Xfx rx470 8gb major artefacting https://vlab.su/viewtopic.php?f=48&t=122085 |
iustin [ 04 янв 2022, 11:34 ] | |
Заголовок сообщения: | Xfx rx470 8gb major artefacting |
I have 3 xfx rx 470 8gb cards which have major artefacting. If you install driver in windows you get back screen or computer freeze. I tried tserver but it returns with gfx pipe busy. Sometimes tserver will freeze too! I tried dmgg.py but it report all channels and 4 memory defective. Is this memory controller? Gpu? All memory dead? |
iustin [ 05 янв 2022, 22:56 ] | |
Заголовок сообщения: | Re: Xfx rx470 8gb major artefacting |
i will try to take out first memory bank as someone suggested and see if it works... |
Roberts3333 [ 07 янв 2022, 03:50 ] | |
what do these artifacts look like? Most likely it is a gpu chip. |
Pandemonium6 [ 07 янв 2022, 10:06 ] | |
We need more information, images, measurements and so on in order to help you. |
iustin [ 22 фев 2022, 22:33 ] | |
Here are some pictures i took. I wasn’t able to make pictures until now… It can reach windows and it has error 43 Can’t see image if i try tserver. I cannot even understand what is written. If i boot as secondary card, i get gfx pipe busy.. |
nikolavik [ 23 фев 2022, 00:46 ] | |
That is usualy D channel. Try to reflow or reball D0 and D1 memory and see what is happening. Or try to change D0 and D1. |
iustin [ 18 май 2024, 22:56 ] | |
I know this is an old thread but it worth mentioning: If you use amd diagnostic tool and run rx470/480 command it will not give you correct informations … Instead you can use rx570/580 command and it will always give you the correct faulty bank… Good luck! |
