Sapphire RX580 Nitro+ not initialize https://vlab.su/viewtopic.php?f=48&t=123653 |
nikolavik [ 21 фев 2022, 23:54 ] | |
Заголовок сообщения: | Sapphire RX580 Nitro+ not initialize |
Hello again. I have sapphire Nitro+ RX580 8GB All resistance are in range of normal, i have all voltages on all phase, all pci data lane good, PERST (reset) good, REFCLK all good. Bios flashed, and check with oscilloscope get good signal. Card does not initialize. Is any one have any ideas? У меня сапфировый Nitro+ RX580 8GB Все сопротивления в пределах нормы, у меня есть все напряжения на всех фазах, все линии передачи данных PCI в порядке, PERST (сброс) хорошо, REFCLK все хорошо. Прошивал биос, проверял осциллографом, есть ли хороший сигнал. Карта не инициализируется. У кого-нибудь есть идеи? Thank you |
STALKER_71 [ 22 фев 2022, 00:10 ] | |
Заголовок сообщения: | Re: Sapphire RX580 Nitro+ not initialize |
Check logic. |
Pandemonium6 [ 23 фев 2022, 05:49 ] | |
What exactly do you mean "Card does not initialize."? Does the motherboard beep or it stays on 2b and restarts? What does tserver say? |
nikolavik [ 25 фев 2022, 21:04 ] | |
Motherboard does not recognize (3 beeps) and tserver not see card. |
Pandemonium6 [ 28 фев 2022, 09:57 ] | |
Could you measure resistances and then voltages on all voltage rails? |
nikolavik [ 01 мар 2022, 23:04 ] | |
I did that first. Compate to working card everything is almost similar. Customer said that raiser fell on metal and graphic turned of and after that came that problem. I don`t know where to look any more. |
