Текущее время: 26 апр 2024, 19:45
 Заголовок сообщения: Problems with Reballing
СообщениеДобавлено: 13 янв 2022, 15:09
hello, I have a problem reballing, especially reballing of GDDR6 memories, my reballing especially when I have to change all memory banks from Micron to Samsung on RTX20 do not last, after 2 - 3 days of stress test some bank of memory gets disconnect, I don't understand what I'm doing wrong, the method I use is the classic one:
1. I clean both the pcb and the memory with goot wick
2. I use the stencil to apply the tin balls in the picture, Sn63 / Pb37,
3. after removing the stencil i reflow once again the memory chip with fresh flux
4. to put the memory back on the board I preheat the bottom, apply flux, and use the heat gun at 260c until the chip floats (testing with tweezers).
i use No-Clean Tack Flux (ChipQuick SMD291)
am I doing something wrong? do you have any advice? should i use lead free balls?
 Заголовок сообщения: Re: Problems with Reballing
СообщениеДобавлено: 13 янв 2022, 15:18
If you use lead-free beads, it will get worse.
СообщениеДобавлено: 13 янв 2022, 15:57
You are doing perfectly well. I personally use a higher temperature around 400'C but I apply heat from the higher distance. It ensures that all balls are melted fast. Of course it will never reach 400'C because this temperature is inside the hot air nozzle and I operate it adjusting the altitude.
But I have a question, what kind of MATS errors do you get? Maybe they are GPU related and heating around GPU you heal it for a moment.
СообщениеДобавлено: 13 янв 2022, 17:29
for now the card I am working on crashes with the classic memory artifacts but shows no errors with mats, it will shows error on mats soon i'm sure, probably on a different memory chip, on this card I changed all the memories with samsung chips, after about a day the D0 chip failed, before reflowing the memory chip I tried to heat only the GPU just to exclude damage to the gpu itself and the problem remained, after the reflow of the memory chip D0 it worked for another 3 days of stress test until today.
So I don't think it's a GPU issue it's one of those cards with the damn bad Micron memory with code 8S if I'm not mistaken.
it is very irritating since I have to keep them in stress test for too many days and I am afraid to sell them for fear of having them returned after maybe a week.
Posted after 41 minute 25 seconds:
here it is, the mats report error on D1 this time
mats version 400.221. Testing TU106 with 20 MB of memory starting with 0 MB.
Read Error Count: 0
Write Error Count: 854955
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 0 0
FBIOA1 0 0 0
FBIOB0 0 0 0
FBIOB1 0 0 0
FBIOC0 0 0 0
FBIOC1 0 0 0
FBIOD0 0 0 0
FBIOD1 0 854955 0
Failing Bits:
D032 D033 D034 D035 D036 D037 D038 D039
=== MEMORY ERRORS BY BIT ===
P : Partition (FBIO)
READ 0 READ 1 READ ?
P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1 EXP. 0 EXP. ?
D 032 0 359304 0 647 358657 0
D 033 0 709407 0 315 709092 0
D 034 0 359304 0 647 358657 0
D 035 0 709407 0 315 709092 0
D 036 0 1310909 0 1009843 301066 0
D 037 0 709407 0 315 709092 0
D 038 0 359304 0 647 358657 0
D 039 0 709407 0 315 709092 0
=== MEMORY ERRORS BY ADDRESS ===
ADDRESS : Failing memory address, or buffer offset if starting with 'X+'
T : Type of memory error: W = write, R = read
S : Subpartition
B : Bank
E : Beat
U : PseudoChannel
ADDRESS EXPECTED ACTUAL REREAD1 REREAD2 FAILBITS TPSBEU ROW COL BIT(s)
0001356cbc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0026 032 D032,D033,D034,D035,D037,D038,D039
0001356cb8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0026 032 D032,D033,D034,D035,D037,D038,D039
0001356cb4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0026 032 D032,D033,D034,D035,D037,D038,D039
0001356cb0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0026 032 D032,D033,D034,D035,D037,D038,D039
0001356cac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0026 032 D032,D033,D034,D035,D036,D037,D038,D039
0001356ca8 00000000 00100010 00100010 00100010 00100010 WD1440 0026 032 D036
0001356ca4 00000000 00100010 00100010 00100010 00100010 WD1420 0026 032 D036
0001356ca0 00000000 00100010 00100010 00100010 00100010 WD1400 0026 032 D036
0001355cbc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0026 032 D032,D033,D034,D035,D037,D038,D039
0001355cb8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0026 032 D032,D033,D034,D035,D037,D038,D039
0001355cb4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0026 032 D032,D033,D034,D035,D037,D038,D039
0001355cb0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0026 032 D032,D033,D034,D035,D037,D038,D039
0001355cac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0026 032 D032,D033,D034,D035,D036,D037,D038,D039
0001355ca8 00000000 00100010 00100010 00100010 00100010 WD1c40 0026 032 D036
0001355ca4 00000000 00100010 00100010 00100010 00100010 WD1c20 0026 032 D036
0001355ca0 00000000 00100010 00100010 00100010 00100010 WD1c00 0026 032 D036
0001352c9c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0026 026 D032,D033,D034,D035,D037,D038,D039
0001352c98 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0026 026 D032,D033,D034,D035,D037,D038,D039
0001352c94 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0026 026 D032,D033,D034,D035,D037,D038,D039
0001352c90 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0026 026 D032,D033,D034,D035,D037,D038,D039
0001352c8c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0026 026 D032,D033,D034,D035,D036,D037,D038,D039
0001352c88 00000000 00100010 00100010 00100010 00100010 WD1440 0026 026 D036
0001352c84 00000000 00100010 00100010 00100010 00100010 WD1420 0026 026 D036
0001352c80 00000000 00100010 00100010 00100010 00100010 WD1400 0026 026 D036
0001351c9c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0026 026 D032,D033,D034,D035,D037,D038,D039
0001351c98 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0026 026 D032,D033,D034,D035,D037,D038,D039
0001351c94 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0026 026 D032,D033,D034,D035,D037,D038,D039
0001351c90 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0026 026 D032,D033,D034,D035,D037,D038,D039
0001351c8c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0026 026 D032,D033,D034,D035,D036,D037,D038,D039
0001351c88 00000000 00100010 00100010 00100010 00100010 WD1c40 0026 026 D036
0001351c84 00000000 00100010 00100010 00100010 00100010 WD1c20 0026 026 D036
0001351c80 00000000 00100010 00100010 00100010 00100010 WD1c00 0026 026 D036
000015f5fc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19e0 0002 037 D032,D033,D034,D035,D037,D038,D039
000015f5f8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19c0 0002 037 D032,D033,D034,D035,D037,D038,D039
000015f5f4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19a0 0002 037 D032,D033,D034,D035,D037,D038,D039
000015f5f0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1980 0002 037 D032,D033,D034,D035,D037,D038,D039
000015f5ec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1960 0002 037 D032,D033,D034,D035,D036,D037,D038,D039
000015f5e8 00000000 00100010 00100010 00100010 00100010 WD1940 0002 037 D036
000015f5e4 00000000 00100010 00100010 00100010 00100010 WD1920 0002 037 D036
000015f5e0 00000000 00100010 00100010 00100010 00100010 WD1900 0002 037 D036
000015c5fc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11e0 0002 037 D032,D033,D034,D035,D037,D038,D039
000015c5f8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11c0 0002 037 D032,D033,D034,D035,D037,D038,D039
000015c5f4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11a0 0002 037 D032,D033,D034,D035,D037,D038,D039
000015c5f0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1180 0002 037 D032,D033,D034,D035,D037,D038,D039
000015c5ec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1160 0002 037 D032,D033,D034,D035,D036,D037,D038,D039
000015c5e8 00000000 00100010 00100010 00100010 00100010 WD1140 0002 037 D036
000015c5e4 00000000 00100010 00100010 00100010 00100010 WD1120 0002 037 D036
000015c5e0 00000000 00100010 00100010 00100010 00100010 WD1100 0002 037 D036
000015b5dc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19e0 0002 023 D032,D033,D034,D035,D037,D038,D039
000015b5d8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19c0 0002 023 D032,D033,D034,D035,D037,D038,D039
000015b5d4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19a0 0002 023 D032,D033,D034,D035,D037,D038,D039
000015b5d0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1980 0002 023 D032,D033,D034,D035,D037,D038,D039
000015b5cc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1960 0002 023 D032,D033,D034,D035,D036,D037,D038,D039
000015b5c8 00000000 00100010 00100010 00100010 00100010 WD1940 0002 023 D036
000015b5c4 00000000 00100010 00100010 00100010 00100010 WD1920 0002 023 D036
000015b5c0 00000000 00100010 00100010 00100010 00100010 WD1900 0002 023 D036
00001585dc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11e0 0002 023 D032,D033,D034,D035,D037,D038,D039
00001585d8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11c0 0002 023 D032,D033,D034,D035,D037,D038,D039
00001585d4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11a0 0002 023 D032,D033,D034,D035,D037,D038,D039
00001585d0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1180 0002 023 D032,D033,D034,D035,D037,D038,D039
00001585cc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1160 0002 023 D032,D033,D034,D035,D036,D037,D038,D039
00001585c8 00000000 00100010 00100010 00100010 00100010 WD1140 0002 023 D036
00001585c4 00000000 00100010 00100010 00100010 00100010 WD1120 0002 023 D036
00001585c0 00000000 00100010 00100010 00100010 00100010 WD1100 0002 023 D036
000099f13c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ae0 0013 014 D032,D033,D034,D035,D037,D038,D039
000099f138 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ac0 0013 014 D032,D033,D034,D035,D037,D038,D039
000099f134 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1aa0 0013 014 D032,D033,D034,D035,D037,D038,D039
000099f130 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1a80 0013 014 D032,D033,D034,D035,D037,D038,D039
000099f12c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1a60 0013 014 D032,D033,D034,D035,D036,D037,D038,D039
000099f128 00000000 00100010 00100010 00100010 00100010 WD1a40 0013 014 D036
000099f124 00000000 00100010 00100010 00100010 00100010 WD1a20 0013 014 D036
000099f120 00000000 00100010 00100010 00100010 00100010 WD1a00 0013 014 D036
000099c13c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD12e0 0013 014 D032,D033,D034,D035,D037,D038,D039
000099c138 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD12c0 0013 014 D032,D033,D034,D035,D037,D038,D039
000099c134 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD12a0 0013 014 D032,D033,D034,D035,D037,D038,D039
000099c130 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1280 0013 014 D032,D033,D034,D035,D037,D038,D039
000099c12c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1260 0013 014 D032,D033,D034,D035,D036,D037,D038,D039
000099c128 00000000 00100010 00100010 00100010 00100010 WD1240 0013 014 D036
000099c124 00000000 00100010 00100010 00100010 00100010 WD1220 0013 014 D036
000099c120 00000000 00100010 00100010 00100010 00100010 WD1200 0013 014 D036
000099b11c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ae0 0013 000 D032,D033,D034,D035,D037,D038,D039
000099b118 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ac0 0013 000 D032,D033,D034,D035,D037,D038,D039
000099b114 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1aa0 0013 000 D032,D033,D034,D035,D037,D038,D039
000099b110 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1a80 0013 000 D032,D033,D034,D035,D037,D038,D039
000099b10c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1a60 0013 000 D032,D033,D034,D035,D036,D037,D038,D039
000099b108 00000000 00100010 00100010 00100010 00100010 WD1a40 0013 000 D036
000099b104 00000000 00100010 00100010 00100010 00100010 WD1a20 0013 000 D036
000099b100 00000000 00100010 00100010 00100010 00100010 WD1a00 0013 000 D036
000099811c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD12e0 0013 000 D032,D033,D034,D035,D037,D038,D039
0000998118 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD12c0 0013 000 D032,D033,D034,D035,D037,D038,D039
0000998114 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD12a0 0013 000 D032,D033,D034,D035,D037,D038,D039
0000998110 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1280 0013 000 D032,D033,D034,D035,D037,D038,D039
000099810c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1260 0013 000 D032,D033,D034,D035,D036,D037,D038,D039
0000998108 00000000 00100010 00100010 00100010 00100010 WD1240 0013 000 D036
0000998104 00000000 00100010 00100010 00100010 00100010 WD1220 0013 000 D036
0000998100 00000000 00100010 00100010 00100010 00100010 WD1200 0013 000 D036
00012ae6bc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19e0 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ae6b8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19c0 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ae6b4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19a0 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ae6b0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1980 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ae6ac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1960 0025 01e D032,D033,D034,D035,D036,D037,D038,D039
00012ae6a8 00000000 00100010 00100010 00100010 00100010 WD1940 0025 01e D036
00012ae6a4 00000000 00100010 00100010 00100010 00100010 WD1920 0025 01e D036
00012ae6a0 00000000 00100010 00100010 00100010 00100010 WD1900 0025 01e D036
00012ad6bc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11e0 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ad6b8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11c0 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ad6b4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11a0 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ad6b0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1180 0025 01e D032,D033,D034,D035,D037,D038,D039
00012ad6ac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1160 0025 01e D032,D033,D034,D035,D036,D037,D038,D039
00012ad6a8 00000000 00100010 00100010 00100010 00100010 WD1140 0025 01e D036
00012ad6a4 00000000 00100010 00100010 00100010 00100010 WD1120 0025 01e D036
00012ad6a0 00000000 00100010 00100010 00100010 00100010 WD1100 0025 01e D036
00012aa69c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19e0 0025 00a D032,D033,D034,D035,D037,D038,D039
00012aa698 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19c0 0025 00a D032,D033,D034,D035,D037,D038,D039
00012aa694 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19a0 0025 00a D032,D033,D034,D035,D037,D038,D039
00012aa690 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1980 0025 00a D032,D033,D034,D035,D037,D038,D039
00012aa68c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1960 0025 00a D032,D033,D034,D035,D036,D037,D038,D039
00012aa688 00000000 00100010 00100010 00100010 00100010 WD1940 0025 00a D036
00012aa684 00000000 00100010 00100010 00100010 00100010 WD1920 0025 00a D036
00012aa680 00000000 00100010 00100010 00100010 00100010 WD1900 0025 00a D036
00012a969c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11e0 0025 00a D032,D033,D034,D035,D037,D038,D039
00012a9698 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11c0 0025 00a D032,D033,D034,D035,D037,D038,D039
00012a9694 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11a0 0025 00a D032,D033,D034,D035,D037,D038,D039
00012a9690 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1180 0025 00a D032,D033,D034,D035,D037,D038,D039
00012a968c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1160 0025 00a D032,D033,D034,D035,D036,D037,D038,D039
00012a9688 00000000 00100010 00100010 00100010 00100010 WD1140 0025 00a D036
00012a9684 00000000 00100010 00100010 00100010 00100010 WD1120 0025 00a D036
00012a9680 00000000 00100010 00100010 00100010 00100010 WD1100 0025 00a D036
00012cfcdc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cfcd8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cfcd4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cfcd0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cfccc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0025 033 D032,D033,D034,D035,D036,D037,D038,D039
00012cfcc8 00000000 00100010 00100010 00100010 00100010 WD1c40 0025 033 D036
00012cfcc4 00000000 00100010 00100010 00100010 00100010 WD1c20 0025 033 D036
00012cfcc0 00000000 00100010 00100010 00100010 00100010 WD1c00 0025 033 D036
00012cccdc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cccd8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cccd4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0025 033 D032,D033,D034,D035,D037,D038,D039
00012cccd0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0025 033 D032,D033,D034,D035,D037,D038,D039
00012ccccc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0025 033 D032,D033,D034,D035,D036,D037,D038,D039
00012cccc8 00000000 00100010 00100010 00100010 00100010 WD1440 0025 033 D036
00012cccc4 00000000 00100010 00100010 00100010 00100010 WD1420 0025 033 D036
00012cccc0 00000000 00100010 00100010 00100010 00100010 WD1400 0025 033 D036
00012cbcfc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0025 027 D032,D033,D034,D035,D037,D038,D039
00012cbcf8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0025 027 D032,D033,D034,D035,D037,D038,D039
00012cbcf4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0025 027 D032,D033,D034,D035,D037,D038,D039
00012cbcf0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0025 027 D032,D033,D034,D035,D037,D038,D039
00012cbcec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0025 027 D032,D033,D034,D035,D036,D037,D038,D039
00012cbce8 00000000 00100010 00100010 00100010 00100010 WD1c40 0025 027 D036
00012cbce4 00000000 00100010 00100010 00100010 00100010 WD1c20 0025 027 D036
00012cbce0 00000000 00100010 00100010 00100010 00100010 WD1c00 0025 027 D036
00012c8cfc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0025 027 D032,D033,D034,D035,D037,D038,D039
00012c8cf8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0025 027 D032,D033,D034,D035,D037,D038,D039
00012c8cf4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0025 027 D032,D033,D034,D035,D037,D038,D039
00012c8cf0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0025 027 D032,D033,D034,D035,D037,D038,D039
00012c8cec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0025 027 D032,D033,D034,D035,D036,D037,D038,D039
00012c8ce8 00000000 00100010 00100010 00100010 00100010 WD1440 0025 027 D036
00012c8ce4 00000000 00100010 00100010 00100010 00100010 WD1420 0025 027 D036
00012c8ce0 00000000 00100010 00100010 00100010 00100010 WD1400 0025 027 D036
0000fded7c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19e0 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fded78 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19c0 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fded74 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19a0 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fded70 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1980 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fded6c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1960 001f 031 D032,D033,D034,D035,D036,D037,D038,D039
0000fded68 00000000 00100010 00100010 00100010 00100010 WD1940 001f 031 D036
0000fded64 00000000 00100010 00100010 00100010 00100010 WD1920 001f 031 D036
0000fded60 00000000 00100010 00100010 00100010 00100010 WD1900 001f 031 D036
0000fddd7c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11e0 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fddd78 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11c0 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fddd74 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11a0 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fddd70 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1180 001f 031 D032,D033,D034,D035,D037,D038,D039
0000fddd6c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1160 001f 031 D032,D033,D034,D035,D036,D037,D038,D039
0000fddd68 00000000 00100010 00100010 00100010 00100010 WD1140 001f 031 D036
0000fddd64 00000000 00100010 00100010 00100010 00100010 WD1120 001f 031 D036
0000fddd60 00000000 00100010 00100010 00100010 00100010 WD1100 001f 031 D036
0000fdad5c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19e0 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fdad58 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19c0 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fdad54 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD19a0 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fdad50 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1980 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fdad4c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1960 001f 025 D032,D033,D034,D035,D036,D037,D038,D039
0000fdad48 00000000 00100010 00100010 00100010 00100010 WD1940 001f 025 D036
0000fdad44 00000000 00100010 00100010 00100010 00100010 WD1920 001f 025 D036
0000fdad40 00000000 00100010 00100010 00100010 00100010 WD1900 001f 025 D036
0000fd9d5c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11e0 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fd9d58 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11c0 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fd9d54 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD11a0 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fd9d50 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1180 001f 025 D032,D033,D034,D035,D037,D038,D039
0000fd9d4c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1160 001f 025 D032,D033,D034,D035,D036,D037,D038,D039
0000fd9d48 00000000 00100010 00100010 00100010 00100010 WD1140 001f 025 D036
0000fd9d44 00000000 00100010 00100010 00100010 00100010 WD1120 001f 025 D036
0000fd9d40 00000000 00100010 00100010 00100010 00100010 WD1100 001f 025 D036
00005cf61c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13e0 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cf618 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13c0 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cf614 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13a0 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cf610 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1380 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cf60c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1360 000b 03c D032,D033,D034,D035,D036,D037,D038,D039
00005cf608 00000000 00100010 00100010 00100010 00100010 WD1340 000b 03c D036
00005cf604 00000000 00100010 00100010 00100010 00100010 WD1320 000b 03c D036
00005cf600 00000000 00100010 00100010 00100010 00100010 WD1300 000b 03c D036
00005cc61c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1be0 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cc618 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1bc0 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cc614 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ba0 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cc610 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1b80 000b 03c D032,D033,D034,D035,D037,D038,D039
00005cc60c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1b60 000b 03c D032,D033,D034,D035,D036,D037,D038,D039
00005cc608 00000000 00100010 00100010 00100010 00100010 WD1b40 000b 03c D036
00005cc604 00000000 00100010 00100010 00100010 00100010 WD1b20 000b 03c D036
00005cc600 00000000 00100010 00100010 00100010 00100010 WD1b00 000b 03c D036
00005cb63c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13e0 000b 028 D032,D033,D034,D035,D037,D038,D039
00005cb638 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13c0 000b 028 D032,D033,D034,D035,D037,D038,D039
00005cb634 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13a0 000b 028 D032,D033,D034,D035,D037,D038,D039
00005cb630 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1380 000b 028 D032,D033,D034,D035,D037,D038,D039
00005cb62c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1360 000b 028 D032,D033,D034,D035,D036,D037,D038,D039
00005cb628 00000000 00100010 00100010 00100010 00100010 WD1340 000b 028 D036
00005cb624 00000000 00100010 00100010 00100010 00100010 WD1320 000b 028 D036
00005cb620 00000000 00100010 00100010 00100010 00100010 WD1300 000b 028 D036
00005c863c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1be0 000b 028 D032,D033,D034,D035,D037,D038,D039
00005c8638 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1bc0 000b 028 D032,D033,D034,D035,D037,D038,D039
00005c8634 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ba0 000b 028 D032,D033,D034,D035,D037,D038,D039
00005c8630 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1b80 000b 028 D032,D033,D034,D035,D037,D038,D039
00005c862c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1b60 000b 028 D032,D033,D034,D035,D036,D037,D038,D039
00005c8628 00000000 00100010 00100010 00100010 00100010 WD1b40 000b 028 D036
00005c8624 00000000 00100010 00100010 00100010 00100010 WD1b20 000b 028 D036
00005c8620 00000000 00100010 00100010 00100010 00100010 WD1b00 000b 028 D036
000055eabc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10e0 000a 03e D032,D033,D034,D035,D037,D038,D039
000055eab8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10c0 000a 03e D032,D033,D034,D035,D037,D038,D039
000055eab4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10a0 000a 03e D032,D033,D034,D035,D037,D038,D039
000055eab0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1080 000a 03e D032,D033,D034,D035,D037,D038,D039
000055eaac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1060 000a 03e D032,D033,D034,D035,D036,D037,D038,D039
000055eaa8 00000000 00100010 00100010 00100010 00100010 WD1040 000a 03e D036
000055eaa4 00000000 00100010 00100010 00100010 00100010 WD1020 000a 03e D036
000055eaa0 00000000 00100010 00100010 00100010 00100010 WD1000 000a 03e D036
000055dabc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18e0 000a 03e D032,D033,D034,D035,D037,D038,D039
000055dab8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18c0 000a 03e D032,D033,D034,D035,D037,D038,D039
000055dab4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18a0 000a 03e D032,D033,D034,D035,D037,D038,D039
000055dab0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1880 000a 03e D032,D033,D034,D035,D037,D038,D039
000055daac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1860 000a 03e D032,D033,D034,D035,D036,D037,D038,D039
000055daa8 00000000 00100010 00100010 00100010 00100010 WD1840 000a 03e D036
000055daa4 00000000 00100010 00100010 00100010 00100010 WD1820 000a 03e D036
000055daa0 00000000 00100010 00100010 00100010 00100010 WD1800 000a 03e D036
000055aa9c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10e0 000a 02a D032,D033,D034,D035,D037,D038,D039
000055aa98 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10c0 000a 02a D032,D033,D034,D035,D037,D038,D039
000055aa94 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10a0 000a 02a D032,D033,D034,D035,D037,D038,D039
000055aa90 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1080 000a 02a D032,D033,D034,D035,D037,D038,D039
000055aa8c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1060 000a 02a D032,D033,D034,D035,D036,D037,D038,D039
000055aa88 00000000 00100010 00100010 00100010 00100010 WD1040 000a 02a D036
000055aa84 00000000 00100010 00100010 00100010 00100010 WD1020 000a 02a D036
000055aa80 00000000 00100010 00100010 00100010 00100010 WD1000 000a 02a D036
0000559a9c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18e0 000a 02a D032,D033,D034,D035,D037,D038,D039
0000559a98 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18c0 000a 02a D032,D033,D034,D035,D037,D038,D039
0000559a94 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18a0 000a 02a D032,D033,D034,D035,D037,D038,D039
0000559a90 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1880 000a 02a D032,D033,D034,D035,D037,D038,D039
0000559a8c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1860 000a 02a D032,D033,D034,D035,D036,D037,D038,D039
0000559a88 00000000 00100010 00100010 00100010 00100010 WD1840 000a 02a D036
0000559a84 00000000 00100010 00100010 00100010 00100010 WD1820 000a 02a D036
0000559a80 00000000 00100010 00100010 00100010 00100010 WD1800 000a 02a D036
000072e5bc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1de0 000e 012 D032,D033,D034,D035,D037,D038,D039
000072e5b8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1dc0 000e 012 D032,D033,D034,D035,D037,D038,D039
000072e5b4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1da0 000e 012 D032,D033,D034,D035,D037,D038,D039
000072e5b0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1d80 000e 012 D032,D033,D034,D035,D037,D038,D039
000072e5ac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1d60 000e 012 D032,D033,D034,D035,D036,D037,D038,D039
000072e5a8 00000000 00100010 00100010 00100010 00100010 WD1d40 000e 012 D036
000072e5a4 00000000 00100010 00100010 00100010 00100010 WD1d20 000e 012 D036
000072e5a0 00000000 00100010 00100010 00100010 00100010 WD1d00 000e 012 D036
000072d5bc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD15e0 000e 012 D032,D033,D034,D035,D037,D038,D039
000072d5b8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD15c0 000e 012 D032,D033,D034,D035,D037,D038,D039
000072d5b4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD15a0 000e 012 D032,D033,D034,D035,D037,D038,D039
000072d5b0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1580 000e 012 D032,D033,D034,D035,D037,D038,D039
000072d5ac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1560 000e 012 D032,D033,D034,D035,D036,D037,D038,D039
000072d5a8 00000000 00100010 00100010 00100010 00100010 WD1540 000e 012 D036
000072d5a4 00000000 00100010 00100010 00100010 00100010 WD1520 000e 012 D036
000072d5a0 00000000 00100010 00100010 00100010 00100010 WD1500 000e 012 D036
000072a59c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1de0 000e 006 D032,D033,D034,D035,D037,D038,D039
000072a598 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1dc0 000e 006 D032,D033,D034,D035,D037,D038,D039
000072a594 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1da0 000e 006 D032,D033,D034,D035,D037,D038,D039
000072a590 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1d80 000e 006 D032,D033,D034,D035,D037,D038,D039
000072a58c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1d60 000e 006 D032,D033,D034,D035,D036,D037,D038,D039
000072a588 00000000 00100010 00100010 00100010 00100010 WD1d40 000e 006 D036
000072a584 00000000 00100010 00100010 00100010 00100010 WD1d20 000e 006 D036
000072a580 00000000 00100010 00100010 00100010 00100010 WD1d00 000e 006 D036
000072959c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD15e0 000e 006 D032,D033,D034,D035,D037,D038,D039
0000729598 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD15c0 000e 006 D032,D033,D034,D035,D037,D038,D039
0000729594 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD15a0 000e 006 D032,D033,D034,D035,D037,D038,D039
0000729590 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1580 000e 006 D032,D033,D034,D035,D037,D038,D039
000072958c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1560 000e 006 D032,D033,D034,D035,D036,D037,D038,D039
0000729588 00000000 00100010 00100010 00100010 00100010 WD1540 000e 006 D036
0000729584 00000000 00100010 00100010 00100010 00100010 WD1520 000e 006 D036
0000729580 00000000 00100010 00100010 00100010 00100010 WD1500 000e 006 D036
0001007ddc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0020 013 D032,D033,D034,D035,D037,D038,D039
0001007dd8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0020 013 D032,D033,D034,D035,D037,D038,D039
0001007dd4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0020 013 D032,D033,D034,D035,D037,D038,D039
0001007dd0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0020 013 D032,D033,D034,D035,D037,D038,D039
0001007dcc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0020 013 D032,D033,D034,D035,D036,D037,D038,D039
0001007dc8 00000000 00100010 00100010 00100010 00100010 WD1440 0020 013 D036
0001007dc4 00000000 00100010 00100010 00100010 00100010 WD1420 0020 013 D036
0001007dc0 00000000 00100010 00100010 00100010 00100010 WD1400 0020 013 D036
0001004ddc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0020 013 D032,D033,D034,D035,D037,D038,D039
0001004dd8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0020 013 D032,D033,D034,D035,D037,D038,D039
0001004dd4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0020 013 D032,D033,D034,D035,D037,D038,D039
0001004dd0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0020 013 D032,D033,D034,D035,D037,D038,D039
0001004dcc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0020 013 D032,D033,D034,D035,D036,D037,D038,D039
0001004dc8 00000000 00100010 00100010 00100010 00100010 WD1c40 0020 013 D036
0001004dc4 00000000 00100010 00100010 00100010 00100010 WD1c20 0020 013 D036
0001004dc0 00000000 00100010 00100010 00100010 00100010 WD1c00 0020 013 D036
0001003dfc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0020 007 D032,D033,D034,D035,D037,D038,D039
0001003df8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0020 007 D032,D033,D034,D035,D037,D038,D039
0001003df4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0020 007 D032,D033,D034,D035,D037,D038,D039
0001003df0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0020 007 D032,D033,D034,D035,D037,D038,D039
0001003dec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0020 007 D032,D033,D034,D035,D036,D037,D038,D039
0001003de8 00000000 00100010 00100010 00100010 00100010 WD1440 0020 007 D036
0001003de4 00000000 00100010 00100010 00100010 00100010 WD1420 0020 007 D036
0001003de0 00000000 00100010 00100010 00100010 00100010 WD1400 0020 007 D036
0001000dfc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0020 007 D032,D033,D034,D035,D037,D038,D039
0001000df8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0020 007 D032,D033,D034,D035,D037,D038,D039
0001000df4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0020 007 D032,D033,D034,D035,D037,D038,D039
0001000df0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0020 007 D032,D033,D034,D035,D037,D038,D039
0001000dec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0020 007 D032,D033,D034,D035,D036,D037,D038,D039
0001000de8 00000000 00100010 00100010 00100010 00100010 WD1c40 0020 007 D036
0001000de4 00000000 00100010 00100010 00100010 00100010 WD1c20 0020 007 D036
0001000de0 00000000 00100010 00100010 00100010 00100010 WD1c00 0020 007 D036
0001247e7c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ee0 0024 03d D032,D033,D034,D035,D037,D038,D039
0001247e78 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ec0 0024 03d D032,D033,D034,D035,D037,D038,D039
0001247e74 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ea0 0024 03d D032,D033,D034,D035,D037,D038,D039
0001247e70 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1e80 0024 03d D032,D033,D034,D035,D037,D038,D039
0001247e6c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1e60 0024 03d D032,D033,D034,D035,D036,D037,D038,D039
0001247e68 00000000 00100010 00100010 00100010 00100010 WD1e40 0024 03d D036
0001247e64 00000000 00100010 00100010 00100010 00100010 WD1e20 0024 03d D036
0001247e60 00000000 00100010 00100010 00100010 00100010 WD1e00 0024 03d D036
0001244e7c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD16e0 0024 03d D032,D033,D034,D035,D037,D038,D039
0001244e78 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD16c0 0024 03d D032,D033,D034,D035,D037,D038,D039
0001244e74 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD16a0 0024 03d D032,D033,D034,D035,D037,D038,D039
0001244e70 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1680 0024 03d D032,D033,D034,D035,D037,D038,D039
0001244e6c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1660 0024 03d D032,D033,D034,D035,D036,D037,D038,D039
0001244e68 00000000 00100010 00100010 00100010 00100010 WD1640 0024 03d D036
0001244e64 00000000 00100010 00100010 00100010 00100010 WD1620 0024 03d D036
0001244e60 00000000 00100010 00100010 00100010 00100010 WD1600 0024 03d D036
0001243e5c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ee0 0024 029 D032,D033,D034,D035,D037,D038,D039
0001243e58 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ec0 0024 029 D032,D033,D034,D035,D037,D038,D039
0001243e54 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ea0 0024 029 D032,D033,D034,D035,D037,D038,D039
0001243e50 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1e80 0024 029 D032,D033,D034,D035,D037,D038,D039
0001243e4c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1e60 0024 029 D032,D033,D034,D035,D036,D037,D038,D039
0001243e48 00000000 00100010 00100010 00100010 00100010 WD1e40 0024 029 D036
0001243e44 00000000 00100010 00100010 00100010 00100010 WD1e20 0024 029 D036
0001243e40 00000000 00100010 00100010 00100010 00100010 WD1e00 0024 029 D036
0001240e5c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD16e0 0024 029 D032,D033,D034,D035,D037,D038,D039
0001240e58 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD16c0 0024 029 D032,D033,D034,D035,D037,D038,D039
0001240e54 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD16a0 0024 029 D032,D033,D034,D035,D037,D038,D039
0001240e50 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1680 0024 029 D032,D033,D034,D035,D037,D038,D039
0001240e4c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1660 0024 029 D032,D033,D034,D035,D036,D037,D038,D039
0001240e48 00000000 00100010 00100010 00100010 00100010 WD1640 0024 029 D036
0001240e44 00000000 00100010 00100010 00100010 00100010 WD1620 0024 029 D036
0001240e40 00000000 00100010 00100010 00100010 00100010 WD1600 0024 029 D036
0000c472dc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c472d8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c472d4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c472d0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c472cc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0018 03f D032,D033,D034,D035,D036,D037,D038,D039
0000c472c8 00000000 00100010 00100010 00100010 00100010 WD1440 0018 03f D036
0000c472c4 00000000 00100010 00100010 00100010 00100010 WD1420 0018 03f D036
0000c472c0 00000000 00100010 00100010 00100010 00100010 WD1400 0018 03f D036
0000c442dc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c442d8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c442d4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c442d0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0018 03f D032,D033,D034,D035,D037,D038,D039
0000c442cc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0018 03f D032,D033,D034,D035,D036,D037,D038,D039
0000c442c8 00000000 00100010 00100010 00100010 00100010 WD1c40 0018 03f D036
0000c442c4 00000000 00100010 00100010 00100010 00100010 WD1c20 0018 03f D036
0000c442c0 00000000 00100010 00100010 00100010 00100010 WD1c00 0018 03f D036
0000c432fc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c432f8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c432f4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c432f0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c432ec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0018 02b D032,D033,D034,D035,D036,D037,D038,D039
0000c432e8 00000000 00100010 00100010 00100010 00100010 WD1440 0018 02b D036
0000c432e4 00000000 00100010 00100010 00100010 00100010 WD1420 0018 02b D036
0000c432e0 00000000 00100010 00100010 00100010 00100010 WD1400 0018 02b D036
0000c402fc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c402f8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c402f4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c402f0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0018 02b D032,D033,D034,D035,D037,D038,D039
0000c402ec 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0018 02b D032,D033,D034,D035,D036,D037,D038,D039
0000c402e8 00000000 00100010 00100010 00100010 00100010 WD1c40 0018 02b D036
0000c402e4 00000000 00100010 00100010 00100010 00100010 WD1c20 0018 02b D036
0000c402e0 00000000 00100010 00100010 00100010 00100010 WD1c00 0018 02b D036
00009fea7c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1fe0 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fea78 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1fc0 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fea74 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1fa0 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fea70 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1f80 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fea6c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1f60 0013 03d D032,D033,D034,D035,D036,D037,D038,D039
00009fea68 00000000 00100010 00100010 00100010 00100010 WD1f40 0013 03d D036
00009fea64 00000000 00100010 00100010 00100010 00100010 WD1f20 0013 03d D036
00009fea60 00000000 00100010 00100010 00100010 00100010 WD1f00 0013 03d D036
00009fda7c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD17e0 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fda78 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD17c0 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fda74 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD17a0 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fda70 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1780 0013 03d D032,D033,D034,D035,D037,D038,D039
00009fda6c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1760 0013 03d D032,D033,D034,D035,D036,D037,D038,D039
00009fda68 00000000 00100010 00100010 00100010 00100010 WD1740 0013 03d D036
00009fda64 00000000 00100010 00100010 00100010 00100010 WD1720 0013 03d D036
00009fda60 00000000 00100010 00100010 00100010 00100010 WD1700 0013 03d D036
00009faa5c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1fe0 0013 029 D032,D033,D034,D035,D037,D038,D039
00009faa58 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1fc0 0013 029 D032,D033,D034,D035,D037,D038,D039
00009faa54 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1fa0 0013 029 D032,D033,D034,D035,D037,D038,D039
00009faa50 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1f80 0013 029 D032,D033,D034,D035,D037,D038,D039
00009faa4c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1f60 0013 029 D032,D033,D034,D035,D036,D037,D038,D039
00009faa48 00000000 00100010 00100010 00100010 00100010 WD1f40 0013 029 D036
00009faa44 00000000 00100010 00100010 00100010 00100010 WD1f20 0013 029 D036
00009faa40 00000000 00100010 00100010 00100010 00100010 WD1f00 0013 029 D036
00009f9a5c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD17e0 0013 029 D032,D033,D034,D035,D037,D038,D039
00009f9a58 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD17c0 0013 029 D032,D033,D034,D035,D037,D038,D039
00009f9a54 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD17a0 0013 029 D032,D033,D034,D035,D037,D038,D039
00009f9a50 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1780 0013 029 D032,D033,D034,D035,D037,D038,D039
00009f9a4c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1760 0013 029 D032,D033,D034,D035,D036,D037,D038,D039
00009f9a48 00000000 00100010 00100010 00100010 00100010 WD1740 0013 029 D036
00009f9a44 00000000 00100010 00100010 00100010 00100010 WD1720 0013 029 D036
00009f9a40 00000000 00100010 00100010 00100010 00100010 WD1700 0013 029 D036
0000466a1c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0008 03c D032,D033,D034,D035,D037,D038,D039
0000466a18 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0008 03c D032,D033,D034,D035,D037,D038,D039
0000466a14 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0008 03c D032,D033,D034,D035,D037,D038,D039
0000466a10 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0008 03c D032,D033,D034,D035,D037,D038,D039
0000466a0c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0008 03c D032,D033,D034,D035,D036,D037,D038,D039
0000466a08 00000000 00100010 00100010 00100010 00100010 WD1c40 0008 03c D036
0000466a04 00000000 00100010 00100010 00100010 00100010 WD1c20 0008 03c D036
0000466a00 00000000 00100010 00100010 00100010 00100010 WD1c00 0008 03c D036
0000465a1c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0008 03c D032,D033,D034,D035,D037,D038,D039
0000465a18 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0008 03c D032,D033,D034,D035,D037,D038,D039
0000465a14 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0008 03c D032,D033,D034,D035,D037,D038,D039
0000465a10 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0008 03c D032,D033,D034,D035,D037,D038,D039
0000465a0c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0008 03c D032,D033,D034,D035,D036,D037,D038,D039
0000465a08 00000000 00100010 00100010 00100010 00100010 WD1440 0008 03c D036
0000465a04 00000000 00100010 00100010 00100010 00100010 WD1420 0008 03c D036
0000465a00 00000000 00100010 00100010 00100010 00100010 WD1400 0008 03c D036
0000462a3c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ce0 0008 028 D032,D033,D034,D035,D037,D038,D039
0000462a38 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1cc0 0008 028 D032,D033,D034,D035,D037,D038,D039
0000462a34 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ca0 0008 028 D032,D033,D034,D035,D037,D038,D039
0000462a30 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1c80 0008 028 D032,D033,D034,D035,D037,D038,D039
0000462a2c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1c60 0008 028 D032,D033,D034,D035,D036,D037,D038,D039
0000462a28 00000000 00100010 00100010 00100010 00100010 WD1c40 0008 028 D036
0000462a24 00000000 00100010 00100010 00100010 00100010 WD1c20 0008 028 D036
0000462a20 00000000 00100010 00100010 00100010 00100010 WD1c00 0008 028 D036
0000461a3c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14e0 0008 028 D032,D033,D034,D035,D037,D038,D039
0000461a38 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14c0 0008 028 D032,D033,D034,D035,D037,D038,D039
0000461a34 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD14a0 0008 028 D032,D033,D034,D035,D037,D038,D039
0000461a30 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1480 0008 028 D032,D033,D034,D035,D037,D038,D039
0000461a2c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1460 0008 028 D032,D033,D034,D035,D036,D037,D038,D039
0000461a28 00000000 00100010 00100010 00100010 00100010 WD1440 0008 028 D036
0000461a24 00000000 00100010 00100010 00100010 00100010 WD1420 0008 028 D036
0000461a20 00000000 00100010 00100010 00100010 00100010 WD1400 0008 028 D036
00000dfb9c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10e0 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dfb98 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10c0 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dfb94 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10a0 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dfb90 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1080 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dfb8c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1060 0001 03a D032,D033,D034,D035,D036,D037,D038,D039
00000dfb88 00000000 00100010 00100010 00100010 00100010 WD1040 0001 03a D036
00000dfb84 00000000 00100010 00100010 00100010 00100010 WD1020 0001 03a D036
00000dfb80 00000000 00100010 00100010 00100010 00100010 WD1000 0001 03a D036
00000dcb9c 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18e0 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dcb98 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18c0 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dcb94 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18a0 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dcb90 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1880 0001 03a D032,D033,D034,D035,D037,D038,D039
00000dcb8c 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1860 0001 03a D032,D033,D034,D035,D036,D037,D038,D039
00000dcb88 00000000 00100010 00100010 00100010 00100010 WD1840 0001 03a D036
00000dcb84 00000000 00100010 00100010 00100010 00100010 WD1820 0001 03a D036
00000dcb80 00000000 00100010 00100010 00100010 00100010 WD1800 0001 03a D036
00000dbbbc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10e0 0001 02e D032,D033,D034,D035,D037,D038,D039
00000dbbb8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10c0 0001 02e D032,D033,D034,D035,D037,D038,D039
00000dbbb4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD10a0 0001 02e D032,D033,D034,D035,D037,D038,D039
00000dbbb0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1080 0001 02e D032,D033,D034,D035,D037,D038,D039
00000dbbac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1060 0001 02e D032,D033,D034,D035,D036,D037,D038,D039
00000dbba8 00000000 00100010 00100010 00100010 00100010 WD1040 0001 02e D036
00000dbba4 00000000 00100010 00100010 00100010 00100010 WD1020 0001 02e D036
00000dbba0 00000000 00100010 00100010 00100010 00100010 WD1000 0001 02e D036
00000d8bbc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18e0 0001 02e D032,D033,D034,D035,D037,D038,D039
00000d8bb8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18c0 0001 02e D032,D033,D034,D035,D037,D038,D039
00000d8bb4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD18a0 0001 02e D032,D033,D034,D035,D037,D038,D039
00000d8bb0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1880 0001 02e D032,D033,D034,D035,D037,D038,D039
00000d8bac 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1860 0001 02e D032,D033,D034,D035,D036,D037,D038,D039
00000d8ba8 00000000 00100010 00100010 00100010 00100010 WD1840 0001 02e D036
00000d8ba4 00000000 00100010 00100010 00100010 00100010 WD1820 0001 02e D036
00000d8ba0 00000000 00100010 00100010 00100010 00100010 WD1800 0001 02e D036
0000b4efdc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13e0 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4efd8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13c0 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4efd4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13a0 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4efd0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1380 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4efcc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1360 0016 03f D032,D033,D034,D035,D036,D037,D038,D039
0000b4efc8 00000000 00100010 00100010 00100010 00100010 WD1340 0016 03f D036
0000b4efc4 00000000 00100010 00100010 00100010 00100010 WD1320 0016 03f D036
0000b4efc0 00000000 00100010 00100010 00100010 00100010 WD1300 0016 03f D036
0000b4dfdc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1be0 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4dfd8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1bc0 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4dfd4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1ba0 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4dfd0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1b80 0016 03f D032,D033,D034,D035,D037,D038,D039
0000b4dfcc 00000000 00ef0010 00ef0010 00ef0010 00ef0010 WD1b60 0016 03f D032,D033,D034,D035,D036,D037,D038,D039
0000b4dfc8 00000000 00100010 00100010 00100010 00100010 WD1b40 0016 03f D036
0000b4dfc4 00000000 00100010 00100010 00100010 00100010 WD1b20 0016 03f D036
0000b4dfc0 00000000 00100010 00100010 00100010 00100010 WD1b00 0016 03f D036
0000b4affc 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13e0 0016 02b D032,D033,D034,D035,D037,D038,D039
0000b4aff8 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13c0 0016 02b D032,D033,D034,D035,D037,D038,D039
0000b4aff4 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD13a0 0016 02b D032,D033,D034,D035,D037,D038,D039
0000b4aff0 00000000 00ef00ef 00ef00ef 00ef00ef 00ef00ef WD1380 0016 02b D032,D033,D034,D035,D037,D038,D039
If you are getting failure for first MB of FB then try option -no_scan_out
Error Code = 00000001
СообщениеДобавлено: 14 янв 2022, 11:13
Your MATS test looks scary because data are not like a random numbers. They look like reversed bits. Maybe you solder it in too low temperature. The peak temperature may be around 250' but with 260' on the hot gun it takes ages. maybe you do not reflow all balls at once. I tap the chip from the top when it is floating.
I also repair cards for money but I would never sell repaired cards. This is too risky and it would be a big headache for me.
You don't have idea what such buyer would do with this card, he could even replace the motherboard and bring it back.
I give only warranty for the particular part which I personally replace and I put custom made holographic warranty stickers in 2-3 places. Before I give back a repaired card I mine on it for a day or two, never less then 24 hours but it is still no warranty it will last for the next week or month.
В этой теме нет новых непрочитанных сообщений. HP dv6610ew (da0at1mb8f1 rev. F) After reballing ot starting at all.
notemaster
16 июл 2014, 13:10
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing
abuholm
25 окт 2014, 05:34
abuholm Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. CELL CXD2992BGB reballing
BuTeK.MaCTeP
3326
23 авг 2017, 00:32
BuTeK.MaCTeP Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. BGA REBALLING STATION: IR(ceramic heater plate) OR HOT AIR, WHICH TO CHOOSE AND WHY?
azzed
17 сен 2022, 08:22
REM Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Aspire 5740 (09285-1M) Video problems
miros84
03 авг 2016, 00:12
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 63
