Pandemonium6 писал(а):
They should do it on each phase not only for powering the chip but for the main 12V rail on each phase.
installation of resistors is possible only where there are small current consumption. in many cases they are not installed because a large current is needed and then the size of the resistor will be very large. with an increase in size and the ability to hold more current, the purpose (of the fuse in this case) is lost.
that's why they don't fit everywhere.
