Searching for software, script for Cayman XT gpu (hd6970) https://vlab.su/viewtopic.php?f=48&t=131363 |
RhOuCnK [ 30 дек 2022, 14:35 ] | |
Заголовок сообщения: | Searching for software, script for Cayman XT gpu (hd6970) |
I have downloaded tserver with a big amounts of preconfigured tests, but i cant seem to find one for cayman xt gpu-s. Is there one, or how can i test my gpu-s? Вложение: PXL_20221229_153137530.jpg Thanks in advance! |
madking [ 30 дек 2022, 19:15 ] | |
Заголовок сообщения: | Re: Searching for software, script for Cayman XT gpu (hd6970) |
here search viewtopic.php?f=48&t=100822&hilit=%2Atserver%2A |
preex [ 04 янв 2023, 00:16 ] | |
RhOuCnK hı can you share this program |
RhOuCnK [ 05 авг 2024, 23:27 ] | |
mad king Thanks for the resources! preex The download link went down, but i have it on a hdd. It has several paritions with different linux enviroments. Do you have an idea how can i share it? |
RhOuCnK [ 12 авг 2024, 00:17 ] | |
The issue is finally solved. It turned out that even if the suite does not contain a "memfa" script, it can be found when launching tserver with "-menu". In the GUI you can select different tests / bundle of tests and memfa is one of them. This way all the cards that are supported by the tserver version can be tested even if memfa isnt defined. I could test several HD5770, HD6870 and HD6970 cards. This test also produces memfa.log so the result can be seen. I dont have the resources to test more cards at the moment, but i think that this way several more older cards can be tested. I will leave this thread open to update it with new cards that i have tried it with. |
