mods.log
MODS start: Thu Apr 7 12:59:36 2022
Command Line : gputest.jse -oqa
CPU
Foundry : GenuineIntel
Name : Intel(R) Pentium(R) CPU G4400 @ 3.30GHz
Family : 6
Model : 14
Stepping : 3
Version
MODS : 370.14
OperatingSystem: Linux (x86_64)
Kernel : 4.1.2-gentoo
KernelDriver : 3.63
HostName : tinylinux
Smbios version [0x300] is not supported
gpu 0 dev.sub 0.0
PCI Location : 0x00, 0x01, 0x00, 0x00
DID : 0x1c82
Raw ECID : 0x00000000056352c000000070589925c4
Raw ECID (GHS) : 0x0000000470705899240000000b1a8ac0
ECID : SS5YP9-11_x53_y43
Device Id : GP107
Revision : a1
NV Base : 0xee000000
FB Base : 0xd0000000
IRQ : 16
NV_PMC_INTR_0 bit 30 high.
Trying to clear interrupt by writing 0x2 to register 0x12004c
Successfully cleared GPU's interrupt state.
Failed to read good Jtag Ctrl Status
WARNING... Failed to unlock Jtag for access!
Raw ECID (RM) : 0
Foundry : TSMC
Subsystem VID : 0x1458
Subsystem DID : 0x3746
Board ID : 0xf001
Chip SKU : 400-0
Project : G210-0000
Fuse File Fmt : JSON
Display : 0x001000
VGA adapter : Primary
Native Mode : 2560x1440
Memory Size : 4096 MB
RAM Protocol : GDDR5
RAM Config : 1
ROM Version : 86.07.39.00.8b
ROM Type : Partner Production
ROM OEM Vendor : Gigabyte
ROM Timestamp : 2017-1-9 02:19:48
PState (mode) : 8 5 [0]
PState Version : 3.0
EDC : Disabled
GPC Clock : 1797.0/1784.0 MHz DEFAULT
DRAM Clock : 3504.0/3504.0 MHz MPLL
Host Clock : 571.4/571.4 MHz XCLKGEN3
XBar Clock : 1759.0/1745.4 MHz DEFAULT
Sys Clock : 1607.0/1593.8 MHz DEFAULT
Power Clock : 540.0/540.0 MHz SPPLL0
Display Clock : 1080.0/1080.0 MHz DISPPLL
NVVDD : 1050 mV
GPC Mask : 0x03 (2 GPCs)
TPC Mask : [7 7] (6 TPCs)
FB Mask : 0x03 (2 FB Partitions)
ROP/L2 Mask : [3 3] (4 ROP/L2s)
PES Mask : [1 1] (2 PESes)
FBIO Mask : 0x03 (2 FBIO Partitions)
FBIO Shift Mask: 0x00
XP Mask : 0x03 (2 3gio Pads)
Nvdec Mask : 0x01 (1 engine)
Nvenc Mask : 0x01 (1 engine)
Gpu Temp : 28 deg C
PEX Width, ASLM: 16 lanes, Not Supported
PEX Link Speed : 8.0 Gbit/s
PEX BandWidth : 128.0 Gbit/s
ASPM, ASPM-CYA : (L0s/L1, Disabled)
ASPM L1SS, CYA : (Disabled, L1.1/L1.2)
LTR : Enabled
Chipset
VID : 8086 (Intel)
DID : 190F (Unknown)
Chipset ASPM : L0s/L1
Chipset LTR : Enabled
RM Version : rel/gpu_drv/r370/r370_00-157
gputest.js : 22
oqa.spc : 2
boards.js : 1
boards_gp100.db: 36
boards_gp102.db: 12
boards_gp107.db: 38
boards.db : 3152
Running test(s) on GP107 (gpu 0, DID: 0x1c82, PCI Dom Bus Dev Fun: 0x0000, 0x01, 0x00, 0x00)
Enter JsGpuTest.SetPState (test 0)
Switched to PState 0 (0.max). Pcie Speed=8000, x16
ClkM = 3504.00 MHz
ClkHost = 571.43 MHz
ClkDisp = 1080.00 MHz
ClkPA = 40.00 MHz
ClkPB = 27.00 MHz
ClkGpc = 1797.00 MHz
ClkXbar = 1759.00 MHz
ClkSys = 1607.00 MHz
ClkHub = 648.00 MHz
ClkUtilS = 108.00 MHz
ClkPwr = 540.00 MHz
NVVDD = 1050 mV
Exit 000000000000 : JsGpuTest.SetPState (test 0) ok
Enter JsGpuTest.CheckConfig (test 1)
Exit 000000000000 : JsGpuTest.CheckConfig (test 1) ok
Enter JsGpuTest.CheckClocks (test 10)
Exit 000000000000 : JsGpuTest.CheckClocks (test 10) ok
Enter JsGpuTest.CheckInfoROM (test 171)
ERROR: BoardSerialNumber is missing from the OBD object. InfoROM may be blank.
Exit 020000171124 : JsGpuTest.CheckInfoROM (test 171) Invalid InfoROM
Error!
Error 020000171124 : JsGpuTest.Run (test 171) Invalid InfoROM
Error 000000171124 : Object.RunGpuTests Invalid InfoROM
Failure(s) :
LOOP TEST CODE MESSAGE
1 CheckInfoROM 020000171124 Invalid InfoROM
Error Code = 020000171124 (Invalid InfoROM)
MODS end : Thu Apr 7 12:59:41 2022 [5.109 seconds (00:00:05.109 h:m:s)]
