surn32 писал(а):
Hello everyone!
The graphics card did not give video, I measure voltages and everything is ok, I see a slight ripple on the PCB on the PCI side. Due to the weight of these graphics, the memory chips tend to detach from the pcb, so I do a memory test, it gives me an error in memory E0 and E1, I replace memory D0, D1 and E0, E1 to make sure. I connect the graph and it gives video, I pass the furmark test, everything is ok. I put the graphics card to sleep with a youtube video in the background and it freezes and blue screen with artifacts, restarts and works again. I turn off the pc I turn on again and it no longer gives video.
I pass the memory test again and according to the test all the memories are ok. I don't know what else to look at. Any ideas?
thanks.
Hello. First of all which memory software u used to test memories? memtune? how did you move the memtune files to the R69XT folder?
Did you reball the memories or replace the memories with new?
