Текущее время: 21 ноя 2026, 03:50
 Заголовок сообщения: Msi rtx 3060 2x ventus OC 12gb crash high core clock
СообщениеДобавлено: 27 окт 2022, 09:24
after several test i found out when i set core clock to 1350mhz and run mods test 178 , PASS. no memory problem. all 5 phases pulses fine. visual inspection perfect.
in windows i set afterburner to -500mhz and power limit 75% i can run heaven benchmark , but opening a game rise the core to 1485 and instant close game.
bad gpu? maybe reball ? i hear you.
thanks.
MODS log crash
MODS start: Wed Oct 26 23:19:02 2022
WARNING: -matsinfo is deprecated, because it is enabled by default, please remove it from command line
Command Line : gputest.jse -oqa -test 178 -matsinfo
CPU
Arch : x86_64
Name : Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Cores : 4
Version
MODS : 455.107
System
OperatingSystem: Linux (x86_64)
Kernel : 5.9.1-gentoo-x86_64
KernelDriver : 4.00
SBIOS Version : 2103
SBIOS Date : 08/15/2014
HostName : tinylinux
Available RAM : 7598/7920 MB (Free/Size)
Sys-uuid : 03000200-0400-0500-0006-000700080009
HDD-Serno : S0URJ9BQ105743
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2503
PDI : 0x5db35e68fb5fa53e
Raw ECID : 0x015ff5800000005d919b25c4
Raw ECID (GHS) : 0x4705d919b2400000016ff8280
ECID : SAMSUNG-SNP6R9-22_x-1_y10
Device Id : _PHRH
Revision : a1
Sub Revision : 0
NV Base : 0xf6000000
FB Base : 0xe0000000
IRQ : 16
WARNING: GPU 0 [01:00.0] PCIE speed capability (8000Mbps) higher than down stream port link speed (2500Mbps)
Platform : Hardware
Foundry : Samsung
Subsystem VID : 0x1462
Subsystem DID : 0x397d
Board ID : 0x02a0
Project : G190-0060
Fuse File Fmt : JSON
Display : 0x00000100 (id)
SBIOS Init : Primary
Native Mode : 1920x1080
Memory Size : 12288 MB
FB Vendor : Samsung
RAM Protocol : GDDR6
RAM Config : 6
WARNING: WAR(2791626): 'Num Row Remaps' reporting is disabled
ROM Version : 94.06.14.00.fc
ROM Type : Partner Production
ROM OEM Vendor : NVIDIA
ROM Partner : msi
ROM Project ID : 112921
ROM Timestamp : 2020-12-1 08:19:05
ROM Expiration : 2021-5-30 08:19:05
PState (mode) : 8 5 3 2 [0]
PState Version : 4.0
EDC : Disabled
GPC Clock : 1987.000 MHz DEFAULT
DRAM Clock : 7500.999 MHz DEFAULT
Host Clock : 1350.000 MHz NAFLL
XBar Clock : 1875.000 MHz DEFAULT
Sys Clock : 1665.000 MHz DEFAULT
Power Clock : 540.000 MHz NAFLL
NVDec Clock : 1740.000 MHz NAFLL
Display Clock : 1350.000 MHz DEFAULT
NVVDD : 1081.25 mV
GPC Mask : 0x07 (3 GPCs)
TPC Mask : [1f 1f 1e] (14 TPCs)
FB Mask : 0x07 (3 FB Partitions)
L2 Mask : [3 3 3] (6 L2s)
L2 Slice Mask : [db bd 7e] (18 L2 Slices)
PES Mask : [7 7 7] (9 PESes)
ROP Mask : [3 3 3] (6 ROPs)
FBIO Mask : 0x07 (3 FBIO Partitions)
FBIO Shift Mask: 0x00
XP Mask : 0x03 (2 3gio Pads)
Nvdec Mask : 0x01 (1 engine)
Nvenc Mask : 0x01 (1 engine)
Nvjpg Mask : 0x00 (0 engines)
Ofa Mask : 0x01 (1 engine)
PCE Mask : 0x30 (2 PCEs)
Syspipe Mask : 0x01 (1 syspipe)
Gpu Temp : 38 deg C
PEX Rx Lanes : 0xffff
PEX Tx Lanes : 0xffff
PEX Det. Lanes : 0xffff
PEX Width, ASLM: 16 lanes, Not Supported
PEX Link Speed : 8.0 Gbit/s
PEX BandWidth : 128.0 Gbit/s
ASPM, ASPM-CYA : (L0s/L1, Disabled)
ASPM L1SS, CYA : (Disabled, L1.1/L1.2)
LTR : Enabled
Chipset
VID : 8086 (Intel)
Chipset DID : 8C44 (SharkBay-Z87)
Chipset ASPM : L0s/L1
Chipset LTR : Enabled
RM Version : rel/gpu_drv/r455/r455_00-241
testlist.js : 6
resumehandler.js: 1
gputest.js : 30
oqa.spc : 2
boards.js : 1
Running test(s) on GPU 0 [01:00.0] (DID: 0x2503)
Enter SetPState (test 0) Wed Oct 26 23:19:04 2022
Switched to PState 0 (0.max). Pcie Speed=8000, x16
ClkM = 7501.00 MHz
ClkHost = 1350.00 MHz
ClkDisp = 1350.00 MHz
ClkGpc = 1987.00 MHz
ClkXbar = 1875.00 MHz
ClkSys = 1665.00 MHz
ClkHub = 810.00 MHz
ClkPwr = 540.00 MHz
ClkNvd = 1740.00 MHz
ClkPexGen = 3.00
NVVDD = 1081.25 mV
Exit 000000000000 : SetPState (test 0) ok [0.025 seconds]
Enter WfMatsBgStress (test 178) Wed Oct 26 23:19:04 2022
Enter GLStress (test 2) Wed Oct 26 23:19:04 2022
0xbe000054 channel could not be idled.
Failed idling a channel, will retry in 10s...
mods/core/utility/errloggr.cpp: GPU interrupt: NV_RUNLIST_CTXSW_TIMEOUT pending for runlist: 0 engine: 0, CTXSW_TIMEOUT_INFO_CTXSW_STATE : 3, CTXSW_TIMEOUT_INFO_STATUS : 0, CTXSW_TIMEOUT_INFO_PREV_TSGID : 2, CTXSW_TIMEOUT_INFO_NEXT_TSGID : 1
Bps: 0.0749 GB read or written per second (0.5662 GB in 7.564 sec)
Bps: 0.0% percent of raw FB bw (360.0480 GB per second)
New unexpected HW interrupts have occurred, count = 1 (1 new)
Background GLStress on dev 0 completed 200 frames.
dev 0: GLStress 200 Frames, DrawPct 100.0, avg Watts 48.850, max Watts 49.118.
INPUT_PEX12V avg Watts 13.248, max Watts 13.476
INPUT_EXT12V_8PIN0 avg Watts 35.601, max Watts 35.642
INPUT_MISC0 avg Watts 17.868, max Watts 17.914
INPUT_HIGH_VOLT0 avg Watts 0.000, max Watts 0.000
OUTPUT_NVVDD avg Watts 12.697, max Watts 12.816
GLStress "Post-Run" callback failed (unexpected device interrupts).
GLStress ErrCounter::ExitStackFrame failed.
Exit 020000002097 : GLStress (test 2) unexpected device interrupts [7.663 seconds]
Error!
Error 020000002097 : WfMatsBgStress_bgthread unexpected device interrupts [7.663 seconds]
Waiting 9s for the channel to go idle...
WfMatsBgStress "Post-Run" callback failed (unexpected device interrupts).
Error 020000178097 : WfMatsBgStress (test 178) unexpected device interrupts [0.000 seconds]
WfMatsBgStress "Post-Cleanup" callback failed (unexpected device interrupts).
WfMatsBgStress ErrCounter::ExitStackFrame failed.
Error 020000178097 : WfMatsBgStress (test 178) unexpected device interrupts [12.635 seconds]
Exit 020000178097 : WfMatsBgStress (test 178) unexpected device interrupts [12.635 seconds]
Error!
GPU tests completed.
Failure(s) :
LOOP TEST CODE MESSAGE
1 >GLStress 020000002097 unexpected device interrupts
1 WfMatsBgStress 020000178097 unexpected device interrupts
Error Code = 020000178097 (unexpected device interrupts)
MODS end : Wed Oct 26 23:19:18 2022 [16.112 seconds (00:00:16.112 h:m:s)]
 Заголовок сообщения: Re: Msi rtx 3060 2x ventus OC 12gb crash high core clock
СообщениеДобавлено: 29 окт 2022, 06:54
i try to crash the card , looking for some drmos heating, but no luck. any ideas?
СообщениеДобавлено: 29 окт 2022, 07:01
huehu3gg писал(а):
maybe reball ?
won't help
replace the GPU
В этой теме нет новых непрочитанных сообщений. msi 1660s ventus - crash
deathdealer9982
08 окт 2023, 10:57
allas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2060 6GB ZOTAC AMP - Strange behavior/crash if core >1700MHz
cxav
10 июн 2021, 23:16
preex Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3060 Ti Msi Ventus 2x
hashwood
31 дек 2023, 18:11
FrostDad Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3060 MSI Ventus код 43
jpb.2008
23 июл 2025, 19:47
jpb.2008 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MAXSUN RTX 3060 12gb не видит количество памяти
Master279
26 окт 2022, 00:14
zaytsevphoto Перейти к последнему сообщению
Сейчас этот форум просматривают: Yandex [BOT] и гости: 100
