https://vlab.su/
DUAL-RX5700-O8G-EVO bios
https://vlab.su/viewtopic.php?f=48&t=128498
Страница 1 из 1
pcexpert8 [ 04 сен 2022, 22:10 ]
Заголовок сообщения:  DUAL-RX5700-O8G-EVO bios
Hi ..I need bios for DUAL-RX5700-O8G-EVO from techpowerup does not work ..I have code 43 ,no video I tried with tserver but does not do test..Maybe can someone write me command for tserver?Thanks
YunicheK [ 04 сен 2022, 22:44 ]
Заголовок сообщения:  Re: DUAL-RX5700-O8G-EVO bios
Вам нужно прошить ШИМ-контроллер.
pcexpert8 [ 07 сен 2022, 21:57 ]
I this controller does not need flashing ...If there is red spot on controller should be flash done ..I have all phase I tested with oscilloscope ..Some memory bank is damage ,but I can't test because tserver does not support this model..I found on taobao new one tserver I think should do job ..https://item.taobao.com/item.htm?id=677015954184
I found that I dont have on 3.3 v on 12 pin EN2 ,maybe should be reason ..Logic smd I have on b 3.3 come from vrdy (4vand 11) ,vcc 3.3 but nothing on out..I change logic ,nothing change ..
pcexpert8 [ 10 сен 2022, 15:08 ]
Some help about this issue?
Pandemonium6 [ 18 сен 2022, 23:17 ]
Did you check shapes of all transients on the phases? I mean all phases, core, memory and other rails? Are you sure that they work?
pcexpert8 [ 19 сен 2022, 09:36 ]
yes I did with oscilloscope all they are fine ..After I notice that line 1.8 v was short..I remove GPU reball but short ..I must find GPU and change..
Pandemonium6 [ 22 сен 2022, 02:47 ]
Are you sure it is GPU? Maybe a capacitor or something on the 1.8V rail ?
pcexpert8 [ 22 сен 2022, 13:10 ]
if i remove gpu short gone that is issue with gpu
http://www.phpbb.com/
