Текущее время: 01 июн 2024, 22:33
Koody
Заголовок сообщения: Re: Gigabyte GV-N308T серийная поломка Добавлено: 09 июн 2022, 00:23 |
Зарегистрирован: 03 июн 2022, 19:13 Наличности на руках: 15.01
Сообщения: 14 Откуда: Brazil
Shalun-avd писал(а): There it is like ... And I also noticed that at this phase there is a zero-resume at the pwm input. On other phases, the pwm signal goes directly to the PWM. I soldered the drmos in vain, tomorrow I’ll unsolder it, and on the other hand I’ll look for duplicate phases, there, too, there’s probably a zero on one of them, it’s enough to unsolder it. I really don't understand why it's on fire. There were double keys to reduce the current through each, everything works ... And then there is also a decoupling through the coils. Should I put 10-12 amp fuses? I think 10A is ok
