Диагностический райзер( перенос линий PCI -e) https://vlab.su/viewtopic.php?f=48&t=123216 |
Bolto [ 08 фев 2022, 20:16 ] | |
Заголовок сообщения: | Диагностический райзер( перенос линий PCI -e) |
Есть карта с пробитой линией pci e решил сделать райзер для диагностики. Перерезал 4 лини с верху и с низу с х16 распаял, но при попытки запуститься через этот райзер не подниматься напряжение, на заведомо исправной видеокарте тоже проверял, Фото как сделал прикрепляю. Вопрос где я накосячил? Вложение: Снимок экрана 2022-02-08 180557.jpg
Pandemonium6 [ 08 фев 2022, 20:49 ] | |
Заголовок сообщения: | Re: Диагностический райзер( перенос линий PCI -e) |
Which/what voltage does not rise? We have discussed this raiser many times, I use it on the day bay day basis. It always works on good cards and on bad cards with the first pcie lane broken. |
Bolto [ 08 фев 2022, 21:01 ] | |
Pandemonium6 писал(а): Which/what voltage does not rise? We have discussed this raiser many times, I use it on the day bay day basis. It always works on good cards and on bad cards with the first pcie lane broken. In general, everyone does not rise, there is only 12V 5V and 3.3V, if the card is connected to the riser, they rise, just connect the riser to the motherboard and there are no voltages |
Pandemonium6 [ 08 фев 2022, 21:16 ] | |
Maybe you cut PEXRST instead of lanes or just by mistake? Many boards need it to rise voltages. Get a multimeter and check all connections. |
Bolto [ 08 фев 2022, 22:00 ] | |
Pandemonium6 писал(а): Maybe you cut PEXRST instead of lanes or just by mistake? Many boards need it to rise voltages. Get a multimeter and check all connections. I noticed that the lines on one side are mixed up, I changed it as in the photo, now the voltage rises on the rx570 but does not see the card (most likely a corpse), and 280x, no matter how the voltage rose, remained Вложение: Снимок экрана 2022-02-08 180801.jpg
Pandemonium6 [ 08 фев 2022, 22:04 ] | |
These are spells, check the connections. |
Bolto [ 08 фев 2022, 23:35 ] | |
Pandemonium6 писал(а): These are spells, check the connections. Using the dialing method, I found out that I cut the lines on side B (REFCLK+,REFCLK-,HSlp(0),HSln(0)), And on side A all the lines remained intact, I noted on the drawings which lines are responsible for what Yellow -HSOp, HSOn Red -- REFCLK Green -- HSlp, HSln Or I misunderstood which tracks should be cut or the riser is not the same as it was in the example Вложение: Снимок экрана 2022-02-08 180557.jpg
Pandemonium6 [ 08 фев 2022, 23:49 ] | |
If you cur REFCLK it will never work ![]() |
Bolto [ 08 фев 2022, 23:57 ] | |
Pandemonium6 писал(а): If you cur REFCLK it will never work Does it work now? Haven't restored it yet REFCLK, I don't have the strength for it today |
Pandemonium6 [ 08 фев 2022, 23:58 ] | |
It will work ![]() |
Bolto [ 09 фев 2022, 10:19 ] | |
Pandemonium6 писал(а): It will work That's right, it worked |
