Текущее время: 08 май 2024, 20:14
uncledim
Заголовок сообщения: Re: Memfa [error][Framework] Exception during attempt to execute test... Добавлено: 22 дек 2021, 22:49 |
Зарегистрирован: 22 дек 2016, 12:07 Наличности на руках: 1,135.36
Сообщения: 1102 Откуда: Moscow
Pandemonium6 писал(а): Failed to load ME microcode Someone here solved this by GPU reballing
uncledim
Заголовок сообщения: Re: Memfa [error][Framework] Exception during attempt to execute test... Добавлено: 23 дек 2021, 09:01 |
Pandemonium6 писал(а): check the memory number 1 hmmm.. maybe try vbios without memory autodetect (i.e. with one type of supported mem) instead?
crocodile70
Заголовок сообщения: Re: Memfa [error][Framework] Exception during attempt to execute test... Добавлено: 24 дек 2021, 14:13 |
Зарегистрирован: 31 май 2020, 23:55 Наличности на руках: 420.60
Сообщения: 625 Откуда: Украина Днепр
Gigabytes are not the best choice for a test motherboard Change your motherboard Especially mats, mods
crocodile70
Заголовок сообщения: Re: Memfa [error][Framework] Exception during attempt to execute test... Добавлено: 27 дек 2021, 15:51 |
H170 pro gaming Asus m4a785td-v evo Asus my tests motherboards
Pandemonium6
Заголовок сообщения: Re: Memfa [error][Framework] Exception during attempt to execute test... Добавлено: 03 янв 2022, 18:48 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,140.72
Сообщения: 762 Откуда: Holand
OK, I will explain I had 4 cards with almost identical symptoms. All AMD 400/500 series. First card I treated by unsoldering vrams 1 and 2 as suggested and there was dirty soldering under them. I reballed them back and this card is mining again. For all others I used IPA (FLUX OFF or similar) pressurized under vrams and I made a reflow of all eight vrams and these cards came back to life like they were never spoiled. It means that this error "TcoreSiliconTarget: Failed to load ME microcode using toollib on..." likely means there is something wrong with vrams. Remember to clean under, bake for some time and reflow memories. There is also a technique I developed for my test setup when the Linux loads up despite of a black screen. I put the card to the x16 slot and I log into it by SSH from a second computer. There is much higher chance that dmgg.py will show correct results. Sometimes a card can oscillate do b2 and initialization restarts. It may be visible in Linux as a secondary but tests will not work, neither tserver nor python script. This is still the case of VRAM. Do not be afraid to clean under them and reflow them without reballing. When they are floating I tap them pushing down a little and it worked.
crocodile70
Заголовок сообщения: Re: Memfa [error][Framework] Exception during attempt to execute test... Добавлено: 04 янв 2022, 11:26 |
Thanks - very important information ! ну тут я уж чисто по приколу решал пошатать чипы, все равно менять не на что, эту то как раз брал на память, но без низа даже на 480 китайских градусах не смог, а греть больше 20 сек я чет не захотел, без низу. но после остывания она заработала) так что имейте ввиду load ME microcode - еще не приговор ГПУ. From another topic - quote viewtopic.php?f=48&t=100822&p=915841#p915841
