MODS start: Sun Aug 21 15:14:51 2022
Command Line : gputest.js -short -test 275 -no_gold -adc_cal_check_ignore -matsinfo
CPU
Foundry : GenuineIntel
Name : Intel(R) Pentium(R) CPU G3260 @ 3.30GHz
Family : 6
Model : 12
Stepping : 3
Version
MODS : 400.281
OperatingSystem: Linux (x86_64)
Kernel : 4.17.4-gentoo
KernelDriver : 3.87
SBIOS Version : 3602
SBIOS Date : 03/26/2018
HostName : tinylinux
Sys-uuid : 03000200-0400-0500-0006-000700080009
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x1e81
PDI : 0x0e1b2ea125c41497
Raw ECID : 0x010036000000006452851591
Raw ECID (GHS) : 0x1646452851400000018018200
ECID : PP5A55-24_x03_y08
Device Id : TU104
Revision : a1
NV Base : 0xf6000000
FB Base : 0xe0000000
IRQ : 11
ERROR: ** ModsDrvBreakPoint **
------------------------- BEGIN ASSERT INFO DUMP -------------------------
TCH(5): 0x8000
[25:16] NV_UCODE_ERROR_CODE_FWSECLIC_REG_BIOSCERT_ERR_CODE:
0x0 (NV_UCODE_ERR_CODE_NOERROR)
NV_PBUS_SW_SCRATCH(6): 0x12000000
[9:0] NV_UCODE_ERROR_CODE_FWSECLIC_REG1_UGPU_ERR_CODE:
GFW Secure Register Group cases:
NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT: 0x1
[7:0] NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT_PROGRESS:
0x1 (NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT_PROGRESS_STARTED)
[10:8] NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT_VALIDATION_STATUS:
0x0 (NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT_VALIDATION_STATUS_UNSUPPORTED)
[14:11] NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT_VALIDATION_DETAILS:
0x0 (NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_0_GFW_BOOT_VALIDATION_DETAILS_INIT )
NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_1: 0x40f900
[0:0] NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_1:
0x0 ( NV_PGC6_AON_SECURE_SCRATCH_GROUP_05_1_WRITE_PROTECT_MODE_DISABLED )
NVRM: NVRM: vbiosProcessSecurity_GV100: Unable to retrieve VBIOS_SECURITY_INFO
ACPI: Unable to evaluate dev method (_DOD) on 0:1:0.0
GF100GpuSubdevice: FloorsweepingAffected=0
GF100GpuSubdevice: Floorsweeping parameters present on commandline:
GF100GpuSubdevice: Floorsweeping parameter mask values: display=0x0 msdec=0x0 msvld=0x0 fbio_shift_override=0x0 ce=0x0 gpc=0x0 fb=0x0 fbio=0x0 fbio_shift=0x0 gpctpc[0]=0x0 gpctpc[1]=0x0 gpctpc[2]=0x0 gpctpc[3]=0x0 gpctpc[4]=0x0 gpctpc[5]=0x0 gpctpc[6]=0x0 gpctpc[7]=0x0 gpczcull[0]=0x0 gpczcull[1]=0x0 gpczcull[2]=0x0 gpczcull[3]=0x0 gpczcull[4]=0x0 gpczcull[5]=0x0 gpczcull[6]=0x0 gpczcull[7]=0x0
GF108PlusGpuSubdevice: Floorsweeping parameters present on commandline:
GF108PlusGpuSubdevice: Floorsweeping parameter mask values: pcie_lane=0x0 fbpa=0x0 spare=0x0
GM10xGpuSubdevice: Floorsweeping parameters present on commandline:
GM10xGpuSubdevice: Floorsweeping parameter mask values: nvenc=0x0 nvdec=0x0 head=0x0
GM20xGpuSubdevice: Floorsweeping parameters present on commandline:
GM20xGpuSubdevice: Floorsweeping parameters mask values: fbp_rop_l2[0]=0x0 fbp_rop_l2[1]=0x0 fbp_rop_l2[2]=0x0 fbp_rop_l2[3]=0x0 fbp_rop_l2[4]=0x0 fbp_rop_l2[5]=0x0 fbp_rop_l2[6]=0x0 fbp_rop_l2[7]=0x0 fbp_rop_l2[8]=0x0 fbp_rop_l2[9]=0x0 fbp_rop_l2[10]=0x0 fbp_rop_l2[11]=0x0 fbp_rop_l2[12]=0x0 fbp_rop_l2[13]=0x0 fbp_rop_l2[14]=0x0 fbp_rop_l2[15]=0x0
GP10xGpuSubdevice: Floorsweeping parameters present on commandline:
GP10xGpuSubdevice: Floorsweeping parameters mask values: gpc_pes[0]=0x0 gpc_pes[1]=0x0 gpc_pes[2]=0x0 gpc_pes[3]=0x0 gpc_pes[4]=0x0 gpc_pes[5]=0x0 gpc_pes[6]=0x0 gpc_pes[7]=0x0 gpc_pes[8]=0x0 gpc_pes[9]=0x0 gpc_pes[10]=0x0 gpc_pes[11]=0x0 gpc_pes[12]=0x0 gpc_pes[13]=0x0 gpc_pes[14]=0x0 gpc_pes[15]=0x0
TU10x floorsweeping parameters present on commandline:
TU10x floorsweeping parameter mask values: nvlink=0x0 nvjpg=0x0
Unknown init property : FbGddr5x8Mode
NVRM: FWSEC failed to complete correctly with status 1
NVRM: vbiosCheckFwseclicStatus_GV100 FWSECLIC binary failed with error code 0x2c4 for command 0x19
NVRM: Vbios Error Code Define:
NV_PBUS_SW_SCRATCH(7): 0x0
[31:28] NV_UCODE_ERROR_EXCEPTION_STATUS_UCODE_ID = 0x0,
[24:0] NV_UCODE_ERROR_EXCEPTION_STATUS_PC = 0x0,
NV_PBUS_SW_SCRATCH(15): 0x0
[27:24] NV_UCODE_ERROR_EXTERR_INTERRUPT_REG_UCODE_ID = 0x0,
[23:0] NV_UCODE_ERROR_EXTERR_INTERRUPT_REG_ADDRESS = 0x0,
NV_PBUS_SW_SCRATCH(16): 0x0
[23:0] NV_UCODE_ERROR_EXTERR_INTERRUPT_REG1_INSTR_PC = 0x0,
NV_PBUS_SW_SCRATCH(12): 0x0
[31:16] NV_UCODE_ERROR_CODE_UDE_GC6_REG_ERR_CODE:
NV_PBUS_SW_SCRATCH(14): 0x0
[31:16] NV_UCODE_POST_CODE_FWSECLIC_FRTS_ERR_CODE:
NV_PBUS_SW_SCRATCH(21): 0x2c4
[15:0] NV_UCODE_POST_CODE_FWSECLIC_SECUREBOOT_ERR_CODE:
0x2c4 ( Unknown Error )
NV_PBUS_SW_SCRATCH(0): 0x0
[31:16] NV_UCODE_ERROR_CODE_COMPACTION_REG_ERR_CODE:
NV_PBUS_SW_SCRATCH(1): 0x0
[31:16] NV_UCODE_ERROR_CODE_PREOS_REG_ERR_CODE:
NV_PBUS_SW_SCRATCH(5): 0x8000
[9:0] NV_UCODE_ERROR_CODE_FWSECLIC_REG_HULK_ERR_CODE:
fifoConstructEngineList_v02_01: No SW entry found for engine enum 0x12
fifoConstructEngineList_v02_01: No SW entry found for engine enum 0x14
NVRM: fbInitFbRegionsForFbps_GP102: FB Reserved Memory = 0'00000000 FB Usable Memory = 0'00000000 (0MB) FB Address Space = 0MB
NVRM: instSetBar0WindowToWorkspaceBase_GM200: VGA workspace base is invalid.
NVRM: Possible bad register read: addr: 0x9a0590, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: fbGetRamType_GK104: PartID 0: NV2080_CTRL_FB_INFO_RAM_TYPE _GDDR6 (0x11) does not match NV_PFB_FBPA_FBIO_BROADCAST_DDR_MODE=0x00.
NVRM: Possible bad register read: addr: 0x9a0470, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: Possible bad register read: addr: 0x9a050c, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: inforomConstructInforomFsAdapter: Failed to construct an INFOROM_FS_ADAPTER (type = 0x03).
NVRM: gpuStatePreInit_IMPL: engine removal in PreInit with NV_ERR_NOT_SUPPORTED is deprecated (OBJINFOROM:0)
NVRM: *** Chipset Setup Function Error!
NVRM: clkDomainsSanityCheck_SUPER: Almost all programmable domains must be included in the VBIOS clock domains.
NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000
NVRM: Possible bad register read: addr: 0x1e0214, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: Possible bad register read: addr: 0x1e0614, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: Possible bad register read: addr: 0x1e0a14, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: Possible bad register read: addr: 0x1e0e14, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: Possible bad register read: addr: 0x1e1214, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: Possible bad register read: addr: 0x1e1614, regvalue: 0xbadf3000, error code: NV_PPRIV_SYS_PRI_ERROR_CODE_FECS_DEAD_RING
NVRM: _nafllSanityCheck_FINAL: Wrong VBIOS configuration for NAFLL=3: DVCO=2x, Dist Mode=1x.
Please fix VBIOS devinit settings for DVCO and/or clock distribution mode.
NVRM: bp @ ../../../../resman/kernel/clk/avfs/clknafll.c:473
-------------------------- END ASSERT INFO DUMP --------------------------
First error recorded: 818 Mods detected an assertion failure
JavaScript stack trace:
#0: Initialize() in <native>:0
#1: InitializeGpuTests() in gputest.jse:309
#2: gputest_main() in gputest.jse:2304
#3: main() in gputest.jse:2247
NVRM: clkNafllDevicesStateInit_IMPL: Error occured during NAFLL sanity check: status=0x00000040, i=0.
NVRM: bp @ ../../../../resman/kernel/clk/avfs/clknafll.c:240
ATION_STATUS:
NVRM: clkAvfsStateInit_IMPL: Failed to initialize the NAFLL devices, status = 0x00000040
NVRM: bp @ ../../../../resman/kernel/clk/avfs/clkavfs.c:76
NVRM: clkStateInitUnlocked_IMPL: Error initializing AVFS state: status=0x00000040.
NVRM: bp @ ../../../../resman/kernel/clk/nv/clk.c:396
Error 000000000229 : Gpu.Initialize hardware was not initialized
Error 000000000229 : Global.PrintGpuInitError hardware was not initialized
Error 000000000229 : Global.InitializeGpuTests hardware was not initialized
Error Code = 000000000818 (Mods detected an assertion failure)
MODS end : Sun Aug 21 15:14:54 2022 [3.072 seconds (00:00:03.072 h:m:s)]
