 seconds]
Error 000000000021 : Global.LoadGoldenValuesHelper script failed to execute [0.054 seconds]
Error 000000000021 : Global.LoadGoldenValues script failed to execute [0.054 seconds]
Error 000000000021 : Global.InitializeGpuTests script failed to execute [0.140 seconds]
gputest.jse:32: TypeError: subdev.Perf has no properties
Error Code = 000000010021 (script failed to execute)
MODS end : Thu Dec 23 11:24:53 2021 [1.178 seconds (00:00:01.178 h:m:s)]
СообщениеДобавлено: 24 дек 2021, 11:09
CatSW
hi
Hi !
File again not found(.
Download and try this version:
MODS 370.14, 1050Ti
GTX1050TI.zip [34.42 МБ]
from user "acidwise" :
viewtopic.php?f=48&t=96805&p=887104
Also important - you must add to command line MODS key "-oqa" :
"gputest.js -skip_rm_state_init - oqa"
Then test memory:
./mats -e 1 -n 1
if PASS you have a chance your GPU is ok
then try:
./mats -e 4 -n 1
If card not detected by MATS - change key "-n 1" to "-3d_card" - like this "./mats -e 1 -3d_card"
СообщениеДобавлено: 24 дек 2021, 13:24
https://www.youtube.com/watch?v=AGLygFlF00A тест видеопамяти ноутбука
In Russian. Sorry
СообщениеДобавлено: 24 дек 2021, 19:48
CatSW
ok i will try the version of mods that you posted thanks
and the gpu is working, is recognized by windows and i can play games on it but the reason im trying to run mods and mats test on it its because when i was playing a game the laptop turned off and when i turned on again, windows wasnt recognizing the gpu and device manager was saying error 43, then a let the laptop tuned off for 6 days and when i turned on magically was recognized by windows again and i was able to play on it too
---------- Добавлено спустя 1 час 29 минут 25 секунд: ----------
crocodile70
hi
i will watch the video and try
СообщениеДобавлено: 24 дек 2021, 23:28
Please read MODS.pdf in the same folder. It explains all the command line keys (you can choose what you want to testing) and explains all the errors that you can see from the test results.
СообщениеДобавлено: 25 дек 2021, 00:19
CatSW
ok
i will read that file before continue doing test
СообщениеДобавлено: 25 дек 2021, 01:06
I can upload this file here if you don't find it in your archive. Just say it))
СообщениеДобавлено: 29 дек 2021, 05:49
CatSW
please yes upload file here
many thanks
СообщениеДобавлено: 29 дек 2021, 13:41
No problem)
СообщениеДобавлено: 30 дек 2021, 21:07
CatSW
thanks
i will test and then post the log
---------- Добавлено спустя 1 час 49 минут 44 секунды: ----------
CatSW
ok so i tried the mods version for gtx1050 that you posted before and now got this
MODS start: Thu Dec 30 13:52:48 2021
Command Line : gputest.js -skip_rm_state_init -mfg
CPU
Family : 6
Model : 14
Stepping : 10
Version
MODS : 370.14
KernelDriver : 3.63
gpu 0 dev.sub 0.0
DID : 0x1c8d
Raw ECID : 0x00000000062312c000000070718881c4
Raw ECID (GHS) : 0x0000000470707188800000000b188c40
Device Id : GP107
Revision : a1
IRQ : 16
NV_PMC_INTR_0 bit 30 high.
Trying to clear interrupt by writing 0x2 to register 0x12004c
Failed to read good Jtag Ctrl Status
WARNING... Failed to unlock Jtag for access!
Chipset
Rm call failed. default Disabled.
Chipset ASPM : Disabled
gputest.js : 22
mfg.spc : 4
boards.js : 1
boards_gp100.db: 36
boards_gp102.db: 12
boards_gp107.db: 38
boards.db : 3152
Error 000000000021 : Global.GetPerfPointsToTest script failed to execute
Error 000000000021 : Object.RunSingleDeviceGpuTests script failed to execute
Error 000000000021 : Function.GroupRunFcn script failed to execute
gputest.jse:4740: TypeError: subdev.Perf has no properties
GpuDevMgr not initialized. Device shutdowns will likely do nothing.
Error Code = 000000000021 (script failed to execute)
MODS end : Thu Dec 30 13:52:49 2021 [0.861 seconds (00:00:00.861 h:m:s)]
now whats next
also tried run mats but got nothing on log
СообщениеДобавлено: 30 дек 2021, 23:50
Sorry, but I think You GPU is dead. But try to check all resistans (power line to GND - GPU, video memories and etc.) and voltage on this points on graphics card, may be you see some faults.
СообщениеДобавлено: 31 дек 2021, 05:17
CatSW
hi
windows recognize the gpu
actually the gpu is working, i can play furmark test and pass and even play video games on it
but i want to do a mats test in this gpu before selling
this gpu is in a laptop integrated
СообщениеДобавлено: 31 дек 2021, 10:08
If you are sure that it is this GPU that is working - not the integrated video - then maybe this MODS is not compatible with this motherboard.
Try another MODS version...
СообщениеДобавлено: 29 янв 2022, 06:38
CatSW
hi and sorry for my very late response
i will try all mods versions that i found and i will tell you if someting new happen
thanks
СообщениеДобавлено: 29 янв 2022, 10:50
Since you are testing the SECOND video card, do not forget about the key "-skip_rm_state_init" in the mods command line. And instead of "-mfg" you can try "-oqa" (or "-short" depending on version MODS). Good luck!
СообщениеДобавлено: 27 июн 2022, 19:50
Hi. Based on what you wrote, your video card is working. An error in MODS shows that it cannot initialize the graphics card. This situation may be due to bad memory, non-working GPU or your video card is not supported by this version of the MODS.
В этой теме нет новых непрочитанных сообщений. RTX 2060 MODS Error 539 (NVRM Generic falcon error)
kiioloxt
10 дек 2025, 14:01
Forter Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Testing electronic components-Colin Mitchell
в форуме Литература | Books and magazines
myth77
19 фев 2017, 11:59
myth77 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. How to install ubuntu for nvidia testing (collect) china
meohaimat2021
15 сен 2020, 07:40
meohaimat2021 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Weird error with Mats/Mods and GTX970: unsupported dram Page size and L2 slices
Assassin
26
5931
06 апр 2024, 20:54
Roberts3333 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MATS понятно а как MODS ? Синий экран Video Scheduler Internal Error
tonycstech
1916
01 май 2022, 02:51
tonycstech Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 125
