mods error when testing gpu https://vlab.su/viewtopic.php?f=48&t=121484 |
elgatillo263 [ 12 дек 2021, 07:15 ] | |
Заголовок сообщения: | mods error when testing gpu |
hi everyone im triying to run mats and mods in an asus laptop mats version is 367.38.1 the model is gl553vd with a gtx 1050 mobile when i run mods i got the following log MODS start: Sat Dec 4 21:24:33 2021 Warning : test specifications should be used to control p-states Command Line : gputest.js -test 3 -test 18 -test 19 -test 52 -test 111 -test 112 -test 143 -mfg -null_display -poll_interrupts -pstate 0.max -no_thermal_slowdown -matsinfo CPU Foundry : GenuineIntel Name : Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz Family : 6 Model : 14 Stepping : 10 Version MODS : 367.38 OperatingSystem: Linux (x86_64) Kernel : 4.1.2-gentoo KernelDriver : 3.63 HostName : tinylinux Smbios version [0x300] is not supported File 'gp107_f.xml' not found gpu 0 dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x01, 0x00, 0x00 DID : 0x1c8d Raw ECID : 0x062312c000000070718881c4 ECID : SS768W-11_x49_y49 Device Id : GP107 Revision : a1 NV Base : 0xa3000000 FB Base : 0x90000000 IRQ : -1 Error 000000000229 : Gpu.Initialize hardware was not initialized Error 000000000229 : Global.PrintGpuInitError hardware was not initialized Error 000000000229 : Global.InitializeGpuTests hardware was not initialized RmDestroyGpu failed Error Code = 000000000229 (hardware was not initialized) ####### #### ######## ### ####### ###### ######## ### ## ## ## ## ### ## ## ## ## ### ####### ######## ## ### ####### ######## ## ### ## ## ## ## ### ## ## ## ######## ######## ## ## ## ######## ######## MODS end : Sat Dec 4 21:24:35 2021 [1.199 seconds (00:00:01.199 h:m:s)] i got the error ¨hardware was not initialized¨ but windows recognizes the gpu and i can play some games on it that means my gpu is not faulty how can i get pass this error or what this error means thanks in advance |
niko_lyan [ 12 дек 2021, 10:36 ] | |
Заголовок сообщения: | Re: mods error when testing gpu |
https://disk.yandex.ru/d/pBUIc8NdTaYEdg delete all the files from the flash drive and drop these, then send the report after checking, the PC will turn itself off mats 400.184 |
elgatillo263 [ 15 дек 2021, 21:29 ] | |
niko_lyan ok ill test and post the next log |
elgatillo263 [ 18 дек 2021, 05:37 ] | |
niko_lyan hi i tried your mods version and i am getting the following errors mods says MODS start: Wed Dec 15 11:57:44 2021 gputest.jse:7058: ReferenceError: HeatStressTest is not defined MODS end : Wed Dec 15 11:57:45 2021 [1.538 seconds (00:00:01.538 h:m:s)] and mats says error description gpu was not compatible now what can i try thanks for your response |
elgatillo263 [ 23 дек 2021, 00:29 ] | |
some suggestions? |
CatSW [ 23 дек 2021, 01:28 ] | |
elgatillo263 писал(а): File 'gp107_f.xml' not found You must find MODS+MATS with support your card. Download more MODS and check this file (gp107_f.xml) is present in his folder. Then repost MODS log there. |
elgatillo263 [ 23 дек 2021, 06:44 ] | |
CatSW Ok I’ll find a new version of mats with that file and then will post log output |
elgatillo263 [ 24 дек 2021, 04:50 ] | |
CatSW hi i find a new mods version wich is 455 and then now i got this log MODS arguments : MODS start: Thu Dec 23 11:24:52 2021 Command Line : gputest.js -skip_rm_state_init CPU Arch : x86_64 Name : Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz Cores : 8 Version MODS : 455.127 System OperatingSystem: Linux (x86_64) Kernel : 4.4.0-142-generic KernelDriver : 4.01 SBIOS Version : V1.28 SBIOS Date : 08/05/2019 HostName : bau-Nitro-AN515-52 Available RAM : 4729/7824 MB (Free/Size) Sys-uuid : HDD-Serno : WKPJBXSP ERROR: File 'gp107_f.xml' not found GPU 0 [01:00.0] dev.sub 0.0 ---------------------------------------- DevInst : 0 PCI Location : 0x00, 0x01, 0x00, 0x00 GPU DID : 0x1c8d PDI : 0x00002d9a94cf8b43 Raw ECID : 0x062312c000000070718881c4 Raw ECID (GHS) : 0x470707188800000000b188c40 ECID : SAMSUNG-SS768W-11_x49_y49 Device Id : GP107 Revision : a1 Sub Revision : 2 NV Base : 0xa3000000 FB Base : 0x90000000 IRQ : 16 Successfully cleared GPU's interrupt state. WARNING: GPU 0 [01:00.0] PCIE speed capability (8000Mbps) higher than down stream port link speed (2500Mbps) Chipset VID : FFFF (Unknown) Chipset DID : FFFF (Unknown) Chipset ASPM : L0s/L1 Chipset LTR : Enabled Error 000000000021 : CheckClocks (test 10) script failed to execute [0.000 seconds] Error 000000000021 : Global.RequireGoldenValues script failed to execute [0.054 seconds] Error 000000000021 : Global.LoadGoldenValuesHelper script failed to execute [0.054 seconds] Error 000000000021 : Global.LoadGoldenValues script failed to execute [0.054 seconds] Error 000000000021 : Global.InitializeGpuTests script failed to execute [0.140 seconds] gputest.jse:32: TypeError: subdev.Perf has no properties Error Code = 000000010021 (script failed to execute) ####### #### ######## ### ####### ###### ######## ### ## ## ## ## ### ## ## ## ## ### ####### ######## ## ### ####### ######## ## ### ## ## ## ## ### ## ## ## ######## ######## ## ## ## ######## ######## MODS end : Thu Dec 23 11:24:53 2021 [1.178 seconds (00:00:01.178 h:m:s)] |
CatSW [ 24 дек 2021, 12:09 ] | |
elgatillo263 писал(а): CatSW hi Hi ! elgatillo263 писал(а): ERROR: File 'gp107_f.xml' not found File again not found(. Download and try this version: MODS 370.14, 1050Ti GTX1050TI.zip [34.42 МБ] from user "acidwise" : viewtopic.php?f=48&t=96805&p=887104 elgatillo263 писал(а): gputest.js -skip_rm_state_init Also important - you must add to command line MODS key "-oqa" : "gputest.js -skip_rm_state_init - oqa" Then test memory: ./mats -e 1 -n 1 if PASS you have a chance your GPU is ok then try: ./mats -e 4 -n 1 If card not detected by MATS - change key "-n 1" to "-3d_card" - like this "./mats -e 1 -3d_card" |
crocodile70 [ 24 дек 2021, 14:24 ] | |
https://www.youtube.com/watch?v=AGLygFlF00A тест видеопамяти ноутбука In Russian. Sorry |
elgatillo263 [ 24 дек 2021, 20:48 ] | |
CatSW ok i will try the version of mods that you posted thanks and the gpu is working, is recognized by windows and i can play games on it but the reason im trying to run mods and mats test on it its because when i was playing a game the laptop turned off and when i turned on again, windows wasnt recognizing the gpu and device manager was saying error 43, then a let the laptop tuned off for 6 days and when i turned on magically was recognized by windows again and i was able to play on it too ---------- Добавлено спустя 1 час 29 минут 25 секунд: ---------- crocodile70 hi thanks for your response i will watch the video and try |
CatSW [ 25 дек 2021, 00:28 ] | |
elgatillo263 писал(а): t but the reason im trying to run mods and mats test Please read MODS.pdf in the same folder. It explains all the command line keys (you can choose what you want to testing) and explains all the errors that you can see from the test results. |
elgatillo263 [ 25 дек 2021, 01:19 ] | |
CatSW ok i will read that file before continue doing test |
CatSW [ 25 дек 2021, 02:06 ] | |
elgatillo263 писал(а): i will read that file before continue doing test I can upload this file here if you don't find it in your archive. Just say it)) |
elgatillo263 [ 29 дек 2021, 06:49 ] | |
CatSW please yes upload file here many thanks |
CatSW [ 29 дек 2021, 14:41 ] | |
elgatillo263 писал(а): please yes upload file here No problem) |
elgatillo263 [ 30 дек 2021, 22:07 ] | |
CatSW thanks i will test and then post the log ---------- Добавлено спустя 1 час 49 минут 44 секунды: ---------- CatSW ok so i tried the mods version for gtx1050 that you posted before and now got this MODS start: Thu Dec 30 13:52:48 2021 Command Line : gputest.js -skip_rm_state_init -mfg CPU Foundry : GenuineIntel Name : Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz Family : 6 Model : 14 Stepping : 10 Version MODS : 370.14 OperatingSystem: Linux (x86_64) Kernel : 4.1.2-gentoo KernelDriver : 3.63 HostName : tinylinux Smbios version [0x300] is not supported gpu 0 dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x01, 0x00, 0x00 DID : 0x1c8d Raw ECID : 0x00000000062312c000000070718881c4 Raw ECID (GHS) : 0x0000000470707188800000000b188c40 ECID : SS768W-11_x49_y49 Device Id : GP107 Revision : a1 NV Base : 0xa3000000 FB Base : 0x90000000 IRQ : 16 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. Failed to read good Jtag Ctrl Status WARNING... Failed to unlock Jtag for access! Chipset VID : FFFF (Unknown) DID : FFFF (Unknown) Rm call failed. default Disabled. Chipset ASPM : Disabled Chipset LTR : Enabled gputest.js : 22 mfg.spc : 4 boards.js : 1 boards_gp100.db: 36 boards_gp102.db: 12 boards_gp107.db: 38 boards.db : 3152 Error 000000000021 : Global.GetPerfPointsToTest script failed to execute Error 000000000021 : Object.RunSingleDeviceGpuTests script failed to execute Error 000000000021 : Function.GroupRunFcn script failed to execute gputest.jse:4740: TypeError: subdev.Perf has no properties GpuDevMgr not initialized. Device shutdowns will likely do nothing. Error Code = 000000000021 (script failed to execute) ####### #### ######## ### ####### ###### ######## ### ## ## ## ## ### ## ## ## ## ### ####### ######## ## ### ####### ######## ## ### ## ## ## ## ### ## ## ## ######## ######## ## ## ## ######## ######## MODS end : Thu Dec 30 13:52:49 2021 [0.861 seconds (00:00:00.861 h:m:s)] now whats next also tried run mats but got nothing on log |
CatSW [ 31 дек 2021, 00:50 ] | |
elgatillo263 писал(а): Failed to read good Jtag Ctrl Status WARNING... Failed to unlock Jtag for access! elgatillo263 писал(а): Error 000000000021 : Global.GetPerfPointsToTest script failed to execute Error 000000000021 : Object.RunSingleDeviceGpuTests script failed to execute Error 000000000021 : Function.GroupRunFcn script failed to execute gputest.jse:4740: TypeError: subdev.Perf has no properties GpuDevMgr not initialized. Device shutdowns will likely do nothing. Sorry, but I think You GPU is dead. But try to check all resistans (power line to GND - GPU, video memories and etc.) and voltage on this points on graphics card, may be you see some faults. |
elgatillo263 [ 31 дек 2021, 06:17 ] | |
CatSW hi windows recognize the gpu actually the gpu is working, i can play furmark test and pass and even play video games on it but i want to do a mats test in this gpu before selling this gpu is in a laptop integrated |
CatSW [ 31 дек 2021, 11:08 ] | |
elgatillo263 писал(а): actually the gpu is working If you are sure that it is this GPU that is working - not the integrated video - then maybe this MODS is not compatible with this motherboard. Try another MODS version... |
elgatillo263 [ 29 янв 2022, 07:38 ] | |
CatSW hi and sorry for my very late response i will try all mods versions that i found and i will tell you if someting new happen thanks |
CatSW [ 29 янв 2022, 11:50 ] | |
elgatillo263 писал(а): i will try all mods versions that i found and i will tell you if someting new happen Since you are testing the SECOND video card, do not forget about the key "-skip_rm_state_init" in the mods command line. And instead of "-mfg" you can try "-oqa" (or "-short" depending on version MODS). Good luck! |
Koiofan [ 27 июн 2022, 20:50 ] | |
Hi. Based on what you wrote, your video card is working. An error in MODS shows that it cannot initialize the graphics card. This situation may be due to bad memory, non-working GPU or your video card is not supported by this version of the MODS. |
